Windows 98SE. Floppy & CD drives not working.
Get following messages:
D: is not accessible. A device attached to the system is not functioning.
A: is not accessible. The device is not ready.
  • 79 Answers
Possibly an IDE problem on the motherboard. Open up the PC and check the leads havent come out, there are 2 - a ribbon cable and a power lead. It could be the power supply is faulty. This is unlikely Windows more likely hardware. Does BIOS detect the drives as it loads?
Posted on Jan 25, 2009
Get message:Bootmgr compressed Press Ctrl+Alt+Del to continue. I did this and get the same message back. How do I get the PC running again??
first check the boot drives to make sure that the computer is not trying to boot from a different drive to the one that contains Windows.
check that there are no CDs or DVDs 3 1/2 inch floppy discs
in the CD/DVD,3.1/2 floppy drives ,and no removable usb drives plugged in to the usb ports
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
don
Feb 19, 2011 | Computers & Internet
My ABIT sg-72 motherboard boot attempt from HDD says "NTLDR is missing". The only Enabled boot device is HDD. If I change boot device in setup to CD (Windows XP distr disk), that boots up and...
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
don
Feb 13, 2011 | Abit SG-72 Motherboard
Cool max cd-350-combo does not reconize ide drives when connected to pc. System acknowledges that a mass storage device is present but does not show in my computer or disk management (so ya cannot change...
Don't know if you've solved this problem, but I was having the same issue using Windows 7, 64bit. It had been working but Explorer crashed & Explorer restarted, it recognized the device, but I couldn't access the files. I tried it on another laptop & it worked. So I left it plugged in & restarted the computer and that fixed the problem. If that doesn't work, you may have to uninstall the driver that windows automatically installed for it & then plug it back in & have windows reinstall the driver. Good luck.
Sep 12, 2010 | Coolmax CD-350-COMBO (CD350COMBO) Infrared...
How do i format my laptop off of the partition on the hard drive. I've managed to hit f 10 and get into the bios but no format option was given
Formatting the hard drive is not a function of the BIOS. You will need to boot the machine from either the Windows CD and do a fresh setup (which will give you the option to format the hard drive) or boot from a bootable CD or floppy disk that has the format command on it. From there you execute the format command and follow the directions.
Jan 05, 2010 | Sony VAIO Notebook
Dell Inspiron 8200 won't continue start up
This stop error means that your ntfs file system is corrupt (damage in the file system, bad hard drive data, corrupt SCSI or IDE drivers or a corrupt ntfs.sys file).
How do resovle the problem.
There are two ways,
1, If you still can access Windows, try to disable any backup programs, virus scanning programs or disk defragmenter tools. Try also to run a hardware diagnostics tool to detect any errors your hard drive might have. And run chkdsk /r to detect and repair any file system structural damage.
2, If you are unable to load Windows. Then you should try to access your ntfs partitions by making a ntfs boot disk with NTFS4DOS (freeware). You can download it from http://www.geekswhoknow.com/files/ntfsinst.exe You will need a floppy disk.
After you load the bootable floppy disk onto your damaged system, select either option one (1) or option three (3). If you selected option one (1), type chkdsk /r at the command prompt, and your problem should go away after the disk has been repaired.
Note! Unfortunately there is a chance that your partition is corrupt beyond repair and all of your data is lost. In that case, you need to reformat the partition to be able to use it again.
Additional information can be found at http://support.microsoft.com/default.aspx?scid=kb;en-us;Q228888
Aug 10, 2009 | Dell Computers & Internet
Wiped clean cannot reload windows
Are you using a floppy or a disc? Your CD rom or disk may be faulty. If you have another copy and/or another cd rom drive try that. Also reseat the memory sticks. Lastly it all of this fails your hard drive may be the culprit...
Apr 20, 2009 | Acer Power FH PC Desktop
I need windows 98 instalation dump or vedio
Ha! That's the first OS I ever reloaded.....ah, memories.
I most certainly can help you with this.
Here's what you need to get:
Windows 98 boot floppy from here - http://www.bootdisk.com/bootdisk.htm
(you need to know which version you are installing, Windows 98 or Windows 98SE)
Windows 98 or 98SE OEM CD
You will need to boot from your floppy disk first and format the hard drive which will prepare it for windows, then use it to boot your computer to the cd and the process will begin.
Here are some more detailed steps, the above is only in a nutshell:
http://support.microsoft.com/kb/221829
That comes straight from Microsoft. Let me know if that helps you!
Mar 14, 2009 | Microsoft Windows 98 for PC
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
Installation
You need to use floppy disks (called boot disks) to boot DOS with cd-rom drivers, because the win98 cd isn't bootable by default.
I suggest you to go to http://www.bootdisk.com/bootdisk.htm and grab the respective windows 98 boot disk.
You will need a functional computer to write the disk image into the floppy.
After that put the boot order in BIOS as floppy first.
Once you see DOS prompt A:\> just access your cd-rom drive like d: or e: and then type install
WaZZie
Jan 04, 2008 | Microsoft Windows 98 for PC
Acer Aspire 3610 laptop - Windows XP error
on a friend's Windows 98 SE or Windows ME computer, create a floppy "Startup disk". Insert in your pc floppy drive and turn on. If floppy drive was not accessed, then get to BIOS and ensure "Boot from floppy drive" is set prior to "boot from hard drive". Once at first screen, select "Boot with CD-ROM driver". Insert CD-ROM and initiate entire re-install of Windows. Windows may do some self-restarting. At first restart do this: get to BIOS and ensure "Boot from hard drive" is set prior to "boot from floppy drive".
Jun 05, 2007 | Acer Aspire 3610 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
