Question about Lexmark T640 Laser Printer
T644 is printing all black pages - Lexmark T640 Laser Printer
3 Suggested Answers
SOURCE: setting print count on Lexmark T644
I'm assuming you mean the maintaince counters... Turn off the printer. Press and hold the check and right arrow buttons on the front of the printer
Turn on the printer. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. Select Reset Maintenance Count from the Configuration menu. The message Reset Maint Cnt=Reset displays momentarily. Press Check to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
Posted on Jan 26, 2009
  • 11 Answers
SOURCE: print job is totally black
I know you've tried some of the below suggtions but I put the whole list there for everyone else. If this printer is less than a year old call them. Their tech support has changed a lot! They try to take care of you.
Possible causes:
· Check/Replace the toner cartridge
· Check the charge roll assembly (see Note below)
· Check the Toner Darkness, Brightness, and Contrast settings
· Try cleaning the inside of the printer
· Bright light/sunlight entering the printer (on right side of printer)
· Printing on media other than plain paper (make sure you're using laser paper- it makes a difference!)
· Using a refilled cartridge. Lexmark will emphatically tell you they are not supported.
NOTE: Checking the charge roller:
1 Power off the printer and remove the toner cartridge.
2 Look into the upper area of the printer where the cartridge was sitting. Located near the top of the printer you will see a couple of gray rollers. This is the charge roller assembly. See the area highlighted in the image below.
NOTE: If you cannot see the rollers, close the upper lid slightly and the rollers should lower into view.
For larger version of this image, click here.
3 Make sure the roller assembly is seated correctly into the holders on the left and right-hand sides. If not, try to reseat the assembly into the holder arm.
IMPORTANT! If the charge roller assembly is not present, it needs to be installed. Look around the inside of the printer and near the printer for the roller assembly. If the charge roller assembly is missing, you will need to order a replacement set in order to get the printer operational again. See the 'Additional Assistance' section at the end of this document for more information.
4 If the rollers are present and installed correctly, check their condition. If the roller surface appears dirty, take a clean dry cloth and carefully clean off any dust or toner. Do your best to ensure all of the roller surface is clean. NOTE: If any part of the rollers is damaged, the charge roll assembly will need to be replaced.
CAUTION! Try not to touch the rollers with your bare hands. The surface is susceptible to contamination and a permanent mark could remain on the rollers.
5 If you were able to reseat the charge roller assembly or managed to clean the rollers, power on the printer and try printing again. Print 10 to 20 pages to give the pages a chance to clear up. If the pages do not begin to clear, the printer will likely require service to correct the issue.
For more information on arranging repair service, please contact Lexmark Technical Support or an authorized service center. See the 'Additional Assistance' section at the end of this document for details.
Posted on Jun 17, 2009
HORIZONTAL LINES ACROSS T644 PRINTER AND 930.00 ERROR CODE
The error code 930.00 indicates a problem in the laser print head section of the printer. This will cause error in the printouts like you are having. This type of problem is not user serviceable and will require an authorized service dealer to obtain and install the printhead assembly. This is directly from page 2-24 of the service manual.
Jul 24, 2012 | Lexmark T644 Laser Printer
I've got a Lexmark T520 and it's not printing anything from photoshop - it says 'flushing buffer' and then just doesn't print. It will print from other sources i.e. web pages...
to large a data being sent for memory on printer photoshop will be hungry data and its has to small a memory to cope ok for normal printing but not this type of work
Aug 14, 2011 | Lexmark T644 Laser Printer
My lexmark print black
laser print head is bad.
Nov 20, 2010 | Lexmark T644 Laser Printer
Have Lexmark t644 printing light on page complete blank on a left side Tried cleaning mirrors in a scanner check transfer roller tensions charge rollers all seem to be fine even charge scanner unit all...
The problem could be with the High Voltage Power Supply or with the video cable connected to the system board may be loose. Here is a very good article that talks about the different steps you can follow to try to resolve the issue.
http://bit.ly/bLSly4
Feb 17, 2010 | Lexmark T644 Laser Printer
Dell M5200n printer will not print web pages, it will print from adobe, black and white pictures, and text documents. When printing from web page the lcd display says 900 service RIP software. I have...
i would recomend you downloading a fix file from dell.com you need a rip repair file at little or no cost.if you are running vista, i would recomend you get a new printer
Feb 26, 2009 | Lexmark T644 Laser Printer
LEXMARK T644
Make sure that the toner is not leaking and check your connections from the HVPS. If they look good I would replace the printhead.
Roger
Sep 10, 2008 | Lexmark T644 Laser Printer
Lexmark T640 Laser Printer Logo
66 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
