Question about Sport & Outdoor - Others
In Pole Vaulting what does NH stand for? - Sport & Outdoor - Others
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 39 Answers
NH means No Height and is the term given to athletes that did not manage to clear their entrance height 3 times consecutively.
Posted on Jan 17, 2013
2 Suggested Answers
annacomputer
  • 63 Answers
SOURCE: What are pole vaulting poles made of?
Typically these days pole vaulting poles are made from fiber glass or carbon fibers due to the lightness and strength of them.
Posted on Jan 14, 2013
Poor directions how do you use the adjustable stand
Alice if you are talking height adjustment, if it has this feature you will loosen the plastic collar/nut that is located approx. half way down on pole of stand, pull up on fan pole to raise and push down to lower, when at desired height tighten the plastic nut/collar. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Assemble Lasko Pedestal Stand Fan in Minutes with No Tools
Jun 05, 2016 | Cars & Trucks
Echo ppt-266 pole chainsaw will not cut with the pole extended
A very common problem is that the tip of the drive shaft breaks off. If it cuts with the pole retracted and won't cut with it extended, than the drive shaft is pulling out at the clutch end or at the head. Try loosening the screws where the pole goes into the cutting head, stand the unit straight up and twist the cutting head to see if it drops down even just a little bit. After trying that, loosen the screws where the pole goes into the engine assembly and twist it there also. If this doesn't work, remove the pole at the engine end and pull the drive shaft out to inspect the ends of the shaft. Good Luck. George
Oct 20, 2013 | Echo 12 in. 25.4 cc Bar Telescoping Gas...
What is the idea behind pole vaulting?
The idea of pole vaulting is to use a pole to clear a cross bar that is placed at great height. The object is to combine skill, speed and technique to jump over the cross bar using a pole.
Jan 17, 2013 | Sport & Outdoor - Others
Where was pole vaulting invented?
Pole-vaulting dates back to ancient Greece when the game's first started and has been part of the Olympic Games since it started. Pole vaulting was also used as a means of getting over land marshes in the Netherlands. A pile of poles were stored at each house and people would use them to jump over the marshes to save them long tedious journeys around them.
Jan 14, 2013 | Sport & Outdoor - Others
How long is a pole vault?
The pole in pole vaulting can be anywhere between 7 and 16 feet in length and this is determined by your weight.
For a4tech webcam pk333e model, how can i get a real clear image?at night,even with sufficient lightning, the image is red and looks like night vision.please answer me asap.thanks.
cho A4TECH webcam pk333e mô hình, làm th? nào tôi có th? nh?n ???c m?t hình ?nh th?c s? rõ ràng vào ban ?êm,? ngay c? v?i sét ??, hình ?nh có màu ?? và trông gi?ng nh? ?êm vision.please asap.thanks câu tr? l?i tôi.
Jun 28, 2011 | A4tech Office Equipment & Supplies
Plants vs zombies cheat
Unlimited MoneyOnce you have the Zen Garden, water the plants until they don't need anything else. After that, change the Date on your PC to another day. As soon as you do, the plants will need water again. Repeat this -- buy new plants, grow them to full size, sell and repeat to earn money.
This also works to get Marigolds in Crazy Dave's shop when they are out of stock. You can fill up your Zen Garden and make all the money you need. You don't even have to close out of the game.
CostumesEnter these codes with your keyboard during gameplay for the desired effect:
  • future - Futuristic sunglasses for zombies
  • mustache - Zombies with mustaches
  • pinata - A shower of candy when a zombie dies
  • trickedout - Alternate Lawn Mower appearance
  • sukhbir - Toggles the zombie's call for brains-sound
  • daisies - Zombies leave small daisies behind when killed
Milking Walnut Bowling for coinsHere's how to make Walnut Bowling more profitable:
1) Protect the Lawnmowers -- Each Mower is worth one gold coin ($250).
2) Line up shots off the front runner. After the first zombie is hit, each additional zombie strike generates coins.
