Question about LG WD-14124RD Front Load Washer / Dryer
Adjusting the door lock on lg wd-1412rd front loader washer
How do i adjust the door lock on the washing machine WD-1412rd please
  • Anonymous Apr 17, 2009
    This has to be the most frustrating aspect of this LG machine
    How to open the door after a wash or dry cycle
  • 1294 Answers
SOURCE: door not opening LG front loader washing machine
Try: Program the select knob at 6 o'clock position. Speed at 9 o'clock. Press pre-wash and the power button together for 4 to 5 seconds. Hopefully it will unlock.
Posted on Sep 30, 2007
SOURCE: Washer LG Model WD-8013F Noisy & vibrates badfly when spinning
hi all you poor owners of this heap of junk, i have one too with the same problems, the shaking and moving around the bathroom was stopped by welding a 1/2 inch long piece of 1 &1/2 inch dia pipe to a 2 inch square flat plate of steel then putting double sided sticky tape beetween the plate and the floor
where you want the front rubber legs to sit, this stops it from running around the floor but it still needs to adjusted to have the
same on the front two legs to stop the shaking.by leaning the machine back a bit also helps to stop it leaking so bad while filling, it is only from the condersation from the hot water going in and the poor design of the soap drawer not allowing the water to run back into the washer which can be fixed by cutting the lip off
the bottom wher the drawer slides in then running a bead of silcone in the crack between the front cover and the inside piece
then another one on the front edge to run the water back into the washer. hpoe this helps. bryan.
Posted on Feb 26, 2008
  • 351 Answers
SOURCE: LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Posted on Mar 02, 2008
  • 489 Answers
SOURCE: LG WD-1021-WF Front Loader Washing Mashing
Replacing the door seal is not an easy task.  You will need to get 2 special tools from LG to make it as easy as possible.  The spring loaded clamps are very hard to put on because the springs are so strong.  Once you get the special tools, remove the front clamp off the door seal.  Pull the seal off the lip to gain access to inner seal clamp.  Remove the inner clamp and pull off the rubber door seal.  Just reverse the procedure when reinstalling the new seal.
Posted on Jun 26, 2008
SOURCE: lg intello wash wd 8013f
The front panel is flasing when i press play
Posted on Sep 16, 2008
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
My LG WD-8023 Fb front loader has the door locked solid. At the end of the wash cycle the delay lock is not releasing. Any assistance appreciated.
look down the very bottom of the machine you should see a couple screws on the bottom unscrew these and remve the lower panel you may have one screw also in the clean out you will be looking for a type of pull cord that is attached to the door pull the cord and the door will open. if the delay lock is not releasing then you would have to replace the door lock assembly in the unit if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Mar 15, 2011 | LG WD-1280FHD Front Load Washer
I have a LG WD - 1049C front loader washing machine showing the DE error have emptied out the washing machine and it still comes up, partner bought a new door latch and installed it but the DE is still...
DE error does mean the door latch,but there are three parts that could cause the error code.If you have changed the door lock already then the main p.c.b/computer board has failed and not registering the door lock but there is a 5-10% chance it's the wiring connecting the two parts together.So basically you need to change the main p.c.b & if that doesn't work it needs to be rewired.unless you know how to use a multi-meter then you could test the wiring for a definate answer.THANKS ECO KIZZA
Feb 18, 2011 | LG WD-1045FH Front Load Washer
My aged invalid mother has a front loading LG washer dryer combo and has washed the same garment 3 times and after wash cycle or drying cycle can't seem to get the door to open to remove the clothes. What...
Hi I hope you solved this by now but I thought an answer might be useful if anyone else has the same question. I am not an expert just an owner of a LG WD-1412RD. It sounds like your mum is not aware this is just the normal safety cool down period following drying (as the stainless steel interior gets very hot during drying). The Door lock sign (small red light) is on, and the display shows Cd during this time, then it beeps and the door unlocks by itself. If you need to remove your laundry earlier than this, you can press the START/PAUSE button to end the cycle (it still takes a couple of minutes). This is covered on p 21 - 22 of the owners manual. which can be downloaded from the LG site. http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Nov 28, 2010 | LG WD-14124RD Front Load Washer / Dryer
Torn door gasket / collar
It requires technical expertise and speccial tools. Part isn't expensive, labor may be depending upon where you live
May 05, 2010 | LG WD-14124RD Front Load Washer / Dryer
Top loader door wont open
Something has caused the washer to not release the door. Is there an error code that is flashing (FE?). A locked door can be due to too much water in the basket, suds causing false water detection (should be using HE), or perhaps the drain is clogged.
If you are sure that the water is not going to spill out on floor, then you might be able to get door open by unplugging the unit and waiting a few minutes (mine took an hour) for the electric lock to release.
Sep 15, 2009 | LG WD-16115FD Front Load Washer
Error display "CL" - what to do?
THe child lock is on. Mine came on for some random reason. On my LG front loader there is a button on the right hand side with a cartoony picture of a child and a padlock. Press this.
Jul 04, 2008 | LG WD-1280FHD Front Load Washer
Mar 02, 2008 | LG WM1812C Front Load Washer
LG WD-14124RD Front Load Washer / Dryer Logo
586 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
