Question about Euro-Pro 0.7 Cu. Ft. Convection Toaster Oven
Fan motor quit. I need a replacement fan & motor unit. Where may I purchase this?
My Euro-pro to241r toaster-oven may have some electrical problems internally. I have owned it for over a year and a half and am now smelling something like burnt plastic or rubber coming from the vents on the right side near the control knobs. I am concerned it may cause an electrical fire. Has anyone else had this problem? I will take it to Wal-Mart where I bought it to see what they say.
My friend tried to look at it but said you need star shaped screw driver heads to take it apart. Look for an online manual to see if you can find information about a fan, but it may not be easy to get to with basic tools.
Did you try looking at there website www.Euro-pro.com which is posted by the model number?
Radioshack may be a possibility.
Good luck, Tom
Posted on Oct 10, 2013
How do I fix the Convection Fan not running/working
Make sure that the fan motor is being energized. If so, and it does not run then the fan needs to be replaced.
Apr 20, 2016 | Breville The Smart Oven Convection Toaster...
Fan motor
maybe you have stain in motor shaft! you can clean the motor by spraying of WD40. or maybe you have defective fuse thats connected to motor to source! or try to clean the rotary switch!
Oct 14, 2007 | Maximatic RO-1010X 1500 Watts Toaster Oven...
Hamilton Beach 31197 blower not working
There is no fuse. This is not an easy repair. I replaced mine which had an open winding. HB tried to make this unit so it could NOT be repaired, but of course it can be if you want to spend the time. The motor is part of a metal duct assy which also holds the rotisserie motor. It is RIVETED to the interior wall of the oven. The fan motor is a DUAL shaft C-Frame shaded pole 120 VAC ~ 3000 RPM ~ .5 amp motor which is not very common. The thermo on all these units is also inaccurate as the "sensor" is simply a metal plate screwed to the top right area of the oven interior. When I replaced my fan I also put in a new REAL oven thermo with a 12" sensing bulb which I mounted inside the oven as it should be. It took some searching to find these two parts. I have all the instructions and can post images if you want to tackle this. I did because the oven is large and the replacement model (31100 for $69 at Wal-Mart) has 1.5" less height and it uses the SAME parts with the same design flaw for the thermo. The retail cost on the parts for this job are ~$160, but I got mine for $15 total. I paid $48 for this oven years ago at Sams.
Apr 14, 2012 | Hamilton Beach 31197 120 Watts Toaster...
How can I fix the fan in a Hamilton Beach 31197C oven which is vibrating. I can push on the end of the shaft and it stops vibrating. Ive tried WD40 on the winding to see if it's a lube problem, and it...
You really need to replace the fan. This motor uses cheap sleeve bearings and you will only cause a problem (maybe burn the house down) trying to spray lube from the interior which I assume is what you are doing.
This is not an easy repair. I replaced mine which had an open winding. HB tried to make this unit so it could NOT be repaired, but of course it can be if you want to spend the time. The motor is part of a metal duct assy which also holds the rotisserie motor. It is RIVETED to the interior wall of the oven. The fan uses a DUAL shaft C-Frame shaded pole 120 VAC ~ 3000 RPM ~ .5 amp motor which is not very common, with 2 separate axial type metal blade sets. The oven door also develops a problem over time that keeps it from staying closed. The thermo on all these units is also inaccurate as the "sensor" is simply a metal plate screwed to the top right area of the oven interior. When I replaced my fan I also put in a new REAL oven thermo with a 12" sensing bulb which I mounted inside the oven as it should be. It took some searching to find these two parts. You can also repair the door mechanism at the same time and give yourself a couple more years until you have to do it again. I have all more and can post images if you want to tackle this. I did because the oven is large and the replacement model (31100 for $69 at Wal-Mart) has 1.5" less height and it uses the SAME parts with the same design flaw for the thermo. The retail cost on the parts for this job are ~$160, but I got mine for $15 total. I paid $48 for this oven years ago at Sams.
Mar 12, 2011 | Hamilton Beach 31197 120 Watts Toaster...
Need to buy replacement fan blade but I don't need the entire fan assembly. Could you help?
DON'T KNOW HOW OLD IS YOUR OVEN BUT IF YOU CAN REPLACED THE MOTOR AND FAN BLADE , ((PROBABLE ONE OR BOTH PART ARE DEFFECTD)) YOU MAY CONTACT SEARS THEY MAY GET THE PART FOR YOU CHECK IF YOUR OVEN HAS ANY WARRANTY CALL 1800-4MY-HOME JUST GET MODEL#
Feb 18, 2011 | Anvil COA8005 6600 Watts Toaster Oven with...
Have T4800 Convection Oven, need fan, motor and thermostat. Cannot locate any parts.
Not knowing where all you have checked, here is contact info for customer service for electrical appliances from Farberware: Electric Appliances
farberware-electric@saltonusa.com 1-800-233-9054
If that doesn't work, then here is an address that will give you a list of sites that carry oven parts:
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 16, 2011 | Farberware T490C 1500 Watts Toaster Oven...
Whirlpool fan assisted oven - fan motor coil burning out
The PCB board is definitely at fault here. One of the dc voltage lines is transferring too much current. The regulator and resistors are probably compromised. The better option is to replace the board than to try and fault find the components.
please rate my help++++Thanks for using FIXYA
Jun 23, 2010 | Toaster Ovens
Convection mode
I would assume that these ovens have a faulty fan motor mount or it may just be a bad design. I would go with a different make or model.
Apr 26, 2008 | Euro-Pro EP278 Bravetti Platinum 1500...
Euro-Pro 0.7 Cu. Ft. Convection Toaster Oven Logo
87 people viewed this question
Top Euro-Pro Toaster Ovens Experts
Dave
Dave
eyecam
Are you an Euro-Pro Toaster Oven Expert? Answer questions, earn points and help others
