Question about Hunting
What is a serrated blade? - Hunting
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
A serrated blade is a blade that has a semi-saw on the sharp side of the blade. Serrated blade is ideal aggressive cutting action like cutting wet line, cable or cord.
Posted on Jan 17, 2013
Proper windshield wiper adjustment?
Good question. Try a site for Mustang Owners like a Club online. The spring tension can be adjustable by moving the tab that houses the spring on each arm. If you are concerned with the position, simply move the arm on the serrated shaft until the blades rest on the cowl. There should be little pressure. The sweep should fall in line with the "at rest" position. If not, a small adjustment can be made to maximize sweep.
May 18, 2015 | 1966 Ford Mustang
I want a list of survival equipment that I can buy and if you can also tell me where I can buy it will be helpful.
Survival List:
- knife/multi tool (steel would be best)
- another knife with a serrated blade (a steel blade will be best)
- compass
- canteen
- flint rock
- water proof matches (yes they do make them)
- dehydrated food
- binoculars
- rope
- some form of warm clothing
go to http://www.doomsdayprep.com
Nov 10, 2013 | Cars & Trucks
When buying a dive knife, should I get one with a serrated edge or a straight edge?
Serrated edges are used for cutting natural fibers such as rope and kelp and can be used with a sawing motion. The straight edge knives are better for cutting plastic, fishing line and nylon rope. You can get knives with a serrated and straight edge so you would be better to get one of these.
Jan 17, 2013 | Scuba Diving & Snorkeling
How does an electric knife work?
The way the knife works is that it has two knife blades put together. These blades are serrated (notched). When the power is on, the blades move sideways and basically saw through whatever they are cutting.
Jan 14, 2013 | Home
Krups Rotary 500 S shaped blade broken. Where can I get one
I'm also looking for a blade for the same food processor - the one with the serrated holes on both sides, we use it to grate potatoes. Can we do a swap? We do not use any of the other blades.
Apr 01, 2011 | Food Processors
How to remove wiper arms from truck
Lift the wiper blade off the windshield
On the right side of the arm, where it goes over the serrated drive wheel,there is a little metal slide.
Move it out to the right, and take off wiper arm
Now to do it real easy,you buy a tool from Snap-On, you will love
It hooks over the end of the arm,you wrap you fingers around the arm, to remove spring tension.
Really nice tool and easy to use
Nov 10, 2010 | 1993 Dodge Dakota
The drain hose on our washer is leaking outside the washer onto the floor. I bought a replacement at Lowe's, but I don't know how to remove the old one. The model is an Amana #LW1502L.
its on a barbed plastic fitting on the machine, the hose gets hardened from toe waste water going through it over the years, take a serrated knife or hacksaw blade and cut a **** lengthwise on old hose,be careful not to cut into machine fitting when doing so tho
Sep 26, 2009 | Washing Machines
Abs brake light
The abs system uses sensors to detect the rotation speeds of the wheels. They "count" serrated notches on the driveshaft cv joins which are located in the centre of each wheel on the inner side. These serrations can become clogged with grease/ rust/road muck so the sensors read incorrectly causing the fault light to come on. I can't remember whether it's possible to clean the serrations out without pulling the driveshafts out (quite a hefty job as there is a large and very tight nut on the end of each driveshaft which has to be removed). You'll need to have the car jacked up and on axle stands or better, up on an inspection ramp, then from underneath, scrape out all the gunk from the serrations with a small screwdriver or knife blade whilst rotating the wheel to gain access.
The sensors themselves can also develop faults, often caused by wiring breakage especially on the front wheels. The wiring to the sensors become brittle with age and can fracture-moreso the front ones as they are subject to most strees due to steering movements of the front wheels. The distance between the sensor tips and the cv joint serrations is also quite critical too.
In short: First ensure the brake fluid reservoir is topped up with the correct brake fluid (for abs systems), then make sure the power steering fluid reservoir is correctly topped up with the correct(usually mineral based) power steering fluid. Deficiency in either of these reservoirs will cause the abs warning light to come on and is by far the easiest thing to remedy but do make sure you use the correct fluids-if in doubt, consult Audi. Next check the wiring to the sensors, inspect the tips for cleanliness and positioning , then have a go at cleaning the cv joint serrations.
If these remedies don't solve the problem, it could be the bake servo (on the end of the brake master cylinder in the engine bay) or at worst (most expensive) the abs pump itself, although these are,thankfully, very reliable units.
Hope this helps, feel free to contact me for any other help I can offer.Good luck, Bob.
Sep 13, 2008 | 1985 Audi 5000 S
Tile Saws question
Since tiles are so thick, brittle, and made of ceramic, a special saw must be used. An ordinary circular saw for wood or metal would either break the tile or get so hot that it would seize up and stop cutting. However, ceramic tile is not cut well with sharp blades. The wet tile saw was invented to address all these unique properties of ceramic. It doesn't overheat, uses a relatively dull blade with no serrations, and can be transported to a job site and set up on top of an existing table or sawhorses.
Aug 27, 2008 | Dewalt DW8306 36-Grit. 4-1/2" Blue...
Hunting Logo
821 people viewed this question
Top Hunting Experts
Peter
Peter
Carl Wiehe
Carl Wiehe
Bruce Mommaerts
Bruce Mommaerts
Are you a Hunting Expert? Answer questions, earn points and help others
