Question about Sport & Outdoor - Others
How to change the line bearings in my skate wheels?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 39 Answers
Use an Allen wrench to remove the axle from the front wheel. Pull out the front wheel. Remove the old bearings from either side of the wheel. They should pop right off if you use a bolt or something similar. Place new bearings on either side of the wheel. If necessary, use a flat surface for extra leverage. Place the wheel in the wheel frame. Use the Allen wrench to replace the axle. If your spacer is aluminum, tighten the axle bolts as far as they will go. If your spacer is plastic, tighten the bolts as far as they will go, then loosen them slightly. Spin the wheel to see how easily it rolls. If it doesn't spin freely, loosen the axle. If it wobbles, tighten the axle. Repeat the steps for the remaining wheels.
Posted on Jan 17, 2013
I need to convert these training skates to inline skates
Buy a set of training wheels, install them on skates. Also, look in the diaper aisle for training pants. Put them on outside of your pants, so people will know your "training" thus stay out of your way.
Aug 30, 2014 | Generic Chicago Skates Boys Training...
Bugaboo bee 09 rear wheels
Yes the Bee+ wheels fit you need two 4 mm alan / hex keys to take off the wheel. You could just change the bearings they use a 608zz bearing any bearing or skate board shop would sell but you may need to add a few spacing washers as the Bugaboo bearing has an extended core.
Dec 30, 2013 | Bugaboo Bee Stroller
Buying roller skate parts can be expensive. How can I prolong the life of my skate wheels?
The inside of the wheels is usually the first to go - you should rotate your wheels so that the worn out edge is on the outside, this will wear the wheels out evenly and they will last longer.
Jan 17, 2013 | Sport & Outdoor - Others
The wheels on my roller skates are vibrating and sluggish when I skate, what could cause this?
. It seems as though your line bearings inside the wheel need to be changed. To do this you should: Use an Allen wrench to remove the axle from the front wheel. Pull out the front wheel. Remove the old bearings from either side of the wheel. They should pop right off if you use a bolt or something similar. Place new bearings on either side of the wheel. If necessary, use a flat surface for extra leverage. Place the wheel in the wheel frame. Use the Allen wrench to replace the axle. If your spacer is aluminium, tighten the axle bolts as far as they will go. If your spacer is plastic, tighten the bolts as far as they will go, then loosen them slightly. Spin the wheel to see how easily it rolls. If it doesn't spin freely, loosen the axle. If it wobbles, tighten the axle. Repeat the steps for the remaining wheels.
How to change a wheel on a roller-skate?
To change a wheel on your roller skate please do the following:
Unscrew and remove the axle bolts from the front wheel with an Allen wrench. Pull the front wheel out of the wheel frame. Remove the bearings and spacer from the wheel. All components should slip out together. Place the spacer and bearings into the new wheel. Place the new wheel on the wheel frame. Replace the axle and tighten it using the Allen wrench. If your spacer is aluminum, tighten the axle as far as it will go. If your spacer is plastic, tighten the axle almost as far as it will go, then loosen it slightly. Spin the wheel to see how easily it rolls. If it doesn't spin freely, loosen the axle. If the wheel wobbles, tighten the axle. Repeat the previous steps for the remaining wheels.
Jan 13, 2013 | Sport & Outdoor - Others
One of my bower roller skates has a wobbly when can I fix this or will I need to buy a set of wheels?
My skates turn on their own so how do you fix it
try turning the wheels around so that the outside is now the inside
Sep 29, 2009 | Chicago Skates Women's Chicago Deluxe...
Converting Little Tikes Roller Blades
My nephew has these skates and I just converted them from the training position to the inline position. The skates come with a bag of extra parts that you need to make the conversion. Basically you need the same bolt that is used for the first wheel and the middle wheel since the back two wheels are mounted on a long bolt that doesn't work for just one wheel. If you didn't get these spare parts then you're probably out of luck. If you're converting to the inline position you might be able to just use the front and rear positions but the plastic frame may not be strong enough. Good luck!
Mar 04, 2009 | Toys
Electric scooter support
Most electic scooters cruise well because they use the same type of wheel that are used by inline skates to minimize rolling resistance. The wheels are also about three times as large as skate wheels so they glide much better than smaller inline or skate wheels. Accelerate the scooter and cover ground.
Aug 27, 2008 | Amigo HD450 3 Wheel Scooter with 33AH...
Sport & Outdoor - Others Logo
465 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
