Question about SanDisk Sansa e250 MP3 Player
My sansa won't turn on!!
When I plug the sansa into the computer, it starts charging. Then once I unplug it, it turns off and will not turn back on again. Also, I can't get rid of songs! I have 90 songs on the mp3, but it only plays about 30. It says "bad track" in a red box to almost every song and I can't even delete them from the disc. Please help me!!
  • cblaw Apr 15, 2008
    yeah i plug it into my computer it works, but when i try to turn it on it wont work, someone please help
  • Anonymous May 08, 2009
    So when i plug in my Sansa, it says "connected". and the battery says its charging. But when i unglug it, it turns off.
Same thing happen to me. A Sansa is just similar to a cellphone.
Unscrew the backings and check if the battery is all the way in.
That fixed my problem, hope it fixed yours.
Posted on Jul 28, 2008
While plugged in, the unit receives its power from the computer, but once unplugged relies on the battery. The battery may not be making contact. To test, try pressing on the back to force the battery to make contact while pressing the power on button. If the unit powers up and you let go of the back and the unit goes off, the battery contact is the culprit. I simply took off the back cover and wedged wooden toothpick pieces along the bottom of the battery to force the battery upward onto the contacts. I also placed a toothpick over the battery so the cover would press down on it when the cover was replaced. Make sure cover screws are tight. This appears to have taken up the slack in the battery housing and solved the random power off problems - for now!
Posted on Jan 31, 2008
To get your screen to turn back on, try holding the power button for 15 seconds. the same thing happened to me and that helped me.
I can help you with the "bad track." That error message will come up once in a while. The files in your computr are not corrupted or anything: only the sansa's files are. Taking those bad tracks off won't help, you have to format it or something (I'm sorry, I forget excatly what it is!) but if you right-click on the sansa in My Computer theres OPEN, EXPLORE, and then FORMAT. This will wipe everything off of the mp3 player, but the problem you have with the bad tracks should be fixed. Just upload them again. I am really sorry I can't tell you how to fix your other problem, I'm having a similar problem with mine right now (I formatted it, then it stopped responding to my computer and won't show any image on the screen, just white letters).
Posted on Jul 15, 2007
SOURCE:
Computer ramdomly turns off
Instead of unplugging everything, only unplug 1/2 of the things. If it still won't start, unplug 1/2 of the remaining things (noting which ones they are). If it restarts then, it was one of the last set of things you removed that is the problem, so keep eliminating possibilities in this fashion this until you can determine which component it was. If it turns out to be the power cord, it could be a problem with the power supply.
Mar 02, 2012 | HP Computers & Internet
Hi! My Sansa e260 won't turn on. It charges
try upgrading the firmware...if that doesnt help u'll need to replace the battery here's how to update firmware- http://kb.sandisk.com/app/answers/detail/a_id/306
Aug 14, 2009 | SanDisk Sansa e260 MP3 Player
Sansa Clip won't charge
Here's the thing, technically it doesn't need to be turned on because it's supposed to turn on by itself.
I've had a problem sort of like that. It might be the plug, but it also might be the computer. I'd either suggest try plugging it into another computer or getting a new plug.
Apr 18, 2009 | SanDisk Sansa Clip MP3 Player
Sansa wont turn on!!
Hey so soz but what u can do is just plug it in and let it charge overnight and then try it again and it should turn
so hope thizz works guud luck
Sep 27, 2008 | SanDisk Sansa e260 MP3 Player
Sansa Fuze not working anymore
My friend give me a sansa mp3 player BB0703UBB. When i charge it in my PC and i forgot to unplug sansa mp3 player BB0703UBB after half hour i plug it. But the power is not working. i cannot open and play it anymore. I try to insert it on my PC but then it says unknown device. HELP!
Jul 17, 2008 | Audio Players & Recorders
Videos
You need to use the sansa media converter program that came with the sansa on the CD. This is used for photos1.gif and for video. The supported files are listed on the screen once you open it.You shouldnt have any problems transferring music to it using that program
Jan 25, 2008 | SanDisk Sansa e260 MP3 Player
I can't turn on my Sansa e250!! Help!
Check the battery connection(s) in the back. Remove the 4 screws, remove the battery an re-connect it. Charge the device for a few hours. Best of Luck.
Oct 05, 2007 | SanDisk Sansa e250 MP3 Player
Sansa MP3 player charges, plays while plugged into wall, but not unplugged.
When you plug it into the wall make sure you turn it off and let it charge all the way before you start using it again. see if that helps
Apr 25, 2007 | SanDisk Sansa e250 MP3 Player
My Sansa E260's screen is white and it won't turn off
After leaving it on all night and running the battery down I plugged it back in, it charged and everything is working fine. The morale of this story is, don't unplug it from the computer while it is in use.
Mar 06, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
110 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
