Question about Cameras
The installation of my evision123 dual mode camera is not completing. It stalls after you click on install. Why?
    Problem Solver:
  • 6 Answers
Try restarting you computer and then going through with install. this happened to me after downloading and unziping the file. couldn't figure it out either then a power outage shutdown puter when i restarted it and tryed to istall it when through fine ... go figure.
Just in case you still have problems ...
This is a link to a driver download for th eVision 123 digital camera that has worked for me running Win XP. Hope it helps. Once you download and unzip the file, restart your computer and go to the setup file to start. for some reason the setup file doesn't seem to want to run until you restart. after the software is installed it works great. see the description on the page for more details of what is included in this setup. hope it works good for you too. And remeber to pay good deeds forward, if you come across someone else who needs this driver offer them the same link. DON'T FORGET TO BACK IT UP TO CD!!!! LOL
http://members.driverguide.com/driver/detail.php?driverid=487395&si=74692cca4f88edc9c505da4bc4f6f4b4
Posted on May 29, 2009
First my laptop crashed after i accepted an update and told me that i had a problem with my drivers. then i tried a system restore and it told me that the installation of windows couldn't be completed....
Hello
1 Try starting in safe mode.hold f8 key while booting up.Select safe mode.
2 Try running windows repair instead of system restore
3 If your running a dual or multicore processor,disable the multicore... Then try to install windows.
Once windows is installed re activate multi or dual core.
Sep 18, 2011 | Computers & Internet
Tip
Installing Your Digital Camera Driver on Your Windows Computer To transfer...
Installing Your Digital Camera Driver on Your Windows Computer To transfer digital camera photos to your computer, you need to install the camera's driveron your computer. You can install a driver fairly easily on a Windowscomputer, and that driver lets you access your digital camera photos onyour computer. To install the driver:
91394.image1.jpgenlarge.gif Enlarge1Choose Start→Control Panel→Printers and Other Hardware→Scanners and Cameras→Add an Imaging Device.The Scanner and Camera Installation Wizard opens with the Welcome screen, as shown in this figure.
91396.image3.jpgenlarge.gif Enlarge2Connect your camera or card reader to your computer (placing your camera in Connect mode, if necessary). You can probably connect your camera by using a USB cable, as this figure shows.
91398.image5.jpgenlarge.gif Enlarge3Select Automatic Port Detection in the wizard (see figure), then click Next.The Camera Selection window opens.
91400.image7.jpgenlarge.gif Enlarge4Select your digital camera make and model in the Camera Manufacturer and Model lists; then click Next.If your camera or card reader isn't listed,install the driver from the disk that came with your device. Place thedisk in the appropriate drive and click the Have Disk button. Thewizard walks you through the process.
5Turn your connected camera on. Click Next.The Installation Wizard now asks you to name your device.
91402.image9.jpgenlarge.gif Enlarge6Type a name for your camera or device. Click Next.Choose a name that makes sense to you, or the camera's make and model.
7To complete the Windows installation process, click Finished.
on Sep 23, 2010 | Cameras
Lost driver. Need installer for the D-Ling DSC-100 (Dual mode Camera).
Hello. You can download the driver for your D-Link DSC-100 by accessing this LINK
Choose an external server and save the file to your computer. Run and install it properly!
If you have any other questions, please leave a reply.
Thank you for using FixYa!
May 26, 2011 | D-Link DSC-100 Digital Camera
My computer do not accept the cd to install the software for sdr-h40 hdd camcorder, i get a message saying do not support the software
What OS is the computer running? The software isn't guaranteed to work with 64-bit Windows. (Windows 2000 through Vista are tested. Win 7 is an untested OS)
If you have Win7, you can try running the software in the compatibility mode. Right click on the Installer (.exe) and choose Properties. Click on the Compatibility Tab and check the box for Run this program in compatibility mode and use the drop down menu to select Vista or XP. Then right click again on the installer and choose Run as Administrator.
