Question about Kitchen Ranges
How to clean the filters for an ATAG domestic cooker hood
Have just moved moved into a new house and the washable removable filters on the cooker hood are full of grease. I have put them in the dishwasher them on the hottest setting, soaked them in concentrated detergent and hot water and brushed them with a fine brush but grease is still there. Does anyone know the solution or have any more ideas e.g. can I try caustic soda (the edges of the filters look like aluminium but I don't know what the filters are made)
  • 1314 Answers
SOURCE: F60 SS Cooker hood
short in light switch
Posted on Dec 30, 2007
SOURCE: Neff cooker hood
the manual i have says that the charcoal filters inside need changing about every 6 months. take out the grease filters then you should be able to turn it and take them out. you may not have these if the extractor vents to the outside. the grease filters can be cleaned with a neutral detergent and then put back in. Make sure the electric is off before you do any of this. Hope this makes sense and helps!
Posted on Jul 17, 2008
SOURCE: hoover F7431-900 steam vac brushes wont work
the brushes are activated by suction, my berings and gears froze up, i took it apart, kinda hard to figure out, but not as bad as it looks. i lubed the berings and the gears, then i took an air compressor to the activation fins and let it spin, lubed again then hit it with air again, now works better then new.....GL
Posted on Jul 29, 2008
SOURCE: Removal of cooker hood to locate electric plug
Thank you for your letter, we had to dismantle the whole cooker hood to get to the electric plug.
Thank you.
Posted on Jan 19, 2009
  • 105 Answers
SOURCE: Where do I put the charcoal filter?
It would fit over / into where the other filter goes the charcoal filter is to help eliminate more smoke and grease
Posted on Feb 10, 2009
How to clean washable filters?
To clean the washable filters you need few things like a stool, screwdriver, brush for cleaning, vacuum with attachments and running water. Cleaning the air filters regularly will keep you away from different type of allergies which are caused by fungi, molds and bacteria.
Sep 30, 2014 | Water Dispensing & Filtration
How do you clean the filter?
Hi, it's Allie from Crucial Vacuum!
Many units nowadays include a washable reusable filter. If your unit's filter is washable, it is very easy to do so.
First, start by unplugging your unit before removing the filter. Make sure not to use your unit without the filter this can permanently damage your vacuum. After removing the filter, you may want to step outside to gently tap off the dirt from the filter and avoid the dirt to be spread inside your house. Using cold-lukewarm running water, rinse the outside surface of your unit's filter, do not use soap. Allow your filter to be air dried for 24-48 hours before placing it back into your vacuum. Using a damp filter may also damage your unit.
If your filter is NOT washable, it will be adversely affected if you wash it and it is better if you replace it instead.
You can purchase direct your replacement filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
http://www.crucialvacuum.com
Aug 16, 2014 | Kenmore Vacuums
HI, I have lost my manual and just want to know how to clean all the filters. Are the hepa filters washable? thanks, Marcia
Hepa filters are not washable. They must be replaced with new ones. You can order new ones from the manufacturer or buy them from the retailer you purchased the unit from.
Jun 08, 2011 | Health & Beauty
How many filters does a dyson dc07 have
Hi there, the DC07 has 2 filters. A pre motor washable filter and a post motor filter which will be either a simple pad (like thick cloth) or a Hepa filter (about and inch thick with a plastic housing). The post motor filter should not be washed but the pre motor filter can. As a technician I would recommend replacing every couple of years for best running of your vacuum. The post motor filter is under the clear bin, you can lever the cover off with a small flat blade screwdriver. The washable filter is to the right of the post motor filter inside a removable housing.
Feb 08, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My DC08 dyson doesn't seem to have the suction it used to have, is there anything I can do to get it back
Poor suction is almost always caused by a blockage of some kind. You need to check all the pipes and hose, and remove any obstruction. You also need to check the filters - particularly the washable filter - and make sure they're clean. If you wash the washable filter, it's vital that you follow the instructions about drying it - if you use it when it's even slightly damp it can clog badly. If in doubt, get a new filter.
Feb 12, 2010 | Dyson DC08 Cylinder Bagless Canister...
Noisey DC07 Bagless Upright Cyclonic Vacuum; lack of suction...
Hi there it's SmartAlec from NelsonVacuums.com.au here. It is very likely you have a problem in the radix assembly or the filter is actually worn out. Basically to test either simply remove one then turn it on to test. If it runs better with out the filter (washable is most likely culprit) simply purchase a new one. If it is the radix assembly that is the problem it is possible to clean inside the little tubes by taking off the top and literally clearing dirt and fluff out with the help of a coat hanger. Alternatively a new one can be purchased. If you are in Australia or New Zealand I can help you with either part. Just put in a request via the email link n our website. Hope this helps regards Alec
Oct 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I remove the washable filter to clean it on my Dyson bagless vacuum?
As you are looking down at the base of the machine (viewing from the front) you will notice a yellow button on the right side just inside of the the wheel area. push up the button to release the casing that holds the hepa filter and the spongy filter. You can see a diagram on your machine which shows this process. After you take the casing from the machine, the round housing which houses the 2 filters will come out of this casing as you pull it off. You can grab the spongy filter and pull it our of the casing. Rinse both filters as shown in diagrams on the side of the casing. Do not use soapy water, just warm water and squeeze out the spongy filter after each new soaking. Let the filters dry for 12 hours and then replace in your unit and enjoy the refurbished air movement. It does suggest that you clean these filters every 6 months.
Aug 07, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Am buying a Bosch cooker hood - does it come with filters?
filters required only if you are venting inside your house (ie recirculating the air), if it is going outside, then you don't need them.
Jul 26, 2008 | Bosch DKE 9306 / DKE 9302 / DKE 9307...
Filter doesn't look clean after rinsing
It could well be that your Dyson is blocked elsewhere. Check the pipes, especially the feeder channels and the air way inspection channels on the Dyson as well as the main dirt channel after the rolling brush bar. Also brush clean the shrouds on the inner cyclones as these get notoriously clogged.
If the filter is washable it wont come up white like new unless you try a stain detergent like a pre stain remover. It would have to be heavily diluted as water is really the only way of cleaning a Dyson filter, but it also has to be of the washable type; Dyson produce a few filters, but some are not washable. EBay usually have good cheap replacements available but I'd check the first points first of all before filter replacement.
Jan 04, 2008 | Dyson DC14 All floors Bagless Upright...
Washable filter is getting clogged with dog hair
I have a Dyson Animal Absolute and a rescue white american eskimo dog and two tabby cats.
We found white hair on top of the washable filter and called Dyson to fix it. There shouldn't be anything on that filter.
The Dyson rep said:
Check the black rubber seal that surrounds the "cyclone" holes as it may need to be pushed down because it isn't sealing properly.
To do this remove the cannister and dump out the stuff in there. Do it outside so the fluff doesn't circulate in the house.
Turn the entire filter part upside down so you can see inside.
Check the seal that is at the bottom of the entire filter part and look at the two half moon "nozzles" that **** up the dirt.. now make sure the black rubber band that surrounds those two nozzles is either up or down... do this then vacuum a bit.. check the washable filter to see if it is clean...make sure the rubber seal actually is sealing.. it should just set into place once you have it done properly.
Now if this doesn't fix it, call Dyson, the number is printed on the front of the machine.. and give them your serial number which is located behind the removable cannister. The machine has a 5 year warranty.
Oct 20, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Kitchen Ranges Logo
52 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
