Question about Skating
Should I wear a protective helmet when rollerblading?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 39 Answers
There is no law that suggests that you must wear a protective helmet when rollerblading - however if you are prone to falling over like me then it would be advisable to wear something to protect your precious head.
Posted on Jan 17, 2013
My charlesowen helmet has a dent in it. am i able to get ait fixed somewhere or can charlesowen replace it? HELP!
Your helmet is now destroyed and should never be worn for protective purposes. get a ballpien hammer and smash it through the helmet to make sure no one ever uses it.
Mar 28, 2015 | Motorcycles
Tip
Choosing the best climbing helmet for your head
Rock climbing is a very fun hobby but it can also be very dangerous. Wearing a helmet when you climb can be a life saver, but it is important
that you make sure that you are wearing the right helmet both for the
activity you are performing and for your head.
When it comes to selecting the right type of helmet there are two main types to choose from, suspension and sponge. The suspension helmets are very similar to a construction helmet, its a hard shell with a netting on the inside.
These are really great for vertical dropping objects but they tend to be a little heavy. The other type of helmets are the foam helmets. These ones are made out of a lighter-weight polystyrene or polypropylene foam with a hard shell over it. It works by absorbing the energy of the of the falling object in the plastic and will deform the foam permanently. The durability of the helmet depends on the thickness of the shell, but because the impact on the helmet permanently damages the helmet it may not be very effective for extensive use.
After you have chosen the type of helmet that you will be using, its time to head into making sure that you have the right fit for your helmet. Keep in mind that you
will be more likely to use a helmet that fits correctly and is comfortable, before buying you should test out the helmet like you do with a pair of shoes. Many of the top climbing stores will allow you to try on and test out the helmet to make sure that it fits properly.
There are two main features that you have to pay attention to when trying on and picking out the right fitting helmet, they are adjustability and the chin strap. You start by placing the helmet on your head with it straight on your head making sure that you don’t tilt the helmet because you have to keep your forehead protected. Next you want to shake your head from side to side, does the helmet move? If it does then you want to either look for a different size helmet or if you can adjust the straps on the inside of the helmet so that it fits snugly. Then buckle the chin strap, it should fit snugly on your chin and form a Y shape
around your ears. There should not be any slack in the straps and if you
wear a pack make sure that you can lift your head to look up while
wearing the helmet.
A few side notes to keep in mind when considering the helmet you want to get. If you are going to be climbing in a very hot or very cold climate when you buy the helmet make sure to take your headscarf or hat with you so that you get a helmet that fits with them underneath. Where you are going to be climbing can also have an impact on the helmet that you will buy, if you are going to be
climbing in a cold climate that has ice you will want to get a solid helmet that will protect you from falling debris, while if you are going to be climbing in a warmer climate you will want to get a helmet that has air vents to allow for air circulation.
on Jan 16, 2014 | Rock & Ice Climbing
How to remove discoloration on wind deflectors on automobiles?
If you are talking about a plastic wind deflector that has discolored due to oxidation I'd recommend a polish like the kind used to treat motorcycle helmets and plastic vehicle headlights. You'll need a buffer or rotary tool - and don't forget to wear protective eye-wear.
Mar 19, 2015 | Cars & Trucks
What is the next number 3,3,4,2,1,...
First off this is the category for Motorcycle Protective Gear. The Bell Sequence Mountain Bike Helmet in matte black is not DOT approved for Motorcycle use. In any case the serial numbers are 2038082, 2038083, and 2038084 for small, medium, and large.
http://www.thebellstore.com/product/bicycle-helmets-bell-mtb/bell-helmets-bicycle-sequence-matteblack.html
Oct 11, 2013 | Bell Helmets road-mtb Sequence Matte Black
I trying to adjust rollerblade sizes and it doesn't work
u should but a smaller/ bigger pair of rollerblades
Feb 18, 2013 | Sport & Outdoor - Others
Are pitching machines dangerous?
The short answer is yes. They are dangerous because they shoot heavy projectiles at a minimum of 40 miles per hour. If you are using a pitching machine, it is imperative that you wear the proper protective gear such as helmet, chest and leg guards.
Feb 06, 2013 | Baseball & Softball
Should I wear a helmet on an exercise bike?
No, you do not need to wear a helmet on an exercise bikebecause it is stationary and you are not likely to fall off.
Jul 09, 2012 | Exercise & Fitness
What is the best helmet in halo reach
Haunted helmet
is the pilot helmet but opened revealing a face which is a skull
can be achieved by unlocking all base helmets and reaching inheritor rank
Oct 10, 2011 | Microsoft Xbox 360 Console
Is it true you don't wear a toque if you wear a snowboarding helmet?
I have a helmet and I don't need a hat under it. The helmet is quite warm. They also usually have vents to open for those warmer days.
Dec 01, 2008 | Dual Electronics Lightweight Polyurethane...
Recomanded protective gear
always wear an helmet while working with any kind of demolition or heavy tool. Safety first!
Aug 27, 2008 | Makita HM1810 Factory-Reconditioned 70 lb....
Skating Logo
423 people viewed this question
