Question about Dell Inspiron 8600 Notebook
Monitor Cuts Off After 5 seconds
I have a View sonic monitor that starts up OK then it says it will shut off in 5 seconds. I can't get it to stay on long enough to change anything.. perhaps its in a "sleep" mode or E'energy saver" mode of some sort. How do I remedy this?
  • jazvic May 11, 2010
    when this happen?? when the system is starting ??
    Thanks
Hi...
do one thing dear ....start ur comp and press F8 key for sometime...it will show u start mode ,select enable vga mode from their and start ur comp..then remove your vga driver and unplug your monitor from ur pc...then press and hold ur menu and select key in your monitor for some time.it will reset ur monitor setting...
then connct ur monitor to ur pc and again reinstall ur vga driver..and keep working
Posted on Jan 25, 2009
My monitor(view sonic e70fb ) is osd lock, n how how can get unlock
Hi Mandalavijay,
To unlock your monitor you need to hold two keys simultaneously for about 5 seconds.
In this case for your model you need to press the 1 key and the down arrow key and a message will appear which reads ' OSD Unlock'
Hope this helps...:) Your feedback would be appreciated.
Aug 22, 2011 | ViewSonic E70f 17" CRT Monitor
I had a power failure in my area. When power was restored my pc booted up ok but the monitor screen only stays visible as it should for about 3 seconds, then it goes black screen. I have powered...
Close windows down. Wait 15 - 20 mins, then power monitor up but NOT windows. Screeen should say "NO SIGNAL in centre. If t does not, wait five mins If still no display shut down and wait another 5 mins. Then start monitor un ANDt windows.. All should be OK now, If not shut EVERYTHING down and disconnect from mains ovrernight. (PC riouter/modem,,,, EVERYTHING . 12 hours later, re-connetc in THIS order - 1.) MONITOR 2.) PC 3) ROUTER/MODEM Should be OK now.
Aug 17, 2011 | Acer X193W LCD Monitor
Monitor is in asleep mode comes on 3 seconds goes off how do i get it 2 stay on
Does the monitor do this with other machines? If no or unsure, do the following and see if the problem persists
1. click Start 2. Click Control Panel
3. In Classic View, find the Power Options Icon and Double Click. In Category View, click the Performance And Maintenance and then click on Power Options.
4. Under the Power Schemes Tab, click the drop down box next to "Turn off monitor" and change the time.
5. Click Apply/Ok
Dec 08, 2010 | Dell E173FP 17" LCD Monitor
ViewSonic VA1930wm Screen stays on for about 2 seconds, and then goes off. 1) If no computer is connected you get a "no signal" message which stays for about 1 seconds and then goes off; blue...
Very typical of View Sonic. Sounds like a back backlight or inverter. I would go to www.viewsonic.com and open up a RMA. Most view sonic screens have a 3 year warranty. They will repair at no cost ..(if it is within that period) There is a date code on the back of the screen that will help you validate the above information.
Nov 07, 2010 | ViewSonic VA1930WM LCD Monitor
When i turn it on the screen lights up and is
More likely to be bad capacitors (bulging/leaking) in the power supply/inverter board just like these Viewsonic here: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find so we can guide you furher and will also help other poeple.
Apr 06, 2010 | ViewSonic VA903B Monitor
E machine monitor turns itself off and on
The same thing happened to me today. I was just sitting in my room then i hear a click and the cpu is on it stays on for a while then cuts off. It then cuts on and off with few seconds in between. It then stays in that way cutting and off for about a minite or two and then cuts off completely. A few minutes later it starts again. Also in the time it its off it will not turn on by pressing the power button. Sometimes it completly boots up by itself and then shuts itself down. If I shut it down manually while its on it'll turn itself on immeditaly after. What's going on! Will the warranty cover it? Do I need a new computer?
Feb 01, 2010 | E-Machines eMachines Monitor E15T4
Wanting to find out if my monitor is going out, or if theres
From what you are describing this is not a monitor issue. If the monitor were dying you'd see faults in the images, dead pixels, or random poweroffs. Loading windows slowly has nothing to do with your monitor. It is likely that you have picked up some sort of virus, spyware or malware that is slowing your system down. Have you installed any toolbars in your web browser lately? Those are notorious for ruining PC performance.
Dec 31, 2009 | ViewSonic VA1930WM LCD Monitor
I HAVE VIEW SONIC E70 ,IT IS WORKING FINE BUT WHEN I TURN OFF THE COMPUTER IT IS NOT AUTOMATICALLY SHUT DOWN,I HAVE TO SHUT DOWN THE MONITOR ALSO THIS PROBLEM IS ALSO OCCURS WHEN I TURN ON THE COMPUTER .
Possible Solution: Your Computer may have not configured the Monitor properly, to check, go to Start menu and Right click My Computer and select Manage then when Computer Manager is open go to Device Manager and find your Monitor and check if that device is working properly (right click on Monitor and go to Properties). Hope I helped - donman92
Jun 09, 2009 | ViewSonic E70 17" CRT Monitor
Viewsonic VE175b Monitor Powers Up Doesn't Display Windows OS
Hi; I had the same problem. I know that sometimes devices require you to perform some type of '10-30 second' "hold" of one or some of its buttons in order to 'reset' the device, so to speak. So, having said that, try this:
1) Turn your monitor off (no green light) but leave it plugged in.
2) Leave it off for about 10 seconds.
3) Hold the [2] button on your monitor (the one to the immediate LEFT of your monitor's POWER button).
4) While holding the [2] button, now press and HOLD your POWER button.
5) Wait for your image to appear and STAY onscreen for about 5 seconds, then release both buttons.
6) Your monitor should retain its onscreen image.
Hope this helps! Good Day to all!
Kelvin W.
Dec 04, 2008 | ViewSonic VE175b 17" LCD Monitor
Dell Inspiron 8600 Notebook Logo
73 people viewed this question
Alun Cox
