Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
The machine isn't turning on
    Sergeant:
    Champion:
  • 249 Answers
Did you make sure that it is plugged in the wall
Posted on Jan 17, 2013
Hotpoint fdw60 4th & 6th lights flashing
These two lights indicate a fault in the heating circuit.
You would require to have access to and be able to use a multimeter to test the heater if the machine isn't actually heating the water.
If it is heating the water then obviously we know the fault isn't with the heater.
Check the heater first.
Take the door apart and check the wiring in the door isn't broken.
If everything checks ok, take the pcb out, look for burned or dry joints around the relays.
Nov 05, 2012 | Washing Machines
Needle is hard to move up and down
try changing the needle
clean under the needle plate & in the bobbin area for lint or threads
rethread the machine top & bobbin
make sure the bobbin isn't too full
make sure the bobbin is not damaged or warped & that it is the right
bobbin for the machine
make sure the bobbin is turned the right way in the bobbin case
if none of these suggestions help then the machine needs to be
checked at a repair shop
Aug 30, 2012 | Kenmore 15516 Mechanical Sewing Machine
Second Needle thread isn't stitching
change the second needle
rethread the second needle & every thread guide
see if that helps & if it doesn't then the machine needs to be checked
Aug 13, 2012 | PfaFF Sewing Machines
My surger isn't making stitches
what is the name & model number of the machine?
do you have a manual?
try changing the needles
May 03, 2012 | White Sewing Superlock 1934D Mechanical...
Foot pedal doesn't work
well if the foot pedal isn't working, you can either replace it with a new one or take the machine to a sewing machine repair shop & let them check the foot pedal & see if it's fixable
Mar 14, 2012 | Husqvarna Sewing Machines
Error Message This embroidery card cannot be used with this machine
Is it a pre-loaded card - or one you add patterns to?
If its one you add patterns to, make sure the pattern isn't too large for the machine. EG if machine does 4"x4" and you've loaded a 5"x7" pattern, try down-sizing the pattern/ breaking it up into smaller sections to load & sew
Feb 16, 2012 | Brother SE-270D Computerized Sewing...
My samsung WA10R3 won't spin - it making a noise as if its trying to spin but the drum isn't turning and the water isn't coming out Thanks
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Samsung Washing Machines
My 2001 Sienna shakes when I apply the brake. I don't know the problem. It passed inspection so I am assuming it's not the brake. Please advise.
The car isn't driven when inspected
Your only choice is to recall, if you had the
brakes apart every year, to clean off rust,
inspect,lube & if necessary machine or replace
parts.
You can not drive year after year & not have
braking issues.
Some times the work you pay for isn't done
correctly & they put issues in there.
Never assume anything in life
Always inspect or test things,& trust no one
Jul 12, 2011 | 2001 Toyota Sienna
I Have an spl audio amp 520 watt and when it turns on it automatically goes to red which is protect. what could be causing this problem
It could be 3 things. There could be a short somewhere, your ground isn't strong enough, or you accidently switched up the ground line and the power line on the amp. Since the fuses aren't blown I would say that your ground isn't strong enough.
May 01, 2011 | SPL Car Audio & Video
EVERY TIME I POWER UP ITS SAYING F61
The below doesn't work with all Panasonic equipment but if this fails then the only fix is a replacement Laser which isn't cost effective.
U61 Fault
Corrupted or Faulty DVD in Machine.
  1. Put Machine into Standby
  2. If won't go into Standby hold 'Power' for 5-10 seconds
  3. In Standby hold 'Stop' & 'CH UP' together for 5-10 seconds until tray opens
If this fails then re-initialise the Machine as follows
  1. Put Machine into Standby as above
  2. In Standby hold 'Stop', 'CH UP' & 'Open/Close' together for 5-10 seconds.
  3. Hello displayed followed by TM AV1
  4. Put Machine into Standby
  5. 11-11 then 12-12 and finally 22-22 displayed
Switch Machine on and Retune
Apr 23, 2011 | Panasonic Audio Players & Recorders
Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer Logo
21 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
