Question about Samsung Ua32d4000 32" Multi-system Led Lcd Tv For Worldwide Use
Tv turn on automatically
Found that my tv just turn on by itself when it on stanby mode... the red light just blink and turn on that all!!!
  • 192 Answers
SOURCE: TV Picture Freezes and Turns Off; Cannot Use Remote
My shop had this problem yesterday. We had to change the DMD to correct it. One of the data lines was being drawn down intermitently. This doesn't eliminate the digital PCB, but, we have seen the DMD do this more than a digital. You should have an authorized shop do the repair. Contact Samsung at 1-800-SAMSUNG or contact by email: http://samsung.com/ContactUs/ContactUs.htm Hope this helps.
Posted on Apr 01, 2007
  • 1694 Answers
SOURCE: My Samsund DLP Rear Projection TV keeps turning itself off.
solder bad connections on power supply pcb.......T.
Posted on Dec 17, 2008
Slinteriors
  • 8617 Answers
SOURCE: Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Posted on Aug 28, 2009
  • 28 Answers
SOURCE: My tv won't turn on, the red light just blinks and
power suppy needs replacing...according to samsung and other forums i read when mine did this its a common problem
Posted on Mar 20, 2010
SOURCE: Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Posted on May 03, 2010
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
Tv is in stanby mode. when i turn on power it seems like it wants to start but nothing comes up on screen. stanby light is blinking
The problem is in the main board of the tv, it is either a power supply issue or a high voltage problem. In order to isolate you will need a tv tech to check the set out and cost involved.
Jan 07, 2011 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Got the tv stanby Working
The ribbon connector which goes from the FMT to the DM is disconnected or not seated properly thats the only thing that will cause the 4 4 error other than a broken ribbon socket
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a Philips 42 in. Plasma Television model#42pf9956/37. When I turn it on it goes right back off. What the problem.
The TV is going into Protection Mode. When a failed part occurs inside the TV, it will turn itself OFF automatically to prevent further damage to other components. I'm sure the red light is blinking a code also.
Most likely the problem is occurring on the Backlight Inverter Board or the Main Power Supply. The Backlight Inverter Board is what brings power to the screen. The Main Power Supply is what brings power to all the circuit boards in the TV.
I would use the warranty if there is any to fix the TV. The repair shop may charge a crazy price to fix the problem.
If you have some electronic experience and you want to fix it yourself, you can sometimes find a Service Manual over the internet for less than $20. It will have red light blink codes, diagrams, schematics, and part numbers for every part on the boards. Replacement parts can be found by using the part numbers for the search on the internet. Most parts cost less than $10. Whole replacement boards can be found at a good price at Shopjimmy.com.
Aug 12, 2009 | Philips 42PF9630A 42 in. Plasma Television
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Can't turn on from Stanby mode
I would assume the power board has a problem. A tech could possibly repair it without replacing the whole board.
Nov 13, 2008 | Pioneer PDP-5070HD 50 in. Plasma...
Samsung Ua32d4000 32" Multi-system Led Lcd Tv For Worldwide Use Logo
43 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
