Question about Sport & Outdoor - Others
Buying roller skate parts can be expensive. How can I prolong the life of my skate wheels?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 13 Answers
Yeah, I agree that buying a roller skate parts can be expensive. The important element to prolong the life of skate wheels is to use the best and reliable bearings. I use precision bearings for my skates since last 5 years and I haven't faced any issue till now. It stil run very smoothly.
Posted on Jun 29, 2018
    Problem Solver:
  • 8 Answers
Here are some tips for enhancing life of roller skates' wheels:-
1.On hot days, schedule your skating for early in the morning or late in the evening.
2.Avoid leaving it in the heat as it affects the working of the wheel.
3.Rotate your wheels every whenever you use them by moving each wheel back.
4.Good wheels have staying power. So try to buy only best quality roller skates for yourself.
Yes, roller skates are expensive but it does not cost anything if you are getting the best of them.
Buying roller skate parts can be expensive. How ca - figure-roller-skates-jobfot2vmul4hxb32zboc30f-4-0.jpg
Posted on Jan 27, 2018
    New Friend:
    Problem Solver:
  • 13 Answers
The inside of the wheels is usually the first to go - you should rotate your wheels so that the worn out edge is on the outside, this will wear the wheels out evenly and they will last longer.
Posted on Jan 17, 2013
2 Suggested Answers
  • 16 Answers
SOURCE: How to change a wheel on a roller-skate?
To change a wheel on your roller skate please do the following:
Unscrew and remove the axle bolts from the front wheel with an Allen wrench. Pull the front wheel out of the wheel frame. Remove the bearings and spacer from the wheel. All components should slip out together. Place the spacer and bearings into the new wheel. Place the new wheel on the wheel frame. Replace the axle and tighten it using the Allen wrench. If your spacer is aluminum, tighten the axle as far as it will go. If your spacer is plastic, tighten the axle almost as far as it will go, then loosen it slightly. Spin the wheel to see how easily it rolls. If it doesn't spin freely, loosen the axle. If the wheel wobbles, tighten the axle. Repeat the previous steps for the remaining wheels.
Posted on Jan 13, 2013
My dyer squeaks
a squeaky dryer means the casting wheels on the dryer are broken and need of replacement their kinda like skate wheels but more durable to stand up to heat however a simple hack such as using metal skate like rollers should help in a far long run
Apr 22, 2017 | Dryers
What is ice skate? And where can I get the ice skates for girls?
ice skating is like roller skating only on ice
ice skates are available from most sports shops
Oct 14, 2016 | Sport & Outdoor - Others
My daughter broke the part of her skates that holds the break can I replace this and if so from where and how
try phoning your local roller skating rink they may have a service to fix skates or will be able to advise where there roller derby skaters get their skates repaired locally.
Aug 23, 2015 | Cycling
The wheels on my roller skates are vibrating and sluggish when I skate, what could cause this?
. It seems as though your line bearings inside the wheel need to be changed. To do this you should: Use an Allen wrench to remove the axle from the front wheel. Pull out the front wheel. Remove the old bearings from either side of the wheel. They should pop right off if you use a bolt or something similar. Place new bearings on either side of the wheel. If necessary, use a flat surface for extra leverage. Place the wheel in the wheel frame. Use the Allen wrench to replace the axle. If your spacer is aluminium, tighten the axle bolts as far as they will go. If your spacer is plastic, tighten the bolts as far as they will go, then loosen them slightly. Spin the wheel to see how easily it rolls. If it doesn't spin freely, loosen the axle. If it wobbles, tighten the axle. Repeat the steps for the remaining wheels.
Jan 17, 2013 | Sport & Outdoor - Others
How to change the line bearings in my skate wheels?
Remove the nut in the center of the wheel and pull the wheel out. Remove the Wasser and remove the old bearings. Now insert the new bearings that you like and fix it all like it was before.
how-to-maintain-a-skateboard-1-nucjddmsi3ykoqyvie4d5yfo-3-0.jpg You're probably changing the bearings because it was of bad quality, right?
Always make sure to choose the right bearing for your objects. You may check ball bearings in us to know about the best bearings.
. I am great at roller blading, does this mean that I will be good at ice-skating?
They are pretty similar however ice is very slippery so there is an obvious difference.
Following the below steps you can easily change wheels of your roller skates :-
*Figure out which side of your tool fits snugly over the nut.
*Your nuts shouldn't be too tight and the wheels slide right off the trucks.
*I suggest putting a towel down to put your wheels.
*Putting wheels on is similar to taking them off. Make sure your nut is facing the right way.
*Tighten the nut with your fingers until you can't anymore.
When I purchased for myself they have given free services for it and thus I learned watching them only.
Jan 13, 2013 | Sport & Outdoor - Others
One of my bower roller skates has a wobbly when can I fix this or will I need to buy a set of wheels?
Dryer sounds like it has a shoe inside. makes thump sounds when running.
does the sound get quieter as it heats up ? if so its likely a drum support (roller) kind of like a roller skate wheel. If sound dosent change after running a while hot you may have a actual drum issue
Aug 06, 2010 | Frigidaire Dryers
Converting Little Tikes Roller Blades
My nephew has these skates and I just converted them from the training position to the inline position. The skates come with a bag of extra parts that you need to make the conversion. Basically you need the same bolt that is used for the first wheel and the middle wheel since the back two wheels are mounted on a long bolt that doesn't work for just one wheel. If you didn't get these spare parts then you're probably out of luck. If you're converting to the inline position you might be able to just use the front and rear positions but the plastic frame may not be strong enough. Good luck!
Mar 04, 2009 | Toys
Sport & Outdoor - Others Logo
553 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
