Question about Dehumidifiers
How to turn the temp up on air force wdh 730 eah
Need a manual please
Hi Klara, The link below is a free user manual for a "dehumidifier WDH-610HB-12R", The only thing is it's in english as well as 5 other languages Sorry......
https://www.stretchnow.com.au/image/data/20/seccoprof-el-manual.pdf
Mar 30, 2016 | Dehumidifiers
I have a idylis dehumidifier and a part that connects to the hose broke (part number WDH-1670EA) where can I purchase another one and what is the name for the part. Thanks
TERMS OF WARRANTY Plastic parts, are warranted for thirty (30) days only from purchase date, with no extensions provided. First 12 Months: During the first twelve (12) months, any functional parts of this product found to be defective, will be repaired or replaced, at warrantor's option, at no charge to the ORIGINAL purchaser. To obtain service: Call 1-800-643-0067 or RETURN TO THE STORE WHERE PURCHASE FOR REPLACEMENT. http://pdf.lowes.com/useandcareguides/840206120030_use.pdf
Jun 27, 2015 | Dehumidifiers
We just bought a new Friedrichs dehumidifier for our damp basement. The temp is reading 81 and the humidity 63 and it's been running for 2 hours. The basement is about 1000 sq feet and the outdoor temp...
Iris, all dehumidifiers generate some heat while in operation. However, it may be generating higher temps because of it's location. Dehumidifiers don't work well in temperatures below 65 degrees, In fact they struggle below that temp. Unless it's a Low Temperature unit, designed specifically for basement applications.
For example, the ambient air temperature never changes more than 10 degrees F throughout the year.
The air temperature at floor level (where the dehumidifier is placed) is colder then the air temperature at shoulder level. Raising the unit up off the floor onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a bull bucket of water, will generally solve the problem.
Be sure to clean the air intake filter regularly. At least once every 2 weeks. And wipe off the cabinet and the front louvers, when you change the filter. Always, turn the unit OFF & Unplug it, before removing the filter. Never operate the unit without the filter in place. Doing so could cause damage to the unit.
I hope this information has helped you and thanks for choosing FixYa.
Aug 26, 2011 | Friedrich D50 Dehumidifier
AIRFORCE CLIMATE CONTROL HIGH PERFORMANCE 20 LITRE A DAY DEHUMIDIFIER WDDH-820EAH - Hello can you provide me with basic instructions for this as i have lost my manual. Thanks
Hi and welcome to FixYa, I am Kelly.
Per the model number you provided in your post (WDDH-820EAH) this is your user's Manual:
http://www.orientalpacific.com/backend/files/products/manuals/127/WDH-820EAH%20User%20Manual.pdf
Note the comment about air filter cleaning on the back of the unit every 2 weeks.
Thanks for choosing FixYa,
Kelly
Dec 27, 2010 | Dehumidifiers
How to clean the filter on a Widetech WDH-101P dehumidifier
Slide it out and put the vacuum cleaner across it. Replace.
Sep 07, 2010 | Dehumidifiers
Have a wind chaser wdh running in my basement and it keeps icing
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 29, 2009 | Windchaser WDH928 Dehumidifier
Dh305y6 keeps shutting of within minutes
sounds like you need to replace your humidistat control. this is just like a thermostat on an air conditioning system, except inside of sensing temp and turning off, it senses humidity and turns off.
Jul 02, 2009 | Goldstar DH504EL Dehumidifier
Dehumidifier runs, but extrracts no moisture
if you turn it up and it starts, or turn it down and it stops, all is well, sometimes there just isnt much moisture in the air.
Jun 20, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Dehumidifiers Logo
69 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
