Where is vertical ic in lg 500G studio work crt monitor
Hi, i need help here about LG Studiowork crt monitor (500g). Unlucky, my monitor dead suddenly when i do surfing internet.
So, I had to check and found that there is a defective component (explode).
I tried to google the serial component "YZ010G", but no details.
Please friends help me. thank you
Posted on May 24, 2013
chinna_1977
  • 65 Answers
SOURCE: LG STUDIOWORKS 500g - FULL SCREEN NOT GETTING DISPLAYED
It's Loose contact Problem in Vertical section
Pl corrected dry points all over the vertical section.
Posted on Oct 10, 2008
  • 62 Answers
SOURCE: My studioworks 500G monitor LED blinking with twise colour(Green and Amber)and no display.
1. LOT problem.
2. Horizontal transistor bad.
3. Dry points in neck board, horizontal section.
4. transformer output capacitors problem.
5. IRF 630 ( lot supply fet )
Posted on Nov 03, 2008
SOURCE: CRT monitor becomes yellowish..
When any dust goes inside your monitor .......you will get these things.......... remove it , it will work fine
Posted on Feb 12, 2009
SOURCE: LG Studioworks model (500G)CRT Monitor flickers most of the time
lg 500g studioworks green color
Posted on Sep 03, 2009
  • 400 Answers
SOURCE: lg 500g monitor blinking in bi-color, no display when powered up
Sir,
there could be two possibilties for that
1 That your serial cable is not working or have broken pin .
2 Another is that you monitors picture tube has got damaged or burnt.
Usually it is second reason it can be repaired but is more expencive so i would prefer buying new one.
Posted on Nov 08, 2009
Vertical booster problem
check the resistor that supplies the vertical ic this must be open the supply of the vertical ic comes from the plyback replace the resistor connecting to it..
pls rate my help
Jun 14, 2010 | LG Studioworks 700S 17" CRT Monitor
LG STUDIOWORKS 500G monitor dead ?
your irf 630 is not original purchase it from proper LG authorised service centre it is costly but never become faulty again duplicate mosfet overheats if your green led is on then measure voltage at E.H.T.connect meter at output transister if E.H.T. is producing then meter should show 1 digit if not then 50v will show take care that signal cable should be disconnected if E.H.T. is not producing then check +vcc at horizontal ic it should be 12v. if 12v is not present then check regulator ic 7812 insmps
Mar 14, 2010 | LG 500LC Monitor
Diagram for supply
yes the diagram is in book of G.T. hardware engineering college jaypur in rajasthan india the books are available in metro citi and authorised suppliers only in that book not only diagram but troubleshooting mathods are also given
Nov 23, 2008 | LG Studioworks 45 14" CRT Monitor
1. LOT problem.
Nov 03, 2008 | LG Studioworks 45 14" CRT Monitor
Aug 31, 2008 | LG Studioworks 45 14" CRT Monitor
Problem
1. problem in vertical section .
2. Vertical IC supply capacitor problem.
3. Drypoints in Vertical IC saroundings.
4. vertical IC problem.
Jul 20, 2008 | LG Studioworks 552V 15" CRT Monitor
Lg 500g crt monitor problem
Try checking B+ coil , may be the coil have shorted .
Happy trying
Apr 01, 2008 | LG Studioworks 45 14" CRT Monitor
Horizontal and vertical adjustments
Check components related with pots thats adding command ic to pots.If they are ok then change command ic with new one.Before this you can check horizantal hold transistor that is placed on hitsink of eht.small in size and check two small transistor placed near it on pcb.Hope this solution works .If not then i am here
Mar 10, 2008 | LG Studioworks 45 14" CRT Monitor
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
