Question about Sport & Outdoor - Others
How can I attach a ball to a rope to make a tetherball game?
    New Friend:
    Problem Solver:
  • 13 Answers
You can buy a tetherball ready made - however if money is tight you could always make your own by attaching a rope to a volleyball, you can make a hole in the sponge ball and pass the rope through it and tie a huge knot at the bottom.
Posted on Jan 17, 2013
How to replace recoil rope on LCT Snow Engine 136 Series Gen II?
if its got a 136 cc briggs and stratton engine, ive got a nifty trick to replace the starter rope and you don't even have to take the cover off , 1st locate the old cords ball end in the rope pulley use a flash light if needed ,cut ball end off with sharp pointed knife, fish out all the old rope thru hole use a old dental pick with a hook end , take a large c -clamp and with a screwdriver push cord pulley backwards "see direction arrow" far as you can clamp with c clamp then take another Bite with screwdriver loosten c-clamp and move it again , repeat this till you have 6 complete turns on pulley (springs pushing back) firmly attach c -clamp to pulley , then measure off 5 feet of new rope attach handle hold to end insert free end thru rope guide hole and into pulley passing it thru hole where knot was located previously (dental pick is great for this ) pull out rope enough you can knot it several times (i melt mine with lighter a bit) Carefull thought there gasoline there too pull rope tight till it knot sets back inside of groove then it simple ever so slowly release c -clamp and guide rope into cover , wow your done and you did'nt need to take engine cover off ropes now in correct posistion !!!!!!!!!
Aug 18, 2014 | Stormforce Garden
Tip
Building your own ladder golf set
Building your own set for ladder golf is relatively easy and shouldn't take you too long. So you can be up and running in just a few hours.
You are going to need is 1" PVC pipe cut into 6 12-inch pieces and 9 24-inch pieces. You are also going to need 6 elbow fitting, 6 t-fittings. For the balls you are going to need 24 solid golf balls (2 sets of 12 in 2 different colors) and about 28 feet of nylon rope.
To building the ladder to form the base take 4 of the elbow fittings and two t-fitting and the 6 24-inch pipes. Connect the pipes to the elbows and the T's so that they flat side of the T is facing down. There should be an empty socket facing up. When you are finished you should have a rectangle that is 4ft by 2ft with 2 upward facing sockets to hold the ladder.
Next you want to build the ladder. Start by taking one of the remaining 24-inch pipes and attaching an elbow fitting to each end. Then attach a 12-inch pipe to the other side of the elbow. At the other end of the 12 inch pipe you are going to attach a t-fitting, continuing along the plane of the 12-inch pipes attach 2 more 12-inch pipes and in the cross plane attach a 24-inch pipe. Repeat this for the bottom step of the ladder. After you have attached the last pipe fit the open ends into the base and there you have your three step ladder for playing.
To make the balls you are going to need a drill to drill a hole through the center of the 24 balls. After you have drilled the holes in the balls take your nylon rope and measure and cut it into 12 20-inch pieces. It is suggested that you burn the ends of the rope so that they don't fray. Stick the rope through the holes and tie a knot on either side of the ball so they don't move. Put one ball on each end of the rope. You are going to need 6 ropes with 2 balls on each.
Once you have finished making the balls you are ready to play! Some play with each player on their own ladder, if you want to play that way you can follow these instructions again to build a second ladder or you can just use one.
on Oct 28, 2013 | Sport & Outdoor - Others
Have a 2-4 hp lawnmower where the rewind spring and rope was broke. Have put new spring and rope on-works great in housing. When attach it to lawnmower the rope pulls out but won't retract back in. As soon...
When you remove the recoil shroud ( housing ), the square shaft sticking out should move freely in a counter-clockwise direction and you should hear clicks when you twist. If you don't hear the little balls clicking or the square shaft doesn't move freely counterclockwise, then that square shaft is rusted onto the end of the crankshaft and must be freed before it can be removed. This is a common problem for mowers left out in the elements. Sounds like the shaft is frozen onto the crankshaft end. Procedure: First, disconnect the spark plug. Get a magnet ready because 5 little balls are gonna come rolling out on this upcoming move. Take a 1/4
Sep 27, 2013 | Briggs & Stratton Briggs Stratton...
I want to make a tetherball pole stay in the ground without falling over, how can I do this?
You should dig a hole that is about 2 feet deep, you should get a pole which is 2 inches thick and 12 feet long. Place the pole into the hole so that 10 foot of it is sticking out of the ground. Fill the hole with cement and wait for it to dry. This should be enough to keep the pole in place when swinging the ball.
Jan 17, 2013 | Sport & Outdoor - Others
How tall should the pole be in tetherball?
If you are going to make a tetherball pole you should make it at least 10ft tall (roughly 3meters) from the ground.
Jan 13, 2013 | Sport & Outdoor - Others
What is tetherball?
Tetherball is a fun sport where two contestants swing a volleyball that is attached to a pole with rope. The idea is that one contest will swing it clockwise and the other anticlockwise - a player wins when they manage to swing the ball so that it is wrapped around the pole and can't swing any further.
What is the purpose of a medicine ball with a rope attached to it?
Medicine balls with a rope allow you to develop rotational strength and power. Here is a short video clip that illustrates how to use this type of medicine ball to develop your rotational skills.
http://www.youtube.com/watch?v=1VzoaVtnZSk
Aug 05, 2012 | Exercise & Fitness
What are some specific types of medicine balls?
Some of the varieties of medicine balls include: leather medicine balls, soft gel medicine balls, medicine balls with grip, air filled medicine balls medicine balls with handles and medicine balls with a rope attached.
Sport & Outdoor - Others Logo
247 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
