Question about HP Deskjet 3843 InkJet Printer
Why does my HP Deskjet 3843 paper keep jamming
My Deskjet 3842 printer keeps paper jamming
  • 34 Answers
SOURCE: HP 4200 printer paper jam. No paper is jammed
check this out....when the printer reports the jam, open the paper tray very carefully and slowly.
Has the paper moved at all forward? Has it moved like 1/4 inch to 1/2 inch out of the tray?
If so, you probabaly need a torque limiter, no tools, $10 or so and a very very easy fix.
POBCM is very correct when he points out that the block/stop in the back of the tray moves when the tray is closed with too much force and this is the #1 cause most of the time.
You may see a "41.3" code displayed if the block is not up to the back of the paper and the paper is not all the way forward in the trays, and under the two metal clips at the front of the tray.
Posted on Mar 14, 2009
SOURCE: HP 3915 paper jam error
I had the same problem and just talked with HP technician Neeta and she showed me how to fix it. It's a bit convoluted. In essence you have to clear the print spooler. Here is what she told me.
First you have to be clear that there really ISN'T a paper jam by printing a test message this back door way.
Neeta : The USB cable should be disconnected. Neeta: To print a self-test page, press and hold the Power button. Raise and lower the printer cover four times. Release the Power button, and the self-test page prints
If the sel-test page prints, this means you truly do not have a paper jam. Next, clear the print spooler
Neeta : The USB cable should be disconnected.Neeta : Now click on start->RUN.Neeta : Then type "services.msc".Neeta : Then it will open the services window.Neeta : Now please look for the option "print spooler. Neeta : Okay, now , please right click on the option "print spooler" and click on stop then click on start, 3 times.
Posted on May 04, 2009
  • 61 Answers
SOURCE: HP deskjet 1280 paper jam
Yes you can manually remove the paper. It can be pulled out from the feed area (pulled out backwards).
To clear the jam status....
Take the back cover off, there is a reset switch in the top left hand lock hole. Push a pen (or similar) into this hole, the switch will give slightly and be the same depth as the others.
put the cover back on, all should be well
Posted on Sep 11, 2009
Testimonial: "Thanks so much for your help - problem solved."
  • 685 Answers
SOURCE: my printer is a hp deskjet D1520 and it wont print
This video should help.
Posted on Dec 23, 2009
SOURCE: HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Posted on Jul 02, 2010
My hp deskjet 1000 j100 printer keeps jamming the paper
Don't load the paper tray 100%, HP printer usually jams when it's filled all the way.
Feb 28, 2011 | HP LaserJet 1000 Printer
How to reset hp deskjet 2360
HOW DO YOU RESET HP DESK JET 2360.iT KEEPS SAYING PAPER JAM,BUT THERE IS NO PAPER IN IT.
Jan 25, 2010 | HP Deskjet 2360 InkJet Printer
Paper jamming problems with HP DeskJet F380 All-In-One Printer . The paper feeds into the paper feeder but then it seems to get off line and the paper get stuck and actually tears in the feeder. The...
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Thanks
Newton
Aug 29, 2009 | HP DeskJet F380 All-In-One Printer
Paper jam in my printer
the paper sensor may have went in the printer try doing unplugging everything and plugging it back in
Jun 29, 2009 | HP DeskJet F380 All-In-One Printer
My Hp printer keeps saying "resume".
Do a complete reset.
1- Clear the printer queue.
2- Turn off the device.
3- Remove paper in the tray and possible paper jammed.
4- Remove ink toner.
5- Turn on the device briefly and turn it off.
6- Replace paper and toner.
7- Turn on!
Mar 27, 2009 | HP DeskJet F4280 All In One Printer InkJet
Hp deskjet 5150 paper jam
u have to need to do change the printer roller
Sep 01, 2008 | HP DeskJet 5150 InkJet Printer
Paper jammed
Usually tear drop means 'out of ink'
Apr 02, 2008 | HP DeskJet 5150 InkJet Printer
HP Deskjet 3843 InkJet Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