Another option is to run the software in a virtual computer running a supported OS. Win7 Pro and Ultimate support the XP mode which needs two programs downloaded and installed from Microsoft. Otherwise you need a licensed version of the OS to install in the virtualization program. Then install the camera software inside the virtual computer (as if it was the only computer).
I hope this helps.
(also note that the software does not run on some dual boot systems and may not run properly on multi-CPU systems. Updated software/drivers do not seem to be available on the Panasonic support site.)
Apr 28, 2010 | Panasonic SDR-H40 HDD Camcorder
Vivitar freelance V15 digital camera...HELP
OK Tested solution. pay attention please.
1. At this website you may download the Vivitar V15 Manual. http://www.retrevo.com/pdf/23576bh245/2/Introduction#q=Vivitar+V15
2. Notice device driver program PhoTags Express has "Sakar" in upper right corner. Sakar makes "inexpensive" cameras. I chose a camera most similar to V15 and download its Driver here.
http://www.sakar.com/productdetail.aspx?id=2275&categoryid=170
3. Driver install occurs normally with a restart of computer. V15 stil not recognized YET so next.
4.Get to Device Manager = press "Windows" keypad button" & "Pause" keypad button at same time. At system properties Press HARDWARE tab and the DEVICE Manager.
5. Double click camera device (may have yellow ? )
6.click DRIVER tab
7. click UPDATE Driver
8.choose NO, NOT At This Time, click NEXT
9.choose INSTALL from specific location
10. click Don't Search, I WILL CHOOSE Driver to Install
11.choose "Imaging Device"
12. choose DUAL MODE CAMERA (make certain check box has check)
13.Driver for V15 Dual Mode Camera INSTALLS.
14. Click FINISH
15. may have to restart.
16. CAmera should now show in My Computer as Dual Mode Camera
Nov 11, 2009 | Cameras
Can you use the aiptek mega cam like a web cam?
Yes you can. Here's what worked for me.
First disconnect your camera.
Software
Uninstall your existing software.
Download new software from http://www.goaiptek.com/drivers/driverfiles/minixp_1.5.zip Unzip.
Install the new software but DO NOT CONNECT THE CAMERA UNTIL INSTALLATION IS COMPLETE.
Camera
Remove any batteries.
Set switch to 'On'
Set Mode to Video
When software installation is complete, plug in camera to PC with USB cable supplied.
Run installed program on PC. The Mega camera screen will appear. Click on 'Live'. Your camera picture should appear on the screen.
Oct 06, 2009 | Aiptek Mini PenCam Digital Camera
Lost Cd my mini digital camera
i have the driver, email me @
tech @ lawckedgaming.com
i will send it to your email
Jun 30, 2009 | Dual Electronics Mini Dual Mode USB VGA...
Update stalls computer
UNPLUG THE CAM AND LOOK IN DEVICE MANAGER.FIND YOUR CAM AND UNINSTALL THE DRIVERS.REBOOT.DOWNLOAD NEW DRIVERS FROM WEBSITE FOR CAM.MAKING SURE ITS THE RIGHT MAKE AND MODEL AND ITS THE DRIVERS FOR YOUR OS.THEN REBOOT.PLUG CAMERA BACK IN.SYSTEM WILL DETECT IT AND LOAD THE DRIVERS.HOPE THIS HELPS.RICHARDM69PS I BELIEVE YOUR ORIGINAL DOWNLOAD BECAME CORRUPTED DURING INSTALL/DOWNLOAD UNINSTALL OLD REBOOT AND INSTALL NEW
Nov 17, 2008 | Logitech Webcam
Vista system will not insall dual mode camera
Make sure the camera is un-pluged while loading the software. After the installation, and the computer reboots, plug it in. It should recognize the drivers then. You should go into control panel and remove the first installation prior to re-installing.
Then your camera will work, but still a lot to be desired.
Apr 02, 2008 | Cameras
Lost software
I just bought one of these and discovered that someone had punched a hole through the software CD to hang the package on a peg! I found the driver and successfully loaded it from the following website.
http://sakar.com/driverdownloads.aspx
Oct 21, 2007 | Sakar 24280/24282 Digital Camera
Cameras Logo
104 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
