No auto fan when heat is on.
When the heat is on and the blower is set to auto, the blower does not work but if I set the blower at the thermostat to the on position the blower works and the heat also.
  • 146 Answers
Check to see if the t-stat is set for gas or electric. should be on the back of t-stat
Posted on Jan 25, 2009
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
What is difference between on an auto on thermostate
I'm not sure exactly how this applies specifically in a car, but on a home heating and cooling (air conditioning) thermostat, it is often associated with the fan or blower setting.
If for a system fan:
"Auto On" setting in a heating / cooling system would start the fan when the temperature climbed above or dropped below the setting you on the thermostat and start the heat or cooling source. Once the thermometer indicates the desired temperature had been reached, the heating / cooling source would be stopped and the fan would turn off.
"On" would run the fan all the time, regardless if the thermostat tired to start the heat or cooling source. This would result in constant circulation of the air in the space(s) and tend to keep warm or cool spots (rooms) from being created.
Nov 30, 2015 | Cars & Trucks
Eb20b/ electric furnance/ blower wont shut-off after heat kicks out, got to kill breaker , runs all the time, installed new thermostat, no change?????? Its cold??????
Check the thermostat and make sure the fan switch is set on "Auto". If it is set on "ON" the blower will run constantly.
Jan 31, 2015 | Heating & Cooling
Honeywell tstat not working in auto cool mode
so with system setting cool/ fan setting auto, the condenser runs but the indoor blower does Not? but when system setting cool /fan setting on, the condenser runs and the blower runs?
Oct 25, 2017 | Honeywell Electronic Programmable...
My Goodman air handler blower will not turn on when Thermostat is on auto fan. The blower comes on when themostat is set on fan-ON. The thermostat has be replaced, also the capacitor, and the BTDR. The...
Hello,Next is make sure the thermostat is set for ELECTRIC heat.In the back there is a dip switch or sometimes a small jumper that MUST be set to ELECTRIC setting.It will give a choice GAS/ELEC it needs to be set ELEC to bring on the BLOWER on a call for heat.It doese'nt matter if you have gas or oil or wood for fuel.
Nov 01, 2010 | Heating & Cooling
Blower cuts off when compressor comes on. Blower
Try the fan"on/auto"function switch at the thermostat when the compressor is on.Set fan to on.Does blower run?
Mar 19, 2010 | Coleman Heating & Cooling
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Nov 02, 2009 | Heating & Cooling
I have an intertherm electric furnace FEH-A020, with multispeed blower installed when A/C added. My problem is blower operation. at the end of the cooling season with fan set to auto operation the fan ran...
The model of T-stat you gave comes up as a discontinued model on Honeywell's web site, but it looks to be a manual stat that type of stat would have to be wired with a summer winter switch with electric heat, allowing it to turn on the fan with a call for heat. If yours is a programmable T-stat you would need to select electric heat or in the installers set up change the default setting for fan from unit controls fan in heat to thermostat controls fan.
Oct 17, 2009 | Intertherm P3RA-048K Air Conditioner
Rheem heat pump. blower will not turn off
The fans are set to delay for 60-90 seconds to remove all heat from the heat exchanger/heater elements.
If the fan runs any longer than 3-4 minutes after the Emergency Heat shuts off, you may have a bad sequencing relay in the air handler.
Jan 27, 2009 | Heating & Cooling
Furnace comes on and off
If fan is set to auto mode that's how it will work.Fan would only run when heat is on
Feb 18, 2018 | Heating & Cooling
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
