Question about Hunting
Where can I find a tree stands that fits 2 people?
  • Ronald eitz
    Ronald eitz Jan 03, 2014
    You can buy them thru Cabels's, Gander Mt.,Bass Pro and Sportsman Guide.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
Freezer troubleshuting
Posted on May 05, 2013
I have a mercedes ml 270 cdi 2002 and when I move off from a stand still I get the dash lit up like a Christmas tree with abs/epc/bas and warning triangle along with brake light and goes into limp mode, I...
Sounds like you have a speed sensor problem. Possibly input or output shaft speed sensor on transmission. You will need to find out what fault codes are being set and proceed from there.
Nov 05, 2014 | 2001 Mercedes-Benz ML 270
Remove motorcycle fork
Put the bike on a stand to elevate the front end. Remove wheel, brake caliper, fender and anything else attached to the fork. Loosen the triple tree bolts. You may need to pry a bit with a flat screwdriver in the gaps of the triple trees where the bolts were while pulling down on fork to remove it. They fit tight. Hope this helps.
Jul 09, 2014 | 2013 Suzuki DR 200SE
How to put it back together
Here is a link to the item on the manufacturer's website. You should be able to locate the manual there.
Jan 27, 2013 | Frontgate Golden Rotating Tree Stand -...
What is the smallest tree I can attach my tree stand to?
Usually the smallest tree is about 8" in diameter and up until about 22"
Jan 17, 2013 | Hunting
What is the material used for tree stands?
Older treestands were made mainly out of steel. But in the past few years company started to use aluminum as it is durable and lighter in weight. However, if you are looking for durability and sturdiness then you may want to look for the steel tree stands.
Can I leave the tree stand outside when not using it?
It is not recommended to leave the treestands outside for long periods of time. If the stand's tubes are filled with water and the water freeze it may damage the tubes. Also, the ropes, the seats or other parts of the stand may be eaten or damaged by animals.
Jan 14, 2013 | Hunting
What is the smallest tree stand I can find?
There are some seats that are small but you must consider the fact that sometimes you are going to be sitting for hours so the stand might as well be comfortable. You may find 14" X 8" seats.
I have an artificial pre-lit Everstar 7 1/2' slim montana pine tree. One of the screw holes in the base stand is stripped and allows the tree to tilt. Where can I find a replacement stand? The tree...
Call Everstar customer service 1800 833-3390 They do NOT have a website. I think because they are a bunch of retired christmas elves without internet service.
Dec 26, 2010 | Solar Christmas Tree 6 Outlet Foot Switch...
I need to stand 2 poles up on either side of my yard for Christmas I plan to run lights down from the top and I need to support the pole for all of winter it will be about 7-9ft and I will have 16 strands...
A 10 foot stick of 1 1/4" or so of electrical EMT conduit would probably work:
http://www.homedepot.com/Electrical-Electrical-Boxes-Conduit-Fittings-Conduit/h_d1/N-5yc1vZ1xg4Zbohl/R-202068042/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
The conduit is easily driven into the ground using water. Just pour some water on the ground and start working the conduit up and down in the same spot, add more water as needed until the conduit is in the ground 2 or 3 feet.
Purchase one 1 1/4" EMT connector to fit on the top end of the conduit. That connector can be screwed into a 1 1/4" galvanized floor flange from the plumbing dept.
http://www.homedepot.com/Plumbing-Pipes-Fittings-Valves-Galvanized-Pipe-Fittings-Fittings/h_d1/N-5yc1vZ1xg4Zbuue/R-100183709/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Drill the (1/4"dia. or so) 16 holes around the perimeter of the flange for each strand. Maleable iron is easy to drill.
The conduit should be fairly secure by itself but you could use small diameter steel guy wire (14 ga. or so) and some tent stakes for added support. 4 should be enough.
Nov 13, 2010 | Home
Hunting Logo
1,667 people viewed this question
Top Hunting Experts
Peter
Peter
Carl Wiehe
Carl Wiehe
Lloyd Willingham
Level 1 Expert
Are you a Hunting Expert? Answer questions, earn points and help others
