Question about Minolta Maxxum 400si 35mm SLR Camera
Minolta Maxxum 400si "help" on screen
I tried taking a pic with a very low F stop and -0s shutter speed, it took way to long to snap the pic and now the screen says Help...I took the bat. out and put it back in and it took one pic then the "help" message came back again...What the f is wrong with my camera, i think i'm gonna have a heartattack
  • Anonymous Nov 13, 2007
    Nessie:
    Did you ever get an answer for your problem? Now my camera is doing the same thing. When I look through the view it is now dark and when I was able to take a picture I now also get the "HELP" on the display screen. Took out and replaced the battery. Still no luck. Maybe it's time to go to digital.
    Robert
    Los Angeles
  • 667 Answers
It is a common problem on these cameras. The gear assembly inside the camera body has failed and needs replacement. $$$
Posted on Dec 30, 2007
6ya staff
SOURCE:
Slow snapping picture
I am not sure, but have you played with the camera manual setting ?
if you did
you should change the shutter speed to a higher level (if you have used the manual mode)
but if you use the automatic mode and the light around you was low the shutter speed will be automatically low so the camera could give you a better picture be lowering the shutter speed so it could have the enough time to collect the light (that's why the snapping is slow)
so try to increase the iso or the av (lowering the av's number)
hopefully, I have helped you
Mar 06, 2014 | Minolta Maxxum 400si 35mm SLR Camera
Minolta Maxxum 400si is locked up
link to your manual, it tells us that we have a winding motor problem, I would do as you have done, so I would ensure that batterys are in great shape, the only other thing I could suggest is to try to turn the winding motor by hand in case it is just locked up. Failing that I presume the motor has died and needs replacement.
Dec 05, 2007 | Minolta Maxxum 400si 35mm SLR Camera
What is an ISO or ASA? where is it on my Minolta Maxxum 400si
There should be a button that says ISO on it, or just a set of arrow buttons. ASA/ISO are the same thing, and indicate the speed of the film being used. 100/200/400/800/etc. Not setting the camera to the proper setting will result in dark or light images.
If you can't find your ISO setting, try searching Google for your model and you should be able to find a pdf download of your manual for free.
Aug 24, 2011 | Minolta Maxxum 400si 35mm SLR Camera
Is it possible to manually control the shutter speed, aperture, AND the focus on the Konica Minolta Maxxum 400si SLR 35mm film camera? I need to be able to manually control these features for a film class...
Yes. You have full control over the shutter speed and aperture in the Manual exposure mode, as described in the "M Mode: Manual Exposure" section in the manual.
You also have full control over the focus, as described in the "Manual Focus" section in the manual.
If you need a manual, you can download it (in two parts) from
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html
Feb 07, 2011 | Minolta Maxxum 400si 35mm SLR Camera
Minolta Maxxum 400si 35mm Is this a good camera? My husband and I are thinking about buying one used for our daughter who wants to get into photography. We found what looks like a good deal but I don't...
The Miinolta 400 si SLR 35 mm is an excellent camera for a beginner as well as the seasoned photographer. It has a complete automatic mode for the point & shoot picture taker as well as manual modes if you want to favor shutter speed over aperature or aperature over shutter speed. I've had one for years and have gotten excellent results.
Dec 09, 2010 | Minolta Maxxum 400si 35mm SLR Camera
My Minolta Maxxum 400si film SLR seems to have a jammed shutter and the shutter curtains seem to be mis-aligned (this would be because of the previous owner, not me) but the bottom curtain actually seems...
With the shutter curtain out of place the camera will not function. If it is only out a little you may be able to persuade the shutter blades to fall back into position. If you bend them, or if they are out of the proper tracks then the camera will have to be sent to a repair service for repair.
Nov 23, 2009 | Minolta Maxxum 400si 35mm SLR Camera
Zmy Minolta Maxxum 35mm camera mirror is locked up
Sounds like the shutter or mirror assemble is damaged and needs repair. This is a major repair that a technician will need to preform.
Nov 20, 2009 | Photography
Only partial picture on frame
it could be a shutter problem. however if it is only when using a flash it would be sync. for flash photography most cameras have a shutter speed that they sync at normally 1/60
May 26, 2009 | Minolta Maxxum 5000 35mm SLR Camera
Film won't load on Minolta 400si Maxxum Camera
My daughter took the camera to her photography teacher he was able to load the film by wrapping more film around the roller. It's not as easy to load as my Canon. I thought we had put plenty of film around it already. Oh well, it's working anyway.
Feb 18, 2009 | Minolta Maxxum 400si 35mm SLR Camera
Minolta Maxxum 400si 35mm SLR Camera Logo
324 people viewed this question
Top Minolta Photography Experts
Ekse
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
