Question about Mitsubishi WL-82913 82" Rear Projection HDTV
DIGITAL MODULATOR FIND PART NUMBER
I NEED HELP TO FIND PART NUMBER FROM DIGITAL MODULATOR MODULE FOR MITSUBISHI TV MODEL WL-82913 THANKS
  • benny leon
    benny leon Jul 13, 2007
    Thanks appreciate you help i solved my problem
    benny leon
  • 87 Answers
Mitshubishi part #934C066001.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Jul 13, 2007
Mitsubishi WL-82913 will not turn on, green power on light blinks continuaously but unit does not turn on. Any suggestions or ideas as to what the cause may be and is there a known fix? Thanks for your...
It is a capacitor on a circuit board. You access it from the back of the tv, however I do not remember much more about the repair except that there were two identical capacitors, and the repairman changed them both out in about 10 minutes. Still charged $200.00 plus dollars for the repair, but apparently he knew extractly what the problem was with doing any other testing so it must be a common problem with the set.
Dec 01, 2009 | Mitsubishi WL-82913 82" Rear Projection...
No picture !
Suggest ebay
Jun 29, 2009 | Televison & Video
Timer light is flashing tv want come on
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Jan 22, 2009 | Mitsubishi WL-82913 82" Rear Projection...
Mitsubishe WL 82913
does the lamp indicator light as red? let me know what the status light does...is it blinking or solid give me some info and I should be able to help you also mitsubshi had some problems with jamicon capacitors with a thousand uf and above ratings that are no good 95 percent of all dlp problems can be traced to those bad capacitors
Apr 10, 2008 | Mitsubishi WL-82913 82" Rear Projection...
WL-82913 Lamp fails and TV turns off every hour or so
We have the same problem. A 14,000 dollar TV that you cant even get a lamp for. I 'm thinking of a class action lawsuit. This is ********!!!!!!!!!!!!!!!!!!!! Please respond if your interested
Jan 12, 2008 | Mitsubishi WL-82913 82" Rear Projection...
TV Won't Turn On - Timer light flashing continuously
try and unplug it from the wall. This should restart the computer. If that doesn't work, you should probably look at buying a new television set.
Aug 26, 2007 | Mitsubishi WL-82913 82" Rear Projection...
Mitsubishi WL-82913 82" Rear Projection HDTV Logo
129 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
