Question about Dell Inspiron 530 Desktop Computer
How to restore factory settings on a dell inspiron 230 using disk
System restore gives error message access to tools denied. Have been told this can be done from from a disc supplied with the pc but not sure how.
  • Dell Master
  • 1,824 Answers
if you want to reinstall OS:
Insert the disk, it should automatically open the install.exe thing and you'll need to follow the instructions.
if you want to restore the computer to factory settings and reinstall OS:
turn off your PC
keep pressing the key for boot menu it's F8 or F12 or F11 depending on the PC's manufacturer.
Then there will be either a boot menu or a "Do you want to do a system restore":
a) system restore, keep pressing the key and it will load. Then follow the instructions
b) if it's boot menu, insert the disk, and then select the option which says to load from the CD/DVD. Then follow the instructions.
NOTE - PLEASE BE CAREFUL, IF MAKE ANY MISTAKE, COMPUTER MAY NOT RECOVER.
Posted on Jan 17, 2013
  • 136 Answers
SOURCE: Dell Optiplex GX150 Factory Settings Restore Partition...
This is from the Dell support site. You were correct in pressing ctrl+f11 but perhaps you did not press at the correct time. If in following these first two steps you do not get the recovery console, it may not have been installed on your computer.
1 Turn on the computer.
2 When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
3 In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.
4 When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
5 Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
The software is now installed as it was when the computer was first received.
Posted on Dec 10, 2008
dapidc
  • 111 Answers
SOURCE: how do i restore my dell back to factory settings
If you mean BIOS setting, then enter the BIOS, choose Restore Defaults.
If you mean your windows installation, use the Operating System reinstallation CD from DELL (the green CD, for Windows XP). After operating system installed, use your driver CD (usually the blue CD from DELL). If you don't have the CD, please contact Dell support center to get the CD (charges may apply).
Posted on Dec 27, 2008
diverseworx
  • 8 Answers
SOURCE: restore for dell dimension b110 without disk
Boot the computer, as soon as the blue Dell bar comes on the screen press CTRL+F11 this will take you to the Dell Restore. If that does not work you can request a backup CD from Dell here(one CD only):
https://support.dell.com/support/topics/global.aspx/support/dellcare/en/backupcd_form
Posted on Mar 06, 2009
jepito
  • 216 Answers
SOURCE: I need to restore my dell dimension c521 back to
as soon as you turn the computer on hold down the CTRL key and press F11 try this
Posted on Sep 03, 2009
  • 1043 Answers
SOURCE: how to restore a Dell inspiron 530 to factory
CTRL F11 should launch your restore partition for you.
Posted on Sep 17, 2009
When i try to open my c drive in a dell inspiron laptop computer, it gives an error message that access denied. what might be the problem?
It isn't a problem it is for the safety of the Operating System. Access is usually denied because you are not an "Administrator".
Feb 18, 2012 | Dell Inspiron 15 1545 Notebook
How do I reset to factory settings without the disk
In order to reset your computer to Factory default settings without the disc, you can follow the instructions below.
1. Turn on your computer. Once you see the DeLL Logo Press and Hold the CTRL button then while holding CTRL button, press F11
2. You should see the Dell PC Restore by Symantec application.
3. You can click Restore and Confirm the restoration.
4. It will take 10-15 minutes. Once your computer rebooted, it should already be in the default settings
Apr 04, 2011 | Dell Inspiron 1501 Notebook
How to repormat a laptop
Before reformatting the pc you must back up necessary files and applications that you might have. Because during the process all files would be deleted and pc would be back to its factory default. You may follow the steps below to reformat the pc.
1. Turn on the computer. When the Dell logo
appears, press <F8> several times to access
the Vista Advanced Boot Options Window.
2. Select Repair Your Computer.
3. The System Recovery Options window
appears.
4. Select a keyboard layout and click Next.
5. To access the recovery options, log on as a
local user. To access the command prompt,
type administrator in the User name
field, then click OK.
6. Click Dell Factory Image Restore. The Dell
Factory Image Restore welcome screen
appears.
NOTE: Depending upon your configuration,
you may need to select Dell Factory Tools,
then Dell Factory Image Restore.
7. Click Next. The Confirm Data Deletion
screen appears.
NOTICE: If you do not want to proceed with
Factory Image Restore, click Cancel.
8. Click the checkbox to confirm that you want
to continue reformatting the hard drive and
restoring the system software to the factory
condition, then click Next.
The restore process begins and may take
five or more minutes to complete. A message
appears when the operating system and
factory-installed applications have been
restored to factory condition.
9. Click Finish to reboot the system.
Operating System Reinstallation
Before you Begin
If you are considering reinstalling the Windows
operating system to correct a problem with a
newly installed driver, first try using Windows
Device Driver Rollback. If Device Driver Rollback
does not resolve the problem, then use System
Restore to return your operating system to the
operating state it was in before you installed
the new device driver. See "Using Microsoft
Windows System Restore" on page 38.
