Question about Football
What is a football helmet made of? - Football
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 39 Answers
When helmets where first introduced into Football they were made from hard leather. Now plastic or composites such as fiber glass are used as they are light weight and are able to withstand certain amounts of force by distributing the impact.
Posted on Jan 17, 2013
Can a bullet be dropped from a UAV as a weapon?
First, a dropped bullet would not have the energy to penetrate a helmet. second, even if it did theres no way to aim it. a shot bullet is traveling at high speed and is stabilized in flight by spiraling like an american football. a dropped one would tumble and be subject to wind. i do not think the tech is available to make a bullet steerable. the guided projectiles available are all much larger caliber, usually fired from Howitzer cannon.
Jan 04, 2017 | Military
Tip
Choosing the best climbing helmet for your head
Rock climbing is a very fun hobby but it can also be very dangerous. Wearing a helmet when you climb can be a life saver, but it is important
that you make sure that you are wearing the right helmet both for the
activity you are performing and for your head.
When it comes to selecting the right type of helmet there are two main types to choose from, suspension and sponge. The suspension helmets are very similar to a construction helmet, its a hard shell with a netting on the inside.
These are really great for vertical dropping objects but they tend to be a little heavy. The other type of helmets are the foam helmets. These ones are made out of a lighter-weight polystyrene or polypropylene foam with a hard shell over it. It works by absorbing the energy of the of the falling object in the plastic and will deform the foam permanently. The durability of the helmet depends on the thickness of the shell, but because the impact on the helmet permanently damages the helmet it may not be very effective for extensive use.
After you have chosen the type of helmet that you will be using, its time to head into making sure that you have the right fit for your helmet. Keep in mind that you
will be more likely to use a helmet that fits correctly and is comfortable, before buying you should test out the helmet like you do with a pair of shoes. Many of the top climbing stores will allow you to try on and test out the helmet to make sure that it fits properly.
There are two main features that you have to pay attention to when trying on and picking out the right fitting helmet, they are adjustability and the chin strap. You start by placing the helmet on your head with it straight on your head making sure that you don’t tilt the helmet because you have to keep your forehead protected. Next you want to shake your head from side to side, does the helmet move? If it does then you want to either look for a different size helmet or if you can adjust the straps on the inside of the helmet so that it fits snugly. Then buckle the chin strap, it should fit snugly on your chin and form a Y shape
around your ears. There should not be any slack in the straps and if you
wear a pack make sure that you can lift your head to look up while
wearing the helmet.
A few side notes to keep in mind when considering the helmet you want to get. If you are going to be climbing in a very hot or very cold climate when you buy the helmet make sure to take your headscarf or hat with you so that you get a helmet that fits with them underneath. Where you are going to be climbing can also have an impact on the helmet that you will buy, if you are going to be
climbing in a cold climate that has ice you will want to get a solid helmet that will protect you from falling debris, while if you are going to be climbing in a warmer climate you will want to get a helmet that has air vents to allow for air circulation.
on Jan 16, 2014 | Rock & Ice Climbing
WHAT KIND OF PAINT DO I USE TO PAINT A FOOTBALL HELMET?
Clean well/ dry completely. Lightly sand with a fine grade of sandpaper, apply either Fusion" spray paint by Sherwin Williams (Krylon) . It does a great job sticking to plastic without primer, and also has a durable finish. The finish is glossy, but not with much depth. To achieve that deeper wet look, add a coat or two of Krylon's Gloss Polyurethane.
Oct 09, 2014 | Tools & Hardware - Others
I ask a question but no answer
When asking a question make sure you provide enough details for experts to have all the information they need to answer your question.
Hope that helps!
Jun 09, 2014 | SS Decals Before You ask the answer is No...
What is a cup used for in football?
A cup is to protect football players genitals from injury during rough games of American Football.
Jan 14, 2013 | Football
What is the best helmet in halo reach
Haunted helmet
is the pilot helmet but opened revealing a face which is a skull
can be achieved by unlocking all base helmets and reaching inheritor rank
Oct 10, 2011 | Microsoft Xbox 360 Console
The Grab Hold is loose on one end of passenger front door.
put on a football helmet then disconnect the battery for about 15 minutes. remove panel tighten handle reconnect battery, start car and last but not least remove your helmet
Jul 20, 2009 | 2000 Lincoln LS
Is it true you don't wear a toque if you wear a snowboarding helmet?
I have a helmet and I don't need a hat under it. The helmet is quite warm. They also usually have vents to open for those warmer days.
Dec 01, 2008 | Dual Electronics Lightweight Polyurethane...
How to fit a snowboard helmet?
"Getting the right fit is the most important factor to consider when buying a Snowboarding Helmet: 1. Measuring Tape. Your helmet size is determined by the circumference of your head. Wrap a measuring tape around your head to get your helmet size. 2. Align the front of the helmet above your eyebrows and hold both straps until the helmet fits well. 3. Make sure there are no unwanted gaps between the helmet lining and your head. The back of the helmet should not touch the back of your neck. 4. The helmet should fit snug and nicely. 5. Try one of your favorite pairs of Snowboard Goggles and make sure they fit properly on your helmet. Please note that the producers of helmets all have different ideas on the shape of a human head. Although the size might be right, the shape of the helmet might be different from the shape of your head."
Snowboard helmet safety rating
"Snowboarding and Skiing Helmet Safety Standards Snowboarding Helmets should have a CE, ASTM or Snell RS-98 certification. ASTM standards have been determined by a series of tests on helmet models, including testing the strength of a helmet's retention system under simulated hot, cold, and wet conditions. "
Football Logo
706 people viewed this question
