Question about NRS Promed Wall Mounted Folding Shower Seat
Fixing Instructions I want to remover a ProMed shower seat and cant figure out how to access the fittings. Also who are the manufacturers of ProMed products?
How to remove cartridge from oakbrook shower faucet with 3 handles
You take off the handles, then the packing nut and you should see the valve stem and it unscrews all the way out. You can then look at the seal on the steam and the seat is in the valve. To change the seat, you need a special tool that fits in the fixture to twist the seat out.
Jun 12, 2015 | Ace Hardware OakBrook& Three Handle Tub...
Tip
How to repair a washer-type bath & shower faucet
  • To take apart a bath/shower faucet for repair, first turn off the water. Then take the faucet apart by removing its handle, escutcheon and packing nut. The packing nut may be buried deeply in the wall, requiring a socket wrench for removal.
  • Your bath and shower faucets may have a renewable seat that can be smoothed with a seat-dressing tool or removed and replaced using a seat wrench. For replacing and repacking the washer, follow the same instructions provided for a washer-type faucet. Some faucets may need a complete replacement of the combination stem/seat unit.
on Jan 16, 2010 | Plumbing
How to remove promed shower seat
the seat sits on a " v" section that is attached to the wall. You may have to lift the bottom out a bit then lift the seat support up off the bracket. If it has be on for some time then it may require a slight tap with a hammer to get it to move as it mat be corroded into place.
Sep 18, 2014 | NRS Promed Wall Mounted Folding Shower...
Can i fit a baby start solofix car seat by using the lap belt as the positioning of the fixing points on the seat would surgest i could
No. car seats have to be fixed in the car the way they are intended. You could checl with the manufacturer to see if there is a work around
Oct 21, 2010 | Toys
The faucet drips and I cant figure out how to make it quit.
It can be repaired without taking entire valve out of wall. First shut water off and remove handle. Next you will see a collar that will screw off to remove the cartridge below is a link for a single handle moen faucet. Check it out to get an idea. If you know your model you can research on line ,but they are close enough to give you an idea.
Once appart replace washers or o -ring's. Pay attention to how you take it appart for easy reinstallation.
http://www.moen.com/shared/pdf/t2703pt.pdf This link is aparts breakdown of a single handle faucet.
http://www.moen.com/shared/pdf/t2703pt.pdf This site is installation instructions.
http://www.efaucets.com/detail.asp?Product_Id=T2703 This site you can enter you faucet model to retrive information.
Jun 19, 2010 | Moen & One Handle Tub & Shower Faucet
Cedo Rue Toilet Seat Soft Close White EAN: 4016959076115 Just bought this - fixing instruction diagrams are unreadable. Can anyone help? Does anyone know if the manufacturer has a web site?
Just bought a Cedo Rue soft close toilet seat. Can't make any sense out of the useless instructions and what to do with all the bits. It also included an alum key which I can't see a use for. Can you please help
Nov 29, 2009 | Duravit Home
I want to fit an ok baby seat
go to any shop of bike and take strap and use it
Sep 07, 2009 | Cycling
Cant fit nania first car seat
We just fitted our 'new' secondhand narnia yesterday with instructions and it was a bit of a fiddle, but once in was very secure. Place the lap/diagonal belt through the slot in the back so that it comes out the front, it then goes over the arm rest, back through the other slot, across the back of the seat, then through the slots in the other side over the arm rest again and click it in.
May 15, 2009 | Nania Dreamer LX
Put harness belt back on baby car seat
22880-mtta is an Eddie Bauer carseat. Go to http://www.eddiebauer.djgusa.com/usa/eng/Instructions
Enter the model number 22880-MTTA, and date of manufacture.
Nov 11, 2008 | Baby Gear
Assembly and fitting of shower screen
Hi trimdon tony,
I'm Harvey the Master Plumber.
Your problem is: You have a ceramica PWAU0071 shower screen a box of fittings and no instructions on assembly.
In this case the only advise I can give you is to ask the manufacturer for a copy. That"s what I would do. It can be e-mailed, faxed or snail mailed. Be nice. Just tell them you like the product but you lost the instructions. Works every time.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 26, 2008 | Home
NRS Promed Wall Mounted Folding Shower Seat Logo
52 people viewed this question
Top NRS Home Experts
Donni Steen
john h
Bill Boyd
Are you a NRS Home Expert? Answer questions, earn points and help others
