Question about GPS
Screen distroted - GPS
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 15 Answers
You need to do a 'factory reset' on your cell ... u might lose stored info' on your fone, but a reset will sort you out ...
Posted on Jan 17, 2013
    Filmmaker:
    Uploaded 5 video answers.
  • 88 Answers
Try pressing the reset button(usually on the side) if that doesnt work then i would say that its cooked.
DISTROTION, TAKES AWHILE TO GET A CLEAR PICTURE
Projection tubes need replaced. They will only work once they are warm, so they are wore out.
Sep 20, 2014 | Mitsubishi VS-60607 TV
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Jan 24, 2014 | Vizio Televison & Video
NO PICTURE AND DISTROTED LINES AND NO PICTUREON THE 1/8 OF SCREEN FROM TOP ON MY LED 32 INCH SAMSUNG TV
Check and replace the back-light inverter board. Contact any service technician. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Jan 23, 2014 | Samsung Televison & Video
Bad sound from my tv, pls help..
What do you mean by this bad sound. No sound? distroted sound?
May 06, 2012 | LG Televison & Video
Window screen is smaller then the monitor. it is on the
For presice adjustments of VGA input run the Auto Ajustment Software on the CD
Additional image quality improvement use the clock and clock pahase controls of the monitor to fine tune the image
Clock increase or decrease the value to minimize any vertical bars or stripes visible on the screen backgroung
Clock phase increase or decrease the value to minimize video distrotion or video jitter
  • allow the monitor to heat up before adjustments
  • use the adjustment pattern application provided ont he CD
  • select OSD menu to select image control and change clock or clock phase
  • Incase of any error restore factory settings select the OSD menu and select factory reset and select yes
Feb 25, 2010 | HP 2159M Monitor
Screen colors are all distroted and phone keeps shutting off
your phone has a virus....you should just take it back ...thats if you have a warranty
Sep 30, 2009 | Samsung SGH-A877 Impression Cell Phone
19" Samsung Monitor Image size function, distroted
Yes, this can be reset by pulling up your video card utility window. this should be located on the right hand side of the task bar. it should be a background utility. Just reset all settings to default in the video res tab...
Jan 28, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Printing is skewed and distroted
The drive rollers are probably contaminated, hardened or worn. You can try doing something through the manual feed; take a fresh sheet of quality paper, make a fat line across it with pure alcohol (not rubbing alcohol; too much water), let the printer pull the sheet in a few inches, then hold the paper to stop it, doing this several times before the sheet is fully pulled in.
If you are lucky, and you have traces of black on the sheet when it exits, you might have cleaned the rubber drive rollers a little.
Another possibility is, you may have a scrap of paper in the paper path causing problems but to check this, you will need some disassembly, not always a 'fun' project.
Oct 24, 2008 | HP PSC 2510 All-In-One InkJet Printer
GPS Logo
16 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
