Question about Toshiba Portege S100-S1133 Notebook
How to boot toshiba portege z830-104
Product has bios password also,i want to install windows 7
PAeasop
  • 17 Answers
SOURCE: Toshiba Portege S100 Bios password
Nedacqua,
The only way to obtain the response for the challenge code is to send your unit to an authorized repair facility. I work at the depot repair facility in Lou.Ky. And we have to send a request to Japan or California to get the response code.
PAeasop
Posted on Apr 25, 2008
SOURCE: Built in HDD Password for Toshiba Portege S100-S1133
remove the rtc battery it's look like a bateery on the organizer its round and flat remove it then disconnect to remove the password
Posted on Feb 16, 2009
wireman101
  • 61 Answers
SOURCE: Bios password for toshiba laptop needs reset
Try This: Resetting a Toshiba BIOS Password KeyDisk will reset the BIOS password on Toshiba laptops.
Older Toshiba laptopsmag-glass_10x10.gif can be convinced to boot without their power-on BIOS password by attaching a dongle to the parallel port which crosses a number of the pins. The pin out is:
Pins 1-5-10 2-11 3-17 4-12 6-16 7-13 8-14 9-15 Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
Posted on Mar 17, 2009
toesnose
  • 21 Answers
SOURCE: damage bios for toshiba portege 3440ct
If you didn't get a maintenance disk with the PC contact the manufacturer's support. They sometimes put a backed up copy on the hard drive itself, if this is the case they will be able to tell you how to access it =)
Posted on Jul 15, 2009
  • 366 Answers
SOURCE: Can't boot from USB (No CD Drive) for fresh install
Tricky one, ive you have a external usb cdrom drive , maybe, or if you can take hardrive out and set it up on another laptop install your xp and also place copy of all drivers required onto it, then put back into the toshiba., dont know what else could help you here. hope this helps in some way.
Posted on Dec 05, 2009
Testimonial: "Thanks, I am in between places for USB cd. I'll just wait for that and switch drives as a last resort for now. Thanks."
Remove password bios toshiba portege m400 please!
Here is a guide toremove windows passwordwith Windows Password Recovery Tool Professional from http://www.windowspasswordsrecovery.com/Step1: Download and install Windows Password Recovery Tool.
Step2: Burn CD/DVD/USB Flash Drive. (Namely it is to burn a Windows password reset disk.)
Step3: Set the target computer boot from CD/DVD or USB.
Step4:Remove the forgotten Windows passwordwith the burned CD/DVD/USB. Then log on to Windows without a password.
Of course, you can also finish Windows password remover if you have a password reset disk in advance. That's also an easy solution.
Source: http://www.windowspasswordsrecovery.com/windows-password-remover.htm
Aug 13, 2012 | Toshiba Portege M400 PPM40U01000E Tablet...
Hi I have a toshiba portege m750 and my little brother was using it and I have decided to use it for college but the only thing is he cannot remember I was just wondering how would I go about changing the...
You can set a user password from inside Windows. From the configuration panel look for an icon that represents two persons and click on it. Follow instructions on setting a user password.
You can also set a password on boot but you have to be careful: If you forget it you cannot open the tablet to remove the password. You will need to take the computer to a Toshiba Certified Service Center.
To set the password on boot you can use the BIOS SetUp configuration or a Toshiba Windows applications (HRWset).
For Windows XP tablet PC edition 2005
If you have the CrossMenu application you can run the HRWsetup from there. You can also go to All programs, Toshiba Utilities and look for HRWSetUp.
For Windows Vista or Windows 7, the name of the application may be Toshiba Security Assist.
Be very careful. You must not lose the password
Jul 30, 2011 | Toshiba Portege M700-S7002 Tablet PC
Cant boot up my toshiba lap top. it comes up asking for the BIOS password then shuts down after 3 tries! have tried all the F keys, shift key and removing battery!
the only way to get past the bios password is to open up the case and try to find a jumper on the main board that says bios reset, close that jumper and turn on the computer for one boot, power down and remove the jumper, after that the bios should be reset(bios passwords are usually set as a security measure that is not easy for the average user to bypass such as a windows one that can be removed by formatting the drive and reinstalling windows)
Jan 22, 2011 | Toshiba Portege S100-S1133 Notebook
How to reset the boot password in toshiba portege a100 laptop
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Mar 08, 2010 | Toshiba Portege S100-S1133 Notebook
I forget my administrator password. please help me
It is said that Windows Password Recovery Tool is the best Windows Password hacker expecially on Toshiba computer. It takes only 4 minutes to hack computer password
More interest, feel free to read this helpful post:
http://www.windowspasswordsrecovery.com/hack-computer-login-password.htm
Jan 11, 2010 | Toshiba Portege 3505 Tablet PC
Dec 05, 2009 | Toshiba Portege 7100 Notebook
Toshiba Portege 3500 Win Xp Bios password - How Can I flash bios?
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.
After that use the patch
Mar 08, 2009 | Toshiba Portege 3500 Tablet PC
Feb 14, 2009 | Toshiba Portege S100-S1133 Notebook
Toshiba Portege S100-S1133 Notebook Logo
372 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
