Question about OKI C9600n Led Printer
OKI C9600 131:fatal error?
OKI C9600 131:fatal error how doI correct this?
Soulvisitor
  • 1113 Answers
SOURCE: oki c5200 "Fatal Error 106"
from your service manual....main board issue
Posted on Jan 16, 2008
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
  • 97 Answers
SOURCE: oki c9600 fatal error 175
Error 175
Fuser Thermistor
short-circuit or Open
is detected (High
Temperature (HOT)
or Low Temperature
(COLD))
Turn ON power again.
Leave in that state for 30
minutes then turn ON power
again.
Posted on Mar 29, 2010
SOURCE: OKi C5800ldn 231: fatal error 03
I have the Oki 5650 which had been great for about 18 months. Then found that the C cartridge was showing error as 'not installed'. After much fiddling about with it and checking on the internet I can now rectify this by either pushing down on the top of the printer while it boots up, or removing the small chip on the left top of the toner (make sure you have 'earthed' yourself to prevent any static damaging the chip when you handle it!) and taping securly onto the top of the cartridge above the chips proper slot. This now has been working OK for 6 months. Strange how this only affects the C cartridge (which has also been replaced and had the same problem). I suspect that the printers RFID chip reader for the C cartridge is having problems reading the chip and moving the chip closer to the reader by either taping to the cartridge top of puching on the top cover while printer boots up resolves the problem (for now anyway!) This can also trigger the 'service call 231 fatal error 03' message which also disappears if you follow the above procedure.
Hope this helps you.
Posted on Jul 27, 2010
Oki c7300 Fatal Error
all oki errors are fatal errors, there will be a 3 digit number that will tell what the error actualy is
Jun 02, 2014 | OKI C7300 Led Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Fatal error 122 on a oki c5200 printer
YOUR DRIVER CD IS CURREPTED.ANOTHER DRIVER CD USE.
Jun 23, 2009 | OKI C5200n Laser Printer
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Okie C5400 giving 162: Fatal Error
This is a Toner Sensor Error, Color:Cyan
and can be corrected by checking that the Cyan toner lock lever is correctly in position.
Mar 19, 2009 | OKI C5400n Led Printer
Fatal error 980 OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
Oki 9800 fatal error 230
No reset need to fix fault then clears...
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Dec 07, 2007 | OKI 9800hdn Laser Printer
Oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
OKI C7300 Printer
moz-screenshot-1.jpg Unfortunately it's a Hardware problem.
If you bought it from a dealer, contact them.
Error 020
When an error has occurred in the controller board (CU) or the program Rom.
Resolution:
Replace the Rom Dimm, see chart below for the correct part number. If the Rom Dimm does not correct the issue, then replace the (CU) controller board. Please refer to the service manual for (CU) part number depending on the printer revision
Dec 01, 2007 | OKI C5300n Led Printer
OKI C9600n Led Printer Logo
180 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
