Leak from bottom of LG WM2277HW washer
Tonight I noticed under my front loader washer. I pulled it our from the wall and noticed it looks like it has leaked in the past. I traced the small water trail to under the machine and on top of the attached drawer. As a result of the drawer, I cannot see any further to determine if it can even leak out of the bottom. Any idea what this might be? I am about ready to give up on front loaders!
Thanks.
  • 2 more comments
  • qposner Feb 01, 2009
    I cannot find any leaking at all.However, there is one for sure. I am going to take the machine off of the drawer and take a look since the water is coming from between the machine and the drawer pedestal.
    I cant remove the pedestal due to the sticky substance used to adhere the support plate to the washer. I dont want to wreck it. However, it appears that on the bottom of the machine is a round metal piece that comes out from the plastic and nearly touches the top f the pedestal. It looks like the leak is comg from under that. Thoughts?
    I see the leak. I started a cycle and it is coming out of the back corner below the drain hose. Its not the drain hose. It is coming from outside of the washer case itself and on top of the pedestal. There is a round deal that has styrofoam. It is really coming out of te styrofoam.
  • qposner Feb 03, 2009
    Thanks. Guess I need to find an LG repair guy in Portland, OR.
  • 112 Answers
Diconnect the washer from the power supply.
Look at the back and you will see a few screws holding the top of the machine on.
Undo these screws and lift the top off by sliding it backwards a couple of inches.
You will then see where the leak is coming from(look for white residue).
Please let me know what you find
good luck
Posted on Jan 25, 2009
  • Steve Draper Feb 02, 2009
    Sounds like the drain pump has failed, or is leaking.
    They do a lot of work for the size of them.
    Coins can bust them.
    They are not user servicable.
    They are easy to replace. Just make notes of where any wires go etc.
    Cost around $25.
I have a lg tromm wm2277hw washer Why does it leak soap down to the front of the washer
in my experience you would be much better off using powdered detergent instead of liquid. it will stop leaking down front and will not leave residue in tub that eventually leads to mold mildew issues.
Jul 18, 2015 | LG Washing Machines
I have a LG WM2277HW front loader washer . The door doesn't close all the way. It locks, but is kind of loose. I don't get any error messages, and it cycles fine(washes fine), but as soon as it starts...
If it is physically possible on your machine I would suggest that the door catch need adjusting, either that or it's broken but the door sensor still thinks it's OK ;-0)
Suggest a service call required ;-0)
Sorry,
John C
Mar 02, 2011 | LG WM-2277HW Front Load Washer
My LG tromm wm2277hw front loader just turned off, can it be a switch, there's power in the outlet, no lights, circuit board is off, no water underneath, dryer is ok plugged in the same outlet,
That could very well be the line voltage suppressor (called a noise filter) that is built into the washer. Take the top off and follow the power cord into the machine. It connects to this component. themobilian_17.png
PAGE 22
Feb 06, 2011 | LG WM-2277HW Front Load Washer
Does a pedestal for the 2005 LG WM2277HW fit the newer models of LG Front loaders?
Yes, it can be used, but the fastening system for pedistal to washer is much better with the new pedistals.
Jan 25, 2011 | LG WM-2277HW Front Load Washer
LG Tromm Front loading Washer, wm2277hw -detergent tray will not pull out.
I've got the same issue!! I can't get it open it must be jammed from the tray inside!
Aug 16, 2010 | LG WM-2277HW Front Load Washer
My LG washer wm2277hw does not drain water and
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | LG WM-2277HW Front Load Washer
Replace door gasket lg wm2277hw
Hiya,
you can find spares for this machine on espares i think the gasket will be a universal one but here is a link for you to check
http://www.espares.co.uk/parts/lg/p/0/81?k=wm2277hw+door+gasket
Please note i have not used this site before but i have noticed that they will deliver to most countrys & im sure they will be able to help with a fitting tool issue if you contact them.
Hope this helps
Apr 20, 2010 | LG WM-2277HW Front Load Washer
Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Jul 27, 2008 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
378 people viewed this question
Top Washing Machines Experts
