Question about Whirlpool Dryers
Electrical shock from dryer
I keep getting shock from dryer
    President:
  • Whirlpool Master
  • 2,651 Answers
Well then unplug it nad have checked by electricina you have a wire touching cabinet somewhere, and your dryer is now live!!! this should not be howeer be,, because a correctly installed machine would/should a least blow the breaker if/when this occurs!
Posted on Jan 25, 2009
Dryer shocks you when you touch it
This should NEVER happen. A properly installed dryer will be grounded both electrically and via chassis ground. You should IMMEDIATELY disconnect power from the dryer at the fuse/breaker panel, unplug the device and get it serviced before any further use. It is currently a fire and shock hazard!
Aug 23, 2014 | Dryers
Been shocked by my dryer and while plugging in my coffee pot
Check the Grounding Circuit in your home. Get a tested at your local hardware that you plug into the wall. You might need to get a electrician or your local electrical company to make sure your not having any Main Service Connection problems that is feeding the electrcity back into your home via the Grounding Circuit. This Grounding Circuit is to keep you from being Shocked by touching your dryer cabinet.
Nov 28, 2013 | Coffee Makers & Espresso Machines
New Maytag Electric shock
I believe you dryer is not hooked up correctly electrically.
You will need to unplug it from the wall without touching it.
You may need to use a wooden broom handle or some other insulating items to accomplish this.
Remember, electricity cannot flow through dry rubber, paper, cardboard, or wood.
If you cannot move the dryer away from the plug so you can reach it, you will need to shut off the dryer at the breaker box or fuse box before you start to unhook it.
The breaker box or fuse box should be marked on the paper on the back of the door as to which 2 circuit breakers or fuses are for the dryer, but most are not.
You should get someone smart to fix this before you have a fire or someone killed .
Be blessed.
Jun 14, 2013 | Maytag Dryers
Dryer electrical shock
first thing unplug machine and have electrical outlet checked for proper wiring. This is a safety hazard. you can buy a tool for about $5 to check them.
https://en.wikipedia.org/wiki/Receptacle_tester
if it passes this test then there is a wiring issue in the machine. Were you touching anything else metal when shocked?
if it fails, get a professional electrician to check and repair the wiring. Do NOT use any faulty outlet as they can be dangerous.
Stay Safe.
Went from a 4 prong to a 3 and get shocked sometimes.
You need a meter. Unplug the dryer and check for continuity between either of the 2 hot legs and the frame.
Sep 04, 2012 | Kenmore 62602 Electric Dryer
Dryer won't turn on at all.. There is power to it because it shocked me and the washer runs. Do you have any idea what might be wrong?
Wait a minute, the dryer shocked you? I've seen this happen twice, where I got shocked and the dryer welded itself to the washer. Ok, you may have a electrical issue with house wiring. Or, someone may have wired the dryer cord incorrectly to the dryer. I've seen both. I would address the "shocking" issue and once it's solved it most likely will fix the Dryer operation.
Oct 12, 2010 | Kenmore 98702 Stacked Washer/Dryer
No Heat
before working on any appliance-be sure to unplug it to keep from getting shocked & damaging your appliance
problem-runs but will not heat
1.loose wiring-check terminals & wiring
2.defective thermostat
3.defective centrifugal switch in motor(check linkage to motor)
4.defective timer-replace timer
5.open heater element--replace
Jul 27, 2010 | LG DLE3777 Electric Dryer
Dryer just stopped working. I get shocked when i open the door or touch any metal part of the machine.
Unless the shock is static electricity, you'd best unplug it and call a professional. You have a dangerous problem.
Jim Hart
Jun 14, 2010 | LG Electronics 7.3 Cu. Ft. Front Control...
First the dryer stopped heating, then when the reset button was pushed it started drying again, but now the heat will not shut off without unplugging the dryer
This is a situation that you need to be very careful with. It sounds like you have a grounded heating element. If this is the case, then the current can be running through the dryer's frame and can cause electrical shock. Keep the dryer unplugged and check the heating element for continuity. If it has none, replace the heating element. BE CAREFUL. Hope this helped and best wishes.
Aug 02, 2009 | Fisher and Paykel DEIX2 Electric Dryer
Kenmore Portable dryer, shocking
To me it sounds like you could have the polarity reversed on the wiring. Also is the outlet that it is plugged in to grounded that alone will cause a shock to be given off, Have goods holiday, biigg53566+
Dec 01, 2008 | Kenmore 82722 Electric Portable Dryer
Dryers Logo
356 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
