Question about Cycling
What type of brakes is better, rim brakes or disk brakes?
  • 3 Answers
Don't forget to factor in your weight, riding style, type of bike, even the climate you'll mostly be riding in. If, for example, you ride in Canada in winter (or even Northern Europe in summer!) you might welcome the extra confidence the stopping power of discs can bring. For me the slight weight penalty is a price well worth paying for the predictability and reassurance in harsh conditions. For whippets on carbon fiber ultra lightweight racing machines or even general cyclists on hybrids etc, disc brakes make very little sense, and global travellers and cycle tourists, who might find themselves in remote parts of the world where spares are hard to come by, tend to favour cantilever brakes. Really, it's horses for courses and only you can decide what is most appropriate for your intended use.
Posted on Jan 13, 2014
  • 29 Answers
Depends on the type of bicycle you have. Disk brakes come as standard on mtn bikes these days. The best are hydraulic actuated. The others use cable. Disk brakes are powerful and are the leading cause of people going over the handlebars because they don't use them with the rear brakes properly. Road bikes have rim brakes, some better than others. The best bikes and rim brakes are almost as good as disk brakes. Disks are being developed for road bikes but have struck some problems. Not the least being weight and increased torque twisting the wheels. As with any type of brake, the performance is more a factor of maintenance than anything else.
Posted on Mar 02, 2013
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 78 Answers
In general: for nuances and more consistent powerful brake throughout all conditions, you should prefer disk brakes. However you may want to know that they are a little heavier than the rim brakes. If you prefer lower price and lighter set, however you are willing to compromise a little on performance, go with the rim brakes.
Posted on Jan 17, 2013
What rims will interchange with ford tarus car rims from other cars
HRE, American Racing, BBS, Borbet, and OZ, et al, make rims to fit your car. American Racing has the biggest selection. HRE are the better of US made rims. Borbet, BBS, and OZ are pricey and made in Europe. Einkei are Japanese rims and equivalent in quality to OZ, certified for street racing use. HRE and American Racing provide catalogs online that allow you to insert your car make and model to see what fits properly. (Brembo calipers are the largest, so when a rim mfr states that their rims are Brembo compatible, it means there is plenty of room so the disc brake calipers won't rub the rims. ) Other good calipers are AP Racing and Galfer; Galfer for cars is only available in Europe. Never use ceramic disc brake pads on slotted rotors, they aren't designed for them... use cross-drilled or solid high quality rotors with ceramic pads for superior braking.)
Mar 21, 2015 | Ford Taurus Cars & Trucks
Rear brake not releasing
I'm assuming these are rim brakes and not disk brakes. A couple things can cause this, first check to make sure the wheel is true and the rim isn't rubbing on the brakes as it rotates. Next check that the brake pads are not hitting the tire when applied. If they are, then the brake pads need to be adjusted to contact only the rim. If they still aren't releasing then the brake cable could be corroded enough inside the brake cable housing that the spring in the brakes can't return it. drip a little bit of oil (TriFlow works great) on the cable where it enters and exits the housing and work the brakes. If this doesn't work then the brake calipers could have some corrosion on the canti-lever posts (assuming these are V type brakes common to a lot of mtn bikes), a little oil might get them moving again. If the bike is normally stored outside then most likely it's the cable corrosion.
Jun 11, 2014 | Huffy Men Mountain Bike (26")
I have a f800gs bmw.floating disks on front wheel very loose and is irritating.Could the 650 daker front disk be fitted on my 21" front rim?ineed to fit two.
Is irritanting where applying the brakes? Or just because are loose when you touch them? If is the second one is normal for disks to move a little. If braking is not affected don't worry. Just check the disks with some gloves after a ride when the brakes are hot. You will see that the disks are tighter than cold.
Oct 18, 2013 | Topcase Rack BMW F650GS, 08- & F800GS, 08-
Replace and adjust brake pads
Is this disk or brake blocks like cantilever or vbrake. I have disks now b ut have never messed with them. If it is not disk then I would just say to make sure that the rear part of the pad hits the rim first. Fine tuning is done by adjusting the turn buckle where the cable goes into the lever. Set the brakes so that when you are pulling hard on the brakes, on dry pavement, set the brakes so that they only get tight enough to not quite lock up. And make sure you use both brakes at the same time. Not just one or the other. adjust the pads by putting one or two dimes between the pad and rim. There are also adjustment screws on the brake arms that control spring tension and in the end the alignment of tire between the brakes. You want the same space between pads and rim on both sides. If they squeal because you have been riding with poorly adjusted brakes take a file to the pads to level them out. Thy will grab better after this. Hope it helps
Apr 08, 2011 | Fuji Cycling
How do I adjust the brakes
This brake mechanism has a Lock/Adjuster nut which holds the brake arms together but it is also to adjust them too.....Just hold the brake unit with hand and break the nut loose....loose enough that you can move each brake pad arm seperately but not to loose.....Then squeeze the arms inward until the pads almost touch the rim then tighten back up...this action moves the pads closer to the rim to stop better faster.....Hope this helps..........Metalpoet..........
Apr 05, 2011 | Pacific International Pacific Exploit...
How do you adjust front cable tension, the front brake pads are a bit away from the rim
The sleeve surrounding the outer cable where it exits from the brake lever mechanism is usually a screw adjuster. Turn anticlockwise to bring blocks closer to rim.
Oct 31, 2009 | ProMax 197NC Bmx V Type Brake Set, Rear,...
Bicycle brake screech
it needs a kind of greeze or oil on the parts that are screeching.
Sep 09, 2009 | Cycling
I want to improve grip to 0.90g on my 08 infinity fx35 n reduce my braking time to 119-125ft from 60mph. is it possible & what would require? also reduce my 0 to 60 time without tempering too much with...
buy upgrade brakes, the stock tires will do the job, a simple upgrade that helps is vented/drilled disk brake rotors, from there u cqan install big brake kits but they are very pricey, into the $1000's
Aug 13, 2009 | 2008 Infiniti FX35
For a 99 ply neon does it have rotors or calibers?
Not knowing exact model, you probably have Disk brakes on front & drums on the rear. Possibility of disk on rear too. As far as rotors & calipers go, which I believe you are referring to, you will for sure have both on the front disk brakes. Rotors are the part that turn with the wheel, & calipers are the part that hold the brake pads & squeeze (for lack of better words) the rotor for stopping.
Jan 16, 2009 | 1999 Plymouth Neon
Cycling Logo
679 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
