Question about HP LaserJet M1005 Printer
How to solve scanner error 12 problem in HP laser jet 10005 mfp
md_ehsan_1
  • 255 Answers
SOURCE: scanner error 12
uninstall the software of scanner and reinstall it
check your cables for loose contacts
Posted on Jul 04, 2009
manojro
  • 495 Answers
SOURCE: Scanner Error 12
SCAN ERROR 12, IT'S A MECHANIC PROBLEM. YOU MUST CONTACT A TECNICIAN.
Posted on Apr 17, 2009
MUKHTAR
  • 2022 Answers
SOURCE: HP LASer jet m1319f mfp errors no entries in fax
kindly re install the printer driver software .
Posted on Jan 14, 2010
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Posted on Apr 19, 2010
  • 3 Answers
SOURCE: error message on display of hp m 1005 mfp
HELLO
Posted on Jun 03, 2010
How can I repair laser scanner HP m 500/525 mfp?Every time when it shows the error code,I try to calibrate the scanner and shows black vertical lines.
this is very difficult to solve from your location. I will give you tech support ,please send me your email address or add me your skype xptareq2000@msn.com
Aug 20, 2016 | HP LaserJet Enterprise 500 M525f MFP -...
Scanner 12 error
HP LaserJet M1005 mfp is not work properly. printer show scanner error 12 ple. solution
Nov 08, 2012 | HP LaserJet M1005 All-In-One Printer
Hp laser jet m1005 mfp scanner error 12 problem print ok
hi
1. check for driver update
if not resolv
2. Firmware Update
if not
3. the motor of the scaner is damage
May 30, 2011 | HP LaserJet M1005 Printer
Scanner error 12 on hp laserjet m1005
When the lid or door of an HP Laser Jet printer isn't properly closed, the printer's display will read "Error 12." You can usually correct an "Error 12" by closing the printer's door securely -- a process which may require that you first fix the orientation of a toner cartridge so that the door can close. In some instances, an "Error 12" appears due to some other issue, such as a missing toner cartridge or a defective paper-feeding component.
Apr 22, 2011 | HP LaserJet M1005 All-In-One Printer
Salve ho un problema con la stampante :HP laser jet 1005 MFP la quale mi da errore scanner 12. Come posso risolvere.
clean the scanner (the lamp and the glass) if not working it is a problem and the scanner must be replaced with another one
Feb 24, 2011 | HP LaserJet M1005 All-In-One Printer
SCANNER ERROR 12
in my laser jet M1005 printer showing the scanner error 12. kindly help me how i can solve the problem.
E-mail : jkmeher@yahoo.com
Jul 13, 2009 | HP LaserJet M1005 Printer
Scanner error 12
Jul 04, 2009 | HP LaserJet M1005 Printer
HP LaserJet M1005 Printer Logo
76 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
