Question about Water Sport
Can I remove my fins on my paddle board? - Water Sport
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
The fins can be easily removed to transporting the paddle board, however they are used for navigation of the water so you should not try to paddle board without the fins attached.
Posted on Jan 17, 2013
I am searching for a fin for my Pathfinder Inflatable Kayak
Won't happen. Steer your kayak with paddles or learn to do that.
Aug 11, 2014 | Pathfinder Ii Two Person Inflatable Kayak
How should I choose the size of my paddle board?
Paddle boards come in three sizes 10ft, 11ft and 12ft, the size is determined by the weight of the person and how many paddles there will be as well as how far the paddler wants to glide between paddles. Normally a person weighing less than 160lbs will choose the 10ft board and someone weighing over 160lbs would take the 11ft. If the paddler is heaver let's say 300lbs or they want to have more than one paddler they would take the 12ft board.
Jan 17, 2013 | Water Sport
Is it better to have a board with attached fins or ones that I can remove?
That depends on two factors. You have to determine if you want a different type of board for each different type of wave so that you can cater the board to the wave. Also, if you are travelling a lot to different surf destinations, I suggest getter a board with removable fins because it is less likely to get damages under the plane and you can store the extra fins in your luggage.
Jan 14, 2013 | Water Sport
A/c not blowing through vent only defrost and floor.what to look for fix. thank you
GM used an electronic air door actuator on many models to direct the heat and AC for defrost, floor, dash vents, etc. The actuator, which is a small stepper motor attached to a plastic paddle or fin, gets weak with age and use, and the paddle itself can bind or jam. The part is under/behind the dash, and in most cases involves removing the radio, climate control unit, and several plastic panels to access. Allow 3-4 hrs minimum if you have not replaced one before.
Jun 21, 2010 | 1999 Buick LeSabre
HOW DO I CHANGE THE FINS ON MY FRONT LOAD WASHER?
open up the top cover and the front,then the rear access panel,remove the drive belt,then the spinner pulley,then you can push the drum and spline shaft out the front to replace the baffle/paddles,i would replace the lip seal if you remove so as to protect the drum drive bearings
Mar 23, 2010 | GE Washing Machines
Fin inside came off
remove toe kick panel screws by the floor and lift upward on front cover and pull upward to remove like lifting a car hood,then there are screws just inside the bottom side of the top cover,remove these and tip top back and secure top as to not break off electrical connections off control panel,then you can access the screws for the paddle fins to re-secure to the drum,if they're oblong from wear and tear either replace or fill the hole with a cement for this purpose and put in 2 match stick pieces (quickly)before glue sets and this will take up slack and seize paddle screw all in one
Jan 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
MDE7600AYW Atlantis Dryer -paddle inside dryer is coming loose
You will need to take the back panel off use a 1/4 in socket driver.Then you should see the drum.
Len
Feb 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Sep 12, 2007 | Washing Machines
Water Sport Logo
515 people viewed this question
Top Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
