Question about Canon imageRUNNER 5570 Copier
Error code E000840-0001incanon ir 6055 - Canon imageRUNNER 5570 Copier
    New Friend:
My machine canon ir6055 display error E000840-0001 and E00060-0001 i am all so cheek the machine fuser unit last time automatic open the lock fuser i am set the fuser agin problem
and E000013-0001
Posted on Aug 03, 2014
  • 113 Answers
Fixing Shutter Motor error
1. Check the operation of the Fixing Shutter Gear (overload,
etc.).
2. Check the operation of the Fixing Shutter Motor (M15) at
the initialization operation of the Fixing Shutter.
3. Check the detection of the Fixing Shutter HP Sensor (PS53)
(if the Sensor operates normally).
4. Check the drawer of the Fixing Assembly and the host
machine.
5. Replace the Fixing Assembly.
6. Replace the Main Driver PCB (PCB2) (check the fuse
(FU11)).
Posted on Jan 19, 2013
    New Friend:
Posted on Feb 25, 2014
Canon ir adv 6055 error 0748-9000
hi. that error indicates there is a problem with the flash board. you need to get technical support. there is nothing you can do to fix it
Apr 25, 2017 | Canon Office Equipment & Supplies
Canon photocopy machine model ir 6055 system error 000302-0001
Title
Error in paper front shading
Remedy
  1. Connector disconnection/open circuit of the Scanner Unit (Reader).
  2. Connector disconnection/open circuit of the Reader Controller PCB (PCB1).
  3. Failure of the Scanner Unit (Reader).
  4. Failure of the Reader Controller PCB (PCB1).
Description
Error in shading RAM access, or the shading value is either below or higher than the reference level.
Aug 11, 2016 | Canon Office Equipment & Supplies
Replace waste toner IR Adv 6055
You have to replace waste toner bottle,which is full
Jul 25, 2014 | Canon Office Equipment & Supplies
Cannon image runner 6055 E000013-0001 error
i have tried but some time it not work what is the problem it does not completely code not finished
please replay me
Jul 20, 2012 | Canon Office Equipment & Supplies
Error code E000005-0001 cannon ir-adv 6055
I have a problem with my machine,
Canon IR 6570 with error code E000005-0001
beg for a solution
Nov 09, 2011 | Office Equipment & Supplies
Battery code for Salter kitchen scale Model 6055
i needs manuals of calibration of the scale salter model 6055
Aug 23, 2011 | Salter 2001 electronic kitchen scale
I need photo coppier "
I would recomend You the two second hend refurbished iR 3300 Copier ( B&W ) or Ricoh AF 1045/2045 and color clc 3200 for color, for the beginning and if you want later take stronger 50ppm i.e. IR advance 6055 for B&W and IR ADVANCE C2030L.
Hope that helps!
Jul 27, 2011 | Canon imageRUNNER 5000 Copier
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Canon imageRUNNER 5570 Copier Logo
2,398 people viewed this question
old marine
old marine
