Question about Sport & Outdoor - Others
Does the paint come out of you clothes when paintballing?
    New Friend:
  • 15 Answers
Paintballing bullets are made with water soluble paint, which means it should come out of your clothes; however I suggest that you wear old clothes and not your best designer gear to ensure that you don't ruin anything.
Posted on Jan 17, 2013
Paintballs keep blowing up in my tippmann 98 custom HELP!
it could be a combination of a number of things.. most likely it has to do with the type of paint you're shooting; in regards to shell.. tippman guns are harder on paint therefore require a harder shell paint, also not all paintballs are exactly .68 caliber, meaning some a bigger and some are smaller.. could be that they're slightly to big for the bore of you barrell
Feb 13, 2013 | Tippmann 98 Custom Act Paintball Gun
Spyder sonix pro paint ball gun shoots but when i shoot fast the paintballs break why and how do i fix it
You can read the reviews here, it may help you figure out the issue:
http://www.pbreview.com/products/reviews/4233/
Feb 08, 2013 | Kingman Spyder Spyder Sonix Pro Vertical...
Is paintballing dangerous and will it hurt if I get hit buy one?
. It may sting a bit if you get hit by a paintball and you may end up with a few bruises. You should ensure that you wear the protective clothing that is required and observe the safety precautions.
Jan 17, 2013 | Sport & Outdoor - Others
How do I adjust accuracy, I think it involves the screw on the left side.
Accuracy is not adjustable with the screw on the side of the gun, that screw would be the velocity screw and should not be played with unless chronographing the gun to avoid setting it at unsafe velocities.
If you'd like better accuracy there are 2 upgrades you can make. #1 is higher grade paint. The more round and smooth the balls are, the more consistent and tighter the grouping will be. #2 is barrel. The closer the bore matches the paint, the more consistent and tighter the grouping will be also.
May 31, 2011 | Tippmann 98 Custom Act Paintball Gun
Paintballs popping before leaving barrel
Well, covering the holes shouldn't cause the paintballs to burst like that. I'd make sure there isn't some aberration in the barrel but that may be hard to tell. Clean it thoroughly and hold it up to a light and see if you can see anything in the reflections inside. You can try to get someone to hone the barrel just a bit to see if that helps get rid of any small aberration(s).
You can try another brand of paint. The one you're using may be a bit brittle, or just around a while and brittle.
Also, check your chrono speed. Make sure it's not cranked up so high it's busting the balls.
You might try another barrel, but would be nice to see if you can fix this one eh. I'd try some other paint first after cleaning the barrel thoroughly.
Play hard, play safe, play with honor!
8^)
May 21, 2010 | Real Action Paintball Spyder MR1 Universal...
98 Custom Act Paintball Gun: i want it to go fasteer...
I can take that a couple of ways. Do you mean you want to fire more balls per second or you want the paintballs themselves to fly faster?
If you want to fire faster, make sure it's clean and properly lubed with a quality oil that made for paintball. Practice makes perfect and fire that ****** as often as you can, even without paint (that's cheaper!) so you can get your trigger finger in shape.
There are custom mods to the trigger, or you can buy a trigger that's smoother or a shorter pull. There are electronic trigger assemblies that make firing faster even easier.
If you're talking about making the balls fly out of the gun faster, that would be the "velocity adjustment". Your user guide shows you how to make that adjustment and which direction is up, and which is down.
A good suggestion is to check out a local field or paintball store, or an airsmith and they can give you some definite ideas you will want to pursue.
8^)
May 17, 2010 | Tippmann 98 Custom Act Paintball Gun
Paintball gun is rapid firing when trigger is pressed. CO2bottle is full and i have tried other bottles but stillth same.
Tippmanns are known for their reliability and are very simple markers making them very easy to repair. you need oil from a local paintball shop or regular sewing machine oil will do.
On one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns, if not..
Sometimes paintballs can break inside your gun. Look and feel inside your breech (where the paintballs go into the gun) and check for paint. If its dirty this can be causing your problem, strip it down and clean it (refer to your manual if you have difficulty)
on one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns
Jan 08, 2010 | Tippmann 98 Custom Act Paintball Gun
Sport & Outdoor - Others Logo
355 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
