Question about Sport & Outdoor - Others
In Paintballing what is the difference between nitrogen (N2) and CO2 tanks?
    Problem Solver:
  • 17 Answers
CO2 tanks are composed of liquid carbon dioxide and are used for many scenario and recreation players. When the trigger is pulled, the liquid CO2 is converted to a gas, and this expansion of gas propels the paintball forward at 800-850 psi. CO2 tanks do not work as well in colder weather or for fully automatic paintball guns
Posted on Jan 17, 2013
Sometimes hard to start, then when driving the car will lurch and wants to die
its your catalytic converter (colloquially, "cat" or "catcon") is a vehicle emissions control device which converts toxic byproducts of combustion in the exhaust of an internal combustion engine to less toxic substances by way of catalysed chemical reactions. The specific reactions vary with the type of catalyst installed. Most present-day vehicles that run on gasoline are fitted with a "three way" converter, so named because it converts the three main pollutants in automobile exhaust: an oxidizing reaction converts carbon monoxide (CO) and unburned hydrocarbons (HC) to CO2 and water vapour, and a reduction reaction converts oxides of nitrogen (NOx) to produce CO2, nitrogen (N2), and water (H2O).[1] The first widespread introduction of catalytic converters was in the United States market, where 1975 model year gasoline-powered automobiles were so equipped to comply with tightening U.S. Environmental Protection Agency regulations on automobile exhaust emissions.[2][3][4][5] These were "two-way" converters which combined carbon monoxide (CO) and unburned hydrocarbons (HC) to produce carbon dioxide (CO2) and water (H2O). Two-way catalytic converters of this type are now considered obsolete, having been supplanted except on lean burn engines[citation needed] by "three-way" converters which also reduce oxides of nitrogen (NOx).[2]
Catalytic converters are still most commonly used in exhaust systems in automobiles, but are also used on generator sets, forklifts, mining equipment, trucks, buses, locomotives, motorcycles, airplanes and other engine-fitted devices. They are also used on some wood stoves to control emissions.[6] This is usually in response to government regulation, either through direct environmental regulation or through health and safety regulations.
Catalytic oxidization is also used, but for the purpose of safe, flameless generation of heat rather than destruction of pollutants, in catalytic heaters.
Oct 15, 2012 | 1995 Buick LeSabre
I have response trigger on my a5 and only shots one shot at a time when pointing straight. When i raise the gun to the air and shot it response trigger works. What could be the problem?
If you are using CO2 it may be affecting the system. With a gun down straight, you could draw liquid CO2 into the internals. A siphon tube can be installed in a CO2 tank to stop or manage this. If you have access to someone's air tank, try using HPA (high pressure air aka nitrogen). If it fires fine with air you have deducted that the CO2 is to blame. Simple. Switch to air. It's better for the gun anyway! Now if the air didnt change anything I would think a component of the response trigger system is to blame. I am not familiar with the response trigger( I use E-grips) but I would think that a part that may slide or move forward or bak when you lift the gun up would be to blame. Most local shops should be able to diagnose the problem. I did find an installation video by Tippmann on youtube.
Here is a link.
A5 response kit installation
Mar 31, 2011 | Tippmann A 5 Standard Paintball Gun
Which gas is the most poisance in the earth
Nitrogen (N2) is the most abundant gas in the Earth's atmosphere having percent volume of 78.8 compare to Oxygen 20.95 %, which falls on the second place after Nitrogen.
Jan 29, 2011 | Cell Phones
The automatic feed system is not working. I have to pull the manual feeder lever to load one paintball. It will fire one ball but I have to pull the lever again.
Couple of things.. the A5 is a wonderful marker, got a couple myself.
Make sure it's clean in there. You probably can't see under the bottom of the feeder into the mechanism. If paint gunk and dirt get in there, then it may not be able to turn.
If it's beyond that, there's a cog in there that is key to turning the feed mechanism and can break. But if you can cycle it by hand then that may not be your problem.
Is it only later on when you're playing? Pressure is important here because not only are you propelling the ball out the marker, and working the internals, you are also pushing the feed mechanism for each shot and if there's not enough pressure you won't get that auto-feed.
