Question about Fisher and Paykel WL26CW2 Top Load Washer
New fisher and paykel washer WL26CW fault code 245
Brand new washer today and tried to run the first load.  After about 15 minutes, I get the fault code 245.
  • Anonymous Mar 24, 2014
    WL80T65CW1 Fault code 10, have just installed a new controller module
    New Friend:
Be sure it is not the motor control assembly. If you receive a fault code 245 at the time of the rinse cycle. Shut it off and restart it from the beginning as if you at starting a new load. If you receive a fault code 49. Unfortunately, it is the motor control assembly. $200. That was my problem.
Posted on Jan 28, 2013
The drain pump impeller is seized; you just need to turn it a bit and will work just fine afterwards.
Posted on Mar 26, 2010
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ... > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Thank you very much, you just saved me big money! The wife thought we needed to...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Jan 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Fault 9 flashing on wl26cw fisher and paykel washer
Fault 9 LAH HIGH CURRENT FAULT The low ambient heater is drawing more current than expected. Either the heater or wiring is faulty.
Primary Action
- Check the wring and connections at both heater and power module.
Secondary Action
- Check heater resistance. If not within limits replace heater.
Aug 03, 2014 | Fisher and Paykel WL26CW1 Top Load Washer
How to unlock the door
Is this unit brand new or has it been run before. Make sure the cycle is finished and power is off should open up. I if not unplug unit wait about a minute and then plug in again then try. Reset any fault .then try.
Aug 02, 2014 | Maytag Neptune MAH6500A Front Load Washer
What is the service code # 245
AquaSmart Error codes
Your pump has items jammed in the impeller.
Jan 05, 2013 | Fisher and Paykel GWL11 Top Load Washer
Sand in fisher and paykel washing machine error 245
This is a pump stall error code. Remove the pump from bottom of washer. make sure nothing is clogging pump. If problem persists replace pump.
Oct 27, 2012 | Fisher Paykel Washing Machines
Open Questions:
See all Fisher and Paykel WL26CW2 Top Load Washer Questions
Fisher and Paykel WL26CW2 Top Load Washer Logo
1,287 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
