Question about Kettler Treadmill Track Motion
Reset service light - Kettler Treadmill Track Motion
0% oil life
to reset the light with the doors closed key on press the gas down to the floor 3 times then the light should flash then its reset
Aug 27, 2012 | 2007 Chevrolet Cobalt Coupe
How to reset service light on 2007 Acura MDX
The full procedure how to reset oil service light Acura MDX. After an oil change, if you like to reset any maintenance oil light for Acura cars. Or any error which appears on the display.
http://resetservicelight.com/reset-oil-service-light-acura-mdx/
Oct 14, 2010 | 2007 Acura MDX
How to turn the sevice warning light off after oil change ?
BMW Model E39 built from 1996~2000 will have a port like the one shown below. A Reset tool like a Peake R5 or R5-FCX is needed to reset the oil service or inspection service lights after required service.
1) If you have a reset tool then turn your car key to Position II but do not start the car.
2) Turn the cap counter clock wise on the Data Link Connector and insert the Reset Tool
3) Follow the instructions of your reset tool, different models may have different functions however they all create a short in PIN 7 to PIN 19 for a given amount of time.
  • OIL Service Reset requires pin 7 and 19 to be closed for 3+ seconds
  • INSPECTION Service Reset requires pin 7 and 19 to be closed for 10+ seconds
  • 4) Once done, remove the reset tool and close the cap .
    5) Your dash should light up with green lights at this point.
    If the light did NOT reset after the above steps then you might be resetting Oil Service however an Inspection Service is needed.
    Aug 04, 2010 | 1998 BMW 7 Series
    I have 1995 volvo 940. how do you reset the service light
    Buy a service light reset tool. try www.biltema.se and look up part no, 15-1389.
    Mar 27, 2010 | 1995 Volvo 940
    I have ust serviced my 2001 volvo s40 and now the
    did the sevice light come on before you serviced it? when you "serviced" it I assume you changed the oil and now need the service light reset.
    I bought the 1998 S70. it got time to change the oil. Being how I am I changed the oil myself. I had to call dealership about resetting the service light.
    they said $29.96.
    I said 29.95?!!! how much if YOU would have changed my oil and reset the light?
    they said $29.95.
    so I learned you need to access the OBDII to reset the light.after service. hope this helps.
    Jun 13, 2009 | 2005 Volvo S40
    SERVICE DUE SOON LIGHT
    Press odometer reset/adjustment shaft in, hold in and turn key to run position. Keep holding in the reset shaft in for about 30 seconds. release shaft. turn key off. restart car. Service Light should go off in about 5 seconds.
    Mar 25, 2009 | 2008 Acura Tl
    Service light
    To reset the MAINT REQ'D light, press and hold the select/reset button on the right side of the instrument panel. Turn the ignition on and hold until the light goes out.
    This should get rid of the service light.
    Joe.
    Jun 29, 2008 | 2001 Honda Accord
    Kettler Treadmill Track Motion Logo
    Top Kettler Exercise & Fitness Experts
    Jim London
    Jim London
    ray gallant
    Steven Brandon
    Steven Brandon
    Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