NOTICE: Before performing the installation,
back up all data files on your primary
hard drive. For conventional hard drive
configurations, the primary hard drive is the
first drive detected by the computer.
To reinstall Windows, you need the following
items:
• Dell Operating System media
• Dell Drivers and Utilities media
Restoring Your Operating System
NOTE: The Dell Drivers and Utilities media
contains drivers that were installed during
the assembly of the computer. Use the
Dell Drivers and Utilities media to load any
required drivers. Depending on the region
from which you ordered your computer, or
whether you requested the media, the Dell
Drivers and Utilities media and Operating
System media may not ship with your
computer.
Reinstalling Windows
The reinstallation process can take 1 to 2 hours
to complete. After you reinstall the operating
system, you must also reinstall the device
drivers, virus protection program, and other
software.
1. Save and close any open files and exit any
open programs.
2. Insert the Operating System disc.
3. Click Exit if the Install Windows message
appears.
4. Restart the computer.
5. When the DELL logo appears, press <F12>
immediately.
NOTE: If you wait too long and the
operating system logo appears, continue to
wait until you see the Microsoft® Windows®
desktop; then, shut down your computer
and try again.
NOTE: The next steps change the boot
sequence for one time only. On the next
start-up, the computer boots according to
the devices specified in the system setup
program.
6. When the boot device list appears, highlight
CD/DVD/CD-RW Drive and press <Enter>.
7. Press any key to Boot from CD-ROM.
Follow the instructions on the screen to
complete the installation.
manuals are here http://support.dell.com/support/edoc...5/en/index.htm
Mar 23, 2011 | Dell Inspiron 1525 Laptop
How to restore my laptop to its factory settings
Proir to restoring computer devices, ascertain that resources that would require backup is securely preserved. For example, computers loose resources least complented by the manufcturer with restoration to factory settings. Also significant is consulting with technician to ascertain the condition of device that least require facory settings. Usually a condition is resolvable with an alternate means least requiring factory settings. Prior arrangments that make restoration attainable includes acquiring the tool resources either as disk roms that contain programs. Usually the computer manufacturer would have provided the restore resources either as disk roms either CD or DVD. Recent computers however have built in programs restore media in which instance restore is possible without disk roms materials. Depending on the condition of the computer considering recent innovation would either require disk material to attain restore or builing functions. Usually refering to the computer support experts with conditions that are encounted would attain means to resolve.
Feb 19, 2011 | HP Mini 210-1030NR Netbook
How do a complete factory restore on dell inspiron 1525 when after f8 it says unable to locate file?
Dell.com supply "rescue disks" as do many sites on the net. I think that is possibly the only way to go.
Errors on the hard drive possibly caused the error in the file system, or the master file table has been corrupted.
Hope it helps.
Jan 02, 2011 | Dell Inspiron 1525 Laptop
All i want to know is HOW DO YOU REBOOT A DELL INSPIRON 1545 TO FACTORY SETTINGS I DON'T HAVE THE MONEY TO TAKE IT IN.
Windows Vista: Dell Factory Image Restore
  1. Turn on the computer. When the Dell logo appears, press several times to access the Vista Advanced Boot Options window.
The System Recovery Options window appears.
  1. Select a keyboard layout and click Next.
  2. To access the recovery options, log on as a local user. To access the command prompt, typeadministrator in the User name field, then click OK.
  3. Click Dell Factory Image Restore.
note.gif NOTE: Depending upon your configuration, you may need to select Dell Factory Tools, then Dell Factory Image Restore.
The Dell Factory Image Restore welcome screen appears.
  1. Click Next.
Nov 09, 2010 | Dell Inspiron 1545 Notebook
I want to reset my PC to factory settings and delete evreything on the hard disk before giving it for recycling, what is the best way to do that? The pc is an old DELL inspiron.
The best way to do this is to format your disks (other than C:) and then use a Windows Installation Disc to format your C: partition.
Jul 24, 2010 | Dell Inspiron 8600 Notebook
I want to restore my dell laptop to factory settings
you can try to restore your PC from start<-all programs<-accessories<-system tolls<restore
-Choose the earliest date that your want your PC to restore back to.
Hope it helped
Mar 25, 2009 | Dell Inspiron 8600 Notebook
Dell laptop inspiron 1000
Put recovery disk in the CD drive. On reboot, hold down F12 key. You should get a choice of drives to boot from. Make sure the first two are in the correct order:
1. CD-ROM (optical drive)
2. HDD (hard drive)
then press F10 to save and exit.
Now the laptop should boot correctly from the recovery disk.
Jan 06, 2009 | Dell Inspiron 1000 Notebook
Dell Inspiron 530 Desktop Computer   Logo
51 people viewed this question
Alun Cox
