Question about Hunting
What is an Auto Backer? - Hunting
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
Auto backer are usually remote and their purpose is to train your dog to stop or go back words when another dog points. This device usually has 2 transmitters that allow raising and lowering the dummy at the push of a button.
Posted on Jan 17, 2013
UNSCRAMBLE THESE LETTERS TO MAKE 3 WORDS
Did you mean 3 words which make sense together? How about 'rocket lab pilot'
If they don't have to make sense together there are many possibilites
A Bitter Pollock
A Brooklet Clipt
A Blotto Prickle
Cab Kite Trollop
Cab Tike Trollop
Cab Triplet Look
Cab Plotter Kilo
Crablike Lop Tot
Crablike Pol Tot
Crablike Plot To
Crablike Lot Top
Crablike Lot Opt
Crablike Lot Pot
Tieback Poll Tor
Tieback Poll Rot
Tieback Poll Ort
Tieback Roll Top
Tieback Roll Opt
Tieback Roll Pot
Tieback Troll Op
Tieback Toll Pro
Balletic Pork To
Blacker Pilot To
Blacker Toil Top
Blacker Toil Opt
Blacker Toil Pot
Blacker Lip Toot
Blacker Pi Lotto
Blacker Pit Tool
Blacker Pit Loot
Blacker Tip Tool
Blacker Tip Loot
Backer Pill Toot
Backer Pilot Lot
Backer Toil Plot
Backer Lip Lotto
Backer Tilt Loop
Backer Tilt Polo
Backer Tilt Pool
Bracket Pill Too
Bracket Oil Plot
Bracket Pilot Lo
Bracket Toil Lop
Bracket Toil Pol
Bracket Lip Tool
Bracket Lip Loot
Bracket Lit Loop
Bracket Lit Polo
Bracket Lit Pool
Bracket Poi Toll
Cable Kilt Troop
Placebo Ilk Tort
Placebo Ilk Trot
Placebo Kilt Tor
Placebo Kilt Rot
Placebo Kilt Ort
Back Little Poor
Back Politer Lot
Back Loiter Plot
Back Toiler Plot
Back Peril Lotto
Back Triple Tool
Back Triple Loot
Back Litter Loop
Back Litter Polo
Back Litter Pool
Back Tiptoe Roll
Back Tie Trollop
Back Rootlet Lip
Back Petrol Toil
Back Plotter Oil
Back Tooter Pill
Black Politer To
Black Polite Tor
etc etc
Dec 14, 2016 | Miscellaneous
Tip
Making a wooden picture frame with perfect corners
Picture frames are very easy to make, but many people make the same very basic mistake that will ruin your frame. It is very important that you follow the carpenters rule of measure twice and cut once. If you don't cut the sides of the frame to be the same length, and you cut the angles of the corners slightly off then when you put it together the final corner won't line up.
The things that you are going to need is a miter saw, some clamps, a backer board and a drafting squares to make sure you have the right angle.
To set up take your backer board and cut off a piece that's around 4 inches to be used as a sliding marker gauge. After cutting it off attach a small piece of wood to keep the slider from shifting around.
With the saw unplugged and turned off clamp the backer board to the back of the saw. To cut the corners of the a frame you need to set the saw to a 45 degree angle. Make sure to check the angle using a drafting square align one side with the backer board and bring down the saw blade align them to make sure its a 45 degree angle. When you think that its right grab yourself a piece of scrap wood and make an initial cut. After cutting the test measure the angle to make sure that it is the right angle.
When you are ready to cut the frame itself take the four pieces of the frame and make an initial cut. Once all the boards have been cut once take your slider marker to the length that you want the sides of the frame to be and clamp it in. Take the first two sides and one at a time line it up with the backer board with the angle on the outside and the cut point against the slider. Turn on the saw and cut the other end. Repeat these steps to cut the other three sides.
After all the sides have been cut use a 90 degree angle to align the corners of the frame. Lay out all the sides of the frame and line them up as tight as you can. To connect them you can use a staple gun to staple the corners together. If you were aligning it and pushing the sides together when you stapled the corners you should have perfectly aligned corners.
Now all that's left is to sand it down and get the inside ready for a picture and stain it if you want.
on Feb 17, 2014 | Saws
How do you darn?
Your first step is to put a backer--stabilizer, pelon, or material underneath the area to be darned. You can use spray adhesive, or use an iron-on backer.
Generally, you should use the zigzag stitch that is several stitches--not the one that does one stitch in one direction and the next in the opposite direction. Make sure that the stitch is wide enough to cover the area next to the tear and hold it securely. It is a good idea to stitch over the tear several times.
Jul 04, 2014 | Singer Quantum XL-5000 Computerized Sewing...
Repair concrete floor, large cracks in flooring
install backer rod into cracks that are more than an 1/8 and use concrete sealer (in the caulking section of your local hardware store). The backer rod is used to reduce the amount of sealer you have to use to bridge the larger gaps in the cracks.
Nov 05, 2013 | Mozilla Firefox
Multitool 250 CE cannot replace the backer with teeth for accessory holding. How?
If the part you purchased is 2609110769 then from looking at the drawing I would have said that it was a press fit so you would have to use some kind of puller to remove the old one and a press to refit the new one. never done one myself before so this is just an educated guess.
Dec 04, 2012 | Bosch GOP 250 CE Professional 220V...
Lost radio code to my Becker Indianapolis BE 7925
Help me....I need code...I have Backer Indianapolis BE 7925...Serial No 45002282....
Jun 24, 2012 | Car Audio & Video
Fuel leak at the fuel line connectors on fuel rail
has this been taken apart before?? there are o rings inside the connector and a lil plastic backer piece, they can dry out and tear when pulled apart or score enuff to leak . is the fitting clean or rusty
same with the line, was it taken apart with the propper tool????
the coupler can be repacked if all the pieces are there. if indoubt
go to an auto wrecker and get a section of line with the fitting complete disassemble and repack yours be careful no damage
if beyond your ability get a garage to fix it ,leaky gas can spray back onto your exhaust n catch fire be aware!
Nov 25, 2009 | 1999 Pontiac Bonneville
How to replace the head gear
i'm going to assume your 7" is like my 9" and say that after you remove the backer pad and expose the spindle you should have access to the gearbox cover that's held in with 4 screws. if you remove those 4 screws and remove the cover you should have the bevel gear exposed.
of course the handle and guard will have to be removed to make it easier.
hold down the spindle lock when unscrewing the backer pad.
Nov 21, 2008 | Makita 7" Electronic Sander - Polisher...
Hunting Logo
1,073 people viewed this question
Top Hunting Experts
Peter
Peter
Carl Wiehe
Carl Wiehe
Lloyd Willingham
Level 1 Expert
Are you a Hunting Expert? Answer questions, earn points and help others
