Question about Sport & Outdoor - Others
If a player gets hit with a paintball that doesn't break, is he still out?
Simple if it breaks your out if not you're still in .. If you're not sure then just ask the ref to check you
Posted on Oct 21, 2013
    Problem Solver:
  • 17 Answers
In most paintball games and tournament play, a paintball impact but non-break is non-elimination. It is good sportsmanship to call out "bounced" or "didn't break" if he/she is hit but does not receive paintball splatter.
Posted on Jan 17, 2013
Paintball gun
Paintball guns that are semi-automatic are generally more reliable and rugged than their electronic counterparts as they have a smaller number of moving parts. They are particularly preferred by beginner and intermediate level players who are discovering how to play the game, relying on a reliable gun rather than player skills. To get the guidance you may look on to Paintball Gun Buying Guide.
Jan 18, 2014 | Sport & Outdoor - Others
Spyder sonix pro paint ball gun shoots but when i shoot fast the paintballs break why and how do i fix it
You can read the reviews here, it may help you figure out the issue:
http://www.pbreview.com/products/reviews/4233/
Feb 08, 2013 | Kingman Spyder Spyder Sonix Pro Vertical...
In Paintballing what is the difference between nitrogen (N2) and CO2 tanks?
CO2 tanks are composed of liquid carbon dioxide and are used for many scenario and recreation players. When the trigger is pulled, the liquid CO2 is converted to a gas, and this expansion of gas propels the paintball forward at 800-850 psi. CO2 tanks do not work as well in colder weather or for fully automatic paintball guns
Jan 17, 2013 | Sport & Outdoor - Others
Is paintballing dangerous and will it hurt if I get hit buy one?
. It may sting a bit if you get hit by a paintball and you may end up with a few bruises. You should ensure that you wear the protective clothing that is required and observe the safety precautions.
How many players are needed to get a proper game in paintballing?
To get the best results you should play with at least 3 players on each team.
Jan 14, 2013 | Sport & Outdoor - Others
When i installed my radio its reading usb error
hit done? But first read through the manual and see if there is any sort of initiall startup procedure. (unlikely)
Then try checking all connections. If that doesn't work, unplug, check for the right connection ports, and replug everything. If it still doesn't work, take it to a professional or return it and buy a new one, it could just be defective.
May 01, 2012 | Kenwood DNX7100 Car Video Player
My New Home sewing machine has been in storage for 2 years. When I press the pressure foot, the motor just hums. Can you help me?
try oiling the machine, since you took the machine apart oil it, use only sewing machine oil, usually you can get it at a fabric store or I think wal mart sells some too.
oil the machine,, let it set for a couple of hours,, put paper towel or old towels under neath the machine because of the oil dripping
then try to turn the handwheel back & forth,, putting slight pressure but not heavy,, DO NOT FORCE IT
if it doesn't break loose oil it again & let it set another couple of hours
then try to turn the handwheel again like before
if that doesn't work then get a can of penetrating oil, & use that,, then wait a couple of minutes & try the hand wheel again & after it breaks loose then be sure to oil it again.
let me know if it helps you
Mar 30, 2012 | Sewing Machines
My needle keeps breaking. So I unthreaded everything and cleaned the bobbin area. Per the manual i rethreaded everything but when i get to the part of turning the balance when toward me until the needle...
check to make sure the needle is inserted correctly--flat side to the back of the machine
that the needle is inserted all the way up in the needle shaft
check the needle clamp screw to make sure it's not loose
is the needle correct for the fabric that's being sewn
check to make sure the needle is not hitting the needle plate- if it's hitting the needle plate or the bobbin case then it's possible the machine is out of time & would have to be serviced because they have the proper tools to time it
Aug 26, 2011 | Brother LS-2125 Mechanical Sewing Machine
Do I have to take the gun apart to get the battery in the gun??? and also before i was done with the gun my brother put the paintballs in the hopper but for some reason they were falling out of the...
No, you didn't do anything wrong...
Paintballs come in a variety of sizes. That difference is very hard to see with the naked eye, but your barrel knows what fits and what doesn't. Players have a choice in barrels and ID-internal dimensions, so the balls are various sizes as well. You will have to sample a few brands and see what works best for you.
Play hard, play safe, play with honor!
8^)
Nov 03, 2010 | Tippmann 98 Custom Act Paintball Gun
Paintball gun is rapid firing when trigger is pressed. CO2bottle is full and i have tried other bottles but stillth same.
Tippmanns are known for their reliability and are very simple markers making them very easy to repair. you need oil from a local paintball shop or regular sewing machine oil will do.
On one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns, if not..
Sometimes paintballs can break inside your gun. Look and feel inside your breech (where the paintballs go into the gun) and check for paint. If its dirty this can be causing your problem, strip it down and clean it (refer to your manual if you have difficulty)
on one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns
Jan 08, 2010 | Tippmann 98 Custom Act Paintball Gun
Sport & Outdoor - Others Logo
423 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
