Question about Hotpoint-Ariston SDL510P Dishwasher
Hotpoint sdl510 3hr and 9hr lights flashing
3hr and 9hr lights flashing, wont wash
Hotpoint aq7L149i washing machine flashing lights ?
Hi Jason.
The most likely reason for your problem is that the water inlet valve is faulty. This is why the machine won't fill.
It is a simple fix for a serviceman.
Good luck.
Nomess
Nov 21, 2014 | Hotpoint Washing Machines
Hotpoint wma32pr door light keep flashing and no wash
1) test the lid switch for open
2) test the door switch for open too
3) see the diagram attached, any switch faulty can not START the motor.
God bless you
Jun 19, 2012 | Washing Machines
Door will not open have wash cycle
Switch off, put in spin/drain cycle and switch back on; check water is fully drained and then check filter. If not all drained, lower hose to ground level and drain to a bowl.
Apr 28, 2012 | Hotpoint Washing Machines
Hi - reference our washing machine WF000G - the energy save light is flashing along with the on/off button and the machine wont run its cycle - can u help?
Do a search on Google using 'diagnostics, hotpoint, flashing lights'. There must be a manual which will identify what this fault is
Dec 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius fdw60
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
Sep 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
We have a hotpoint wd420 washing machine and it wont finnish a wash cycle. wont drain the water either, we do get an error code though in that the door locked light flashes as well as the reduce creases...
you have a blocked pipe - where the water is draining out. Either that or your filter is blocked.
best you open the back and take a look at the filter before calling out hotpoint - might save you 100 pound call out charge.
Jul 28, 2008 | Washing Machines
Lights flashing & door wont open
Dear RedBikeGirl
I've got a BWM129 which is causing me problems too (the washing is smelly at th eend of the cycle!) - How did you get the filter unit out of its housing, I turns around but doesn't seem to want to come out!
Any help gratefully received
Jun 01, 2008 | Hotpoint BWM12 Front Load Washer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Door lock flashes
Your switch bracket or switch is either broken or you have no either to or from it. Check your switch first.
Dec 18, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint-Ariston SDL510P Dishwasher Logo
198 people viewed this question
Top Hotpoint-Ariston Dishwashers Experts
Owen Barnes
Are you a Hotpoint-Ariston Dishwasher Expert? Answer questions, earn points and help others
