How to record from lg lm670t
How do i record onto usb stick or portable hard drive? have tried using the tv guide and selecting record with hard drive connected to usb 1. without success. i have been told by the tv retailer that my hard drive is too big at 2tb,and the max hard drive should be 16gb.or am i doing something wrong when i set up the record mode. thanks Ian
SOURCE: User guide for LG RH1885 HDD recorder and DVD player
I have LG HT 1858 But I can't install the DV to My PC I need the User Gude So don't buy any thing with out the user gude you don't know when you are going to need it....
Mosa'ub
Posted on Jan 01, 2008
  • 4 Answers
SOURCE: Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Posted on Jul 19, 2008
SOURCE: LG RH399H
I've had "Record-blocking signals detected" on my LG RH398H-M recorder off & on since I bought it almost a year ago. Also other minor problems. LG replaced the recorder 4 times with no change in problems. I became suspicious when I found that when these messages came on I could switch to any channel, digital or analog, even the weather channel, and I would still get the same message for about 5 minutes & then everything would be OK again. Recently I finally got the chance to try something. When the message came on I disconnected the input to the recorder and the message still came on! Again, I got the message "Record-blocking signal detected" with ABSOLUTELY NO INPUT CONNECTED to the recorder!!! Of course it's impossible for the recorder to be receiving blocking signals when there's nothing connected to the inputs. I wrote to LG again and threatened a law suit but so far they've been ignoring me. I would like to hear from anyone who can duplicate the above.
Posted on Jul 10, 2009
SOURCE: Connecting my laptop to DVD recorder and recording onto the recor
You FIRST need a way to get the Signal, INTO the laptop, you need to get a USB to TV/Video Dongle, Now using this and the software that came with it, as well as other software, You Hook up the OUTPUT from the DVD Player, to the Video Input on the USB Dongle, Either, Component (Best) or Composite, (OK) Video, and AV Audio, and set to "Record" on the PC, and "Play" the DVD and then the PC will "Record" the incoming signal from, the DVD player, to the HDD in the PC. Once digitised, and saved it can be manipulated, any way you want.
Now if you want to do the REVERSE IE: Take a signal FROM the PC, to the DVD, then you simply setup the DVD as a Second monitor, use a TV to set it all up, once it is all working on the Laptop and TV, simply swing the Output, away from the TV's Input, to the DVD's Input,and select record, the PC, will then output whatever, to the screen, and whatever is displayed on-screen, will be recorded by the DVD's hard drive.
You First though must setup the PC to have multiple monitors, it is best to get the most up to date drivers and install them in the PC. FIRST. Go to this MS link below it shows you how to set u,setup as CLONE mode, I think will be best, also don't set initial resolution too high to start, set it to say 800x600 32 bit, to start, and work up, until your TV complains and stop. As related once setup, swing the PC's output to the DVD, and record.
http://support.microsoft.com/kb/307873
Posted on May 08, 2010
SOURCE: Unlock LG DP450 DVD
hi its a bit late but someone might benefit from this. Make sure that u CLOSE dvd cover.
To multizone:
Make sure that there is no disk in. CLOSE dvd cover. Press power on on remote. if dvd goes into standby press power again. unit will be searching for a disk. as soon as player says NO DISK (heres where u have to guess since the bloody thing is closed) press PAUSE then press 314159 in quickly. Now open and voila the screen will read current region whatever...next press 0 then PAUSE and finally Power key. it worked for me after trying a billion times the 314159 thing.
Posted on May 19, 2010
I have a sum vision 2.5 sata to usb hard drive i want to record from my lg tv on to it but nothing is showing up please help
Think the USB has to be fat32 in order the tv recognises it.you are better off with USB stick or sd card for that sort of thing
Dec 04, 2014 | Computers & Internet
Why can't my Panasonic DVD recorder read my portable harddrive? I want the DVD record to read the harddrive?
hi anonymous, it may well be that you need to change settings on your DVD Recorder and/or on your TV. On my LG 42" TV I need to select the input mode ie. Movie, USB, music etc, as necessary. Maybe your DVD Recorder or TV can't handle the file format on you Portable Drive, check the manufacturer specs.
Jun 08, 2014 | Panasonic DMR-EZ47V DVD Recorder/VCR
HOW DO I RECORD USING USB STICK ON MY TCL TV
go into the tv guide menu and there should be a option to record
Jun 02, 2014 | LG Tcl L40fhdf11ta Tv Part Main Board...
Does a baird tv have usb ports
try to google it and type specs after brand and model;
Jan 17, 2013 | Televison & Video
I want to turn a memory stick into hard drive. How can i do that?
you will need usb data drive at least 4 - 8 gb
Download the GParted Live utility and the HP USB Format Tool via the links in Resources.
http://www.majorgeeks.com/downloadget.php?id=5757&file=15&evp=fb0a8fee133295405b5af3205e8d2424
Insert your USB stick into the computer. Run HP USB Format Tool. Select your USB stick and then choose the FAT or FAT32 format options. Click "Start."
Extract the files from the GParted Live zip file. Select the USB stick as the destination.
Open a file browser and navigate to the USB stick. Select "utils" > "win32" > "makeboot.bat." Double click on "makeboot.bat." Enter "Y" when prompted.
Power off your computer leaving the USB stick inserted.
Connect your portable hard drive to another USB port.
Power on the computer and quickly press "F8" through "F12" to access your boot menu.
Check your computer or motherboard manual for the exact keystroke.
Select the USB stick as your boot source and press "Enter." Allow the Gparted GUI to start.
Select the external portable hard disk drive. Click "Partition" on the menu bar.
Hover over "Format to" and select "NTSF."
If you are unable to create or format the partition, select delete partition.
This will erase all data on the external hard drive. Confirm partition deletion. Select the external drive again. Click "Partition" and hover over "Format to" then select "NTSF."
Select the external hard disk drive again. Click "Partition" on the menu bar and then "Manage Flags." Check the box next to "Boot." Save and apply changes to the drive.
Power off your computer and remove the USB stick.
Install the OS
Insert or plug your OS installer, usually a DVD, CD or USB thumb drive, into the computer. Power on the computer and access the boot manager again.
Select the source containing your OS installer and press "Enter."
Enter your personalization and registration information if required.
When prompted, specify the portable hard drive as the install directory.
Begin the installation normally.
Restart the computer when prompted and access the boot menu again. Select the external hard drive as your boot source and press "Enter" to ensure the installation succeeded.
Use this process to boot from your portable drive on any computer.
hope this helps
Oct 02, 2012 | Sony Vaio VGNBX196SP
How to tranfare recordings onto a usb
transfer a recording onto a USB stick ,quite simple right click on the item to transfer then it will come up with a list of what you want to do like copy to cd or another hard drive or the USB providing its plugged in it will show as the name of the USB stick or drive whatever letter the computer affixes to the drive ,simple well it should be
Dec 10, 2011 | Lorex SG19LD804-161
Having saved files onto my iomega harddrive - how do i re instate files onto laptop
if the hard drive you saved the files to is separate to your laptop you can use a usb portable drive to copy these files to then plug the usb drive into your laptop to finish installing them by selecting the file right click to open
hope this helps
Sep 03, 2010 | Iomega eGo160GB External USB 2.0 Portable...
Recording on the Meos 20'' LCD-DVD Combo 2009 model
YOU CANT RECORD FROM A SCART TO USB, THE SCART IS IN ONLY AND ANALOGUE. YOU SHOULD HAVE A USB PORT ON THE TV TO PLUG IN YOUR STICK OR PORTABLE HARD DRIVE
Aug 31, 2009 | Televison & Video
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
Electro Med Services...
