Question about Dell Inspiron 6000 Notebook
Computer problem Hello. I start my computer but when it gets to the main screen it just blinks. The whole screen blinks and does not let me access any programs. I cant restore my system or run anything. I tried safe mode and that doesnt work either. This problem started after a game was downloaded from limewire. Can you help me?
    President:
  • 1,990 Answers
The only thing that you can do is Reinstall Your Operating System, Windows ??? Word to the Wise! Limewire is FULL of Viruses and you will get them more often than not!
Posted on Jan 25, 2009
I have hp pavillion DV6-6c35dx black screen with caps lock blinking twice to indicate corrupted bios. How do I flash the bios on this laptop?
If that computer wont boot to a screen that you can recognize, it is a brick. When the bios is corrupted and it wont allow the machine to start you cannot access any screens that will allow you to recover. It takes special equipment to flash the BIOS when this happens and most places just replace the whole motherboard because this equipment is not used often by repair shops.
Dec 14, 2016 | HP Computers & Internet
Samsung 710v problem. It started out as "Not optimum mode" for which i applied the 50/47 ohm fix present around the web. It worked for around a year.
Not optimum mode refers to the resolution. If you set it to 2048x1024 and your monitor won't support that, it will give you this message. Remove the resistor. In Windows Control Panel go to display. Adjust your resolution to your preference in the table. Do NOT exceed the table. You may have fried your monitor with the resistor. Good luck.
Nov 04, 2014 | Computers & Internet
DEll Latitude D520 is not starting at all.
Remove the main battery and try again, no change! remove the ram memory one at a time, testing as you go making sure there is one ram stick in the slot at all times. If none of these work, the motherboard is the likely problem and you will need a technician to access.
Jul 21, 2012 | Dell OptiPlex Computers & Internet
Will not start. screen black as the red light continues to blink. must be unplugged to get the blinking red light to stop. alive but dead.
The reason your television does not come on and you only have blinking red light is because there is a problem inside the unit.
The problem mainly is either from the main panel or the power panel of the television. There is a burnt capacitor on the main panel or the power panel that is why it is not powering up.
Unplug the television for a while, about an hour or two, so the high voltage on it will dissipate, then you unscrew the screws at the back. You will have access to the main panel and the power panel, assess it and you will find a burnt capacitor, have it replaced by turning the panel to the other side and melting it off with a soldering iron and replacing it with a new one. Then couple the television back together.
Take care
Oct 14, 2010 | Toshiba 42HP95 Television
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
My main screen is off center for game playing so I cannot get to all my buttons for choices--they are off the edge of the screen.
The screen could not have shifted only for one game or prog. It may be larger on all side and you notice it during the game when you want to access the buttons. So, press the settings button and reduce the screen size to occupy the whole physical screen (ie, max and no more). Now you will get the whole picture on the entire screen.
Nov 05, 2009 | E-Machines eMachines T3830 PC Desktop
Screen is blinking very frequently
Hello, this is a known problem with the model of that laptop. You will also notice in safe mode your screen will not flicker but in normal mode it will flicker.
Your laptop should still be under warranty and needs the LCD replaced.
Mar 04, 2009 | HP Compaq 6720s Notebook
Laptop problem
thank you problem solved.
Jan 25, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
