Question about Sharp AL 1631 Copier
Error u2 on al1631 - Sharp AL 1631 Copier
  • Sharp Expert
  • 337 Answers
The U2-40 error can possibly be cleared. Press P, *, C, * to enter the service simulation. Enter 16 using the keypad, then the Copy Start button. Press Execute on the screen. Replace the toner cartridge if the error persists.
Posted on Jan 30, 2013
Hi I have problem with my photocopaier. Sharp ARM236. It shows Code: U2-40
U2-04 EPROM error
U2-11 Main counter error
U2-12 EPROM error
As you can see there are many U2 error codes. Needless to say, find your code and the replace the bad part. The battery is on the main board. The EPROM is on the main board.
If you find your code, replace the part and error still remains -- replace main board.
Aug 07, 2011 | Sharp AR-M237 Copier
U2-40 error on sharp AR-M207 displayed on the digital display... what do i do
U2 04 EEPROM serial communication error
11 Counter check sum error
12 Adjustment value check sum error (EEPROM)
40 CRUM communication error
this the U2 Code Error
Jun 09, 2010 | Sharp AR-M207 All-In-One Laser Printer
Error code u-2 solution
U2 00 EPROM error 11 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication error
U2 04 EPROM error 11 Main counter error 12 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication errorYou need the service help. It is no a distans work Good luck)
Mar 14, 2010 | Sharp AR-5320 Black and White Copier
Al1631 sharp copier
This is called error code which you must specify.For H2,H3,H4, use command 14, for U2 use comm 16.Please specify if neither of this displays.
Oct 02, 2009 | Sharp AL 1631 Copier
ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code U2 on a AR201 copier
Hello sir; This error code it can be reset folloe the instruction;
1, press "clear", "interupt", " 0 ", "interupt"
2, enter 16 then press start.
Jun 01, 2009 | Sharp AR 201 Copier
U2 PROBLEM blinking U2 and will not print
U2 RAM error
U2-00 EPROM error
U2-01 Counter error
U2-01 Memory back-up battery dead
U2-04 EPROM error
U2-12 EPROM error
Feb 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
U2 error code
Hi there, Error U2 -
Possible Causes - Loading
Check loading to ensure no items extend
beyond the height of the drawer.
Good Luck!
neo
Dec 28, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
To find out the sub code for the U2 error hold down the Start key. Below is a list of the errors:
U2-04 EEPROM serial communication error
U2-11 Counter check sum error
U2-12 Adjustment value check sum error (EEPROM)
U2-40 CRUM communication error
To clear the U2-40 error try pulling out the toner cartridge and firmly reinstalling it. If that doesn't work you must install a new toner cartridge. There is a CRUM chip on the cartridge that keeps up with how many impressions have been made with that cardridge. You cannot "refill" these cartridges without replacing the CRUM. This problem occurs frequently with remanufactured cartridges.
To clear other U2 errors you must enter simulation mode.
Perform the following procedure to enter the simulation mode.
Clear key - Interrupt key - "0" key - Interrupt key - 16 - Start key - Start key. The unit should reset.
Nov 11, 2008 | Sharp AR 201 Copier
Sharp AL 1631 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