3) Create a front runner where none exists! Pole vaulting zombies run fast until they vault over a nut, and the newspaper zombie runs fast after getting the paper destroyed by a nut. Just let them run a little bit down the lawn before sending a nut their way.
4) Just because you have nuts does not mean you have to use them. This is where "Nerves of Steel" comes into play. When there are a few zombies ambling down the lawn without a clear ricochet shot, wait a little bit to see if more of their friends will step out to play. They can always be killed once they cross the red line.
5) Remember how many nuts it takes to kill a zombie; this is important when the cross the red line. Use one nut for regular zombies, three for bucket wearing zombies, and two for the rest.
6) Reserve the exploding nuts. Try not to use those nuts unless a mob crosses the line, or there are not enough nuts or room to clear out a hard to kill zombie. Use the regular walnuts for the zombies that have not reached the red line.
7) Don't use exploding nuts to kill pole vaulting zombies directly. Pole vaulting zombies only jump obstacles in their own lane. A pole vaulting zombie who has not vaulted yet will safely jump over explosions or nuts in their own lane; so find a neighbor in the next lane and time the nut to hit when the pole vaulting zombie gets close to the neighbor.
Play Slot Machine for Extra Coins and Diamonds1) Set up your defenses around the slot machine. Try for one row of wallnuts on the right side, one or two rows of sunflowers on the left, and fill everything else with pea and snow pea shooters.
2) Protect the lawn mowers. Each are worth a Gold Coin at the end of the game, so don't let them mow the zombies.
3) Stop collecting sun around 1900 sun points. At this point, the garden should be full, so getting the extra 100 points to win should be easy. Just collect enough sun to offset the slot machine.
4) Keep the slot machine spinning! It will randomly drop one or three gems as long the patience lasts.
5) If the Zombies get close to the mowers, end the game. Just collect the sun lying on the field to end the game.
Switch Locked SeedsTired of being stuck with the crappy cards Crazy Dave makes you have? All you have to do is exit the game and restart it and the 3 cards will be changed to something else.
May 18, 2011 | Computers & Internet
How to assemble the hawaiian breeze oscillating floor fan
I cannot find exact instructions but I did find a general guide to assembly. they are usually very easy to assemble.
A standing fan is a portable fan that has a set of three oscillating blades on a long neck. The neck, also called the pole or the leg, is mounted on the floor. Standing fans have evolved from their origins as noisy accessories that blew away papers in their vicinity to silent fans whose direction can be controlled remotely. When placed at a convenient location, a standing fan can distribute air evenly to the entire room. Its speed can be controlled, and many standing fans can be programmed to stop at a set time.
  1. Installation Requirements
    • The only requirement for installing a standing fan is making sure it is near a power source. The entire unit can be assembled manually with only a screwdriver. A single standing fan, either an oscillating or pedestal fan, is very simple to assemble for basic home use.
    Pole and Base
    • The first step is to lay the parts on a floor. Then assemble the pole on the base of the stand. This is very simple, because the grooves for the screws are already drilled, so the screws just need to be inserted and screwed in. Screwing the pole into the base of the fan is required on some models; on others, the pole and the base are molded together and no screws are needed.
    Motor and Fan Installation
    • One some fans, you have to install the motor and oscillating arm to the pole. This again is done by screwing screws into predrilled holes. Grooves for long screws are at the top end of the pole, where they attach to the motor of the fan. Once the motor is placed on the top of the pole, insert the screws in the predrilled holes and tighten the screws. The next step is to wire the three blades. This is done by taking the wires from the motor and joining them to the sockets in the pole. This finishes the assembly procedure.
      To turn the fan on, ensure that the wires fit securely together. A loose connection cannot not only hamper the performance of the fan, it can also lead to problems such as electrical shocks or burning wires.
I hope this helps
good luck
Please rate FIXYA
Apr 07, 2011 | Vacuums
Fahrenheat plf2004
I can help you with this if you still need it.
Oct 16, 2008 | Fahrenheat Electric Convector Baseboard...
Sport & Outdoor - Others Logo
1,228 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
