Question about Cycling
Which shifter should I change while riding? - Cycling
  • 29 Answers
The above advice is not exactly good cycling practice. The right shifter operates the cluster of gears on the REAR wheel. The main aim is keep your legs turning at a constant speed (around 70-90 turns per min). Do this by changing the right shifter. For most people cycling UNDER 30km/hr, the SMALL chainring (or middle one if three) is the gear to use. The left shifter will shift these.. When your pedal action is more than 90 rpm, shift to a larger cahinring (left shifter). Now there are some GEAR combinations to AVOID, mostly theLARGE front chainring and LARGE sproket on the back. This combination wears the chain rapidly, but more important, is the leading cause of the cahin coming off. !
Posted on Feb 25, 2013
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 78 Answers
Well, the basic principle is this: If you want a big change use your left shifter and if you want a small change use the right shifter. The right shifter is more for nuances and the left one will make a big difference in your riding speed and difficulty.
Posted on Jan 17, 2013
How do I change my right shifter?
It depends on how mechanical of a person you are. In simplest terms we'd unscrew the old one and put in the new one. Calibrate and then ride. Without model number or any other specifics we can only give you a general response.
For my bike, I'd change gears to the smallest gear first. Then I'd locate the screw holding the whole thing in place along the underside... unscrew. Then unhook the shift cable from the shifter. Then unthread that cable through the bike frame until I get to the derailleur. Remove / loosen the screw that holds it in place. Put the new shifter in place. Hook the cable back in. Change shifter to position of the current gear and thread the cable back through the bike to the derailleur. Slip cable back into place and tighten. Calibrate and ride...
Aug 30, 2015 | Giant Cycling
How do u change the shifter?
you change the shifter by taking it apart and there will by all the electronics and scews or somethin will hold the shifter on. then just replace it.
Aug 07, 2013 | Peg Perego John Deere Turf Tractor
Trying to replace a shifter in a older gator 4x2 with a new shifter
I can get you the schematic if that would help, or i have a new style wiring harness i can sell you
Apr 10, 2013 | Peg Perego John Deere Gator HPX Ride on...
The gears will not change at all. It seems like the part that you twist to change gears is seized on both sides. This is causing the bike to ride very slow.
Actually, it's causing you to have no gearing options. If you were Lance Armstrong the bike would move fast ;0) even with a flat tire.
http://www.parktool.com/blog/repair-help/shift-levers-shifters
Crimped, corroded shifter cables can prevent accurate shifting. I'm thinking you need a bike mechanic to look at it.
After it's all fixed you might want to view some resources concerning shifting, braking and general riding skills. It's all out there.
Feb 23, 2011 | Pacific International Pacific Evolution...
Will not run or move. have changed battery, checked all connections
No, just the shifter. Just to check you can exchange the red and blue wires under the pedal(just for a second or so, do not do this permanently) to see if you get power to the wheels, if so then yes it is Definitely only the shifter, but I am still pretty sure it is just the shifter. you can also call Peg Perego Tech support which is excellent and they can help you too 1800-728-2108 and parts can be priced and found at www.mypegperegoparts.com
Nov 13, 2010 | Peg Perego John Deere Gator HPX Ride on...
How to change speed for gator
you have to remove the high speed lockout, its a little red plastic piece on the shifter and there is a screw that holds it in
Apr 10, 2010 | Peg Perego John Deere Gator HPX Ride on...
Changing into reverse
If the shifter is not working then you can get at a new shifter with a wiring assembly at
http://www.shopjandl.com/asgi0115nyr.html
I had the same problem and the repair help at www.shopjandl.com told me to replace the shifter and now the kids are happy!
Hope this helps
Jun 17, 2009 | Peg Perego John Deere Gator HPX Ride on...
Transmission keeps cuting out..doesnt change gear ...over rides
there is some problem in your gear shifter the pinion is not engaging properly according to the counter so change the shaft of the gear shifter
Jul 29, 2008 | Mazda 323 Cars & Trucks
Cycling Logo
494 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