Try a full tank and see if it works better. Try a different tank than you're currently using. Try nitrogen/compressed air if you're using co2. Variations of a theme here if you couldn't tell.
Good luck.. if that doesn't identify your problem, a quick trip to your local Tippmann certified airsmith should get it back into shape in short order.
Play hard, play safe, play with honor!
8^)
Dec 26, 2010 | Tippmann A 5 Standard Paintball Gun
Just need a dot diagram for these molecules N2 and O2
What is the atomic-weight for N (Nitrogen)? For oxygen?
The atomic-weight determines the number of protons in the nucleus of the atom, and the number of electrons at each level.
Oct 28, 2010 | Computers & Internet
Is all gases are lighter than air?
Hello and Welcome to FixYa!
NO, not all the gases are lighter than air.
Neon, Hydrogen fluoride, Water (steam), Carbon monoxide, Ammonia, Nitrogen, Hydrogen cyanide, Methane, Ethylene, Acetylene, Methllithium, Diborane,Helium,Hydrogen are Lighter than air.
While; Arsine AsH3, Nitrogen dioxide NO2, Carbon dioxide CO2, Chlorine Cl, Fluorine F are Heavier.
Jul 29, 2010 | Computers & Internet
I have a 1994 chevy work truck with a 305. I have trouble codes # 15, 22, 33, 34, 44, and 53. The egr valve had been removed but apeared good. Someone had put a plate over the port. Additionaly someone...
DTC - 15 Engine coolant temp sensor error (low temp indicated)
DTC - 22 Throttle position sensor error (signal low)
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
DTC - 34 MAP sensor circuit error (signal low indicating high vacuum)
DTC - 44 Oxygen sensor error (lean condition indicated)
DTC - 53 Digital EGR Valve solenoid 1 error
MAP is short for manifold absolute pressure sensor,,it senses the manifold pressure and applies the right amount of gas with the right amount of ignition timing so the car runs and performs well if this does not work properly,it throws off the whole loop cycle for the computer,,which in turn makes it run badly,,and get poor fuel economy,,it causes one to have a lack of power,,combined with a loss of fuel economy,,and also poor take offs,,and sometimes an occasional stalling,,i hope this helps.
EGR system was really developed for was emissions control. the purpose of the EGR valve is to regulate the amount of exhaust gas recirculated back into your combustion chamber to send the gasses through another cycle in order to eliminate any excess pollutants like NOX (nitrogen oxides), N2 (nitrogen), O2 (oxygen), CO2(carbon dioxide) and HC (Hydrocarbons). the EGR was also developed to lower combustion temps that's another reason why the exhaust is recirculated the exhaust gasses will not burn therefor lowering combustion temps, because there is less "usable" air going into the cylinders.
Nov 17, 2009 | 1994 Chevrolet C/K 2500
What are the symptoms of a bad egr valve ina 1994 geo tracker?
this may help
EGR Theory. EGR serves one purpose and one purpose only. That purpose is to reduce Oxides of Nitrogen (NOx). Undernormal combustion, Nitrogen(N2)Oxygen (O2) in the air and Hydrocarbons (HC) in the fuel combind into water(H2O) Carbon dioxide (CO2) and the Nitrogen remains unchanged. Under very hot combustion temperatures, the Nitrogen reacts with the other two byproducts and forms Nitrogen oxide (NO). After being released into the atmosphere, it picks up another Oxygen and becomes Nitrogen dioxide (NO2). In the presence of sunlight,
it combines with other compounds like Hydrocarbons and forms Smog. Since exhaust gas is inert (very stable) it doesn’t burn again. So by being introduced into
the combustion chamber, it will lower combustion chamber temps enough so that
the Nitrogen doesn’t react with the other compounds and is passed unchanged out
the tailpipe thus not contributing to smog. Now, since exhaust gas doesn’t burn, it
doesn’t exactly help with combustion. At higher RPM’s, this really isn’t noticable,
but at idle, the reintroduction of exhaust gas will cause a very rough idle and can
cause stalling if to much is introduced into the combustion chamber
Feb 01, 2009 | 1996 Geo Tracker 2 Door
Sport & Outdoor - Others Logo
450 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
