Question about Food Mixers
Change cartridge in moretti domino tap? - Food Mixers
7inch mixer lever tap is dripping how to fix
Turn off the water to the taps. Screw the top off your taps and clean off the rubber seals from lime or dirt and then put back together nice and tight. Hope that works
Sep 07, 2017 | Food Mixers
Why does the mixer tap bangs when the hot water tap is opened?
This often happens when the pipes in the house are not secured along their run, follow the pipes and check for elbows etc. that can move around when shaken. Any that you find should be secured to any nearby firm structure.
Jun 30, 2011 | Food Mixers
We have a hansa canyon tap when we installed it everything seems ok but then we get a red flashing light and it turns off... help pls?
Have you solved this issue yet? I have the same problem with my basin and bath tap. Its driving me nuts trying to fix it!!!
Jan 03, 2011 | Food Mixers
Kitchenaid mixer won't run changed out brushes and have changed them out in all 4 different positions
The brushes need to be seated onto the armature. Try going from off to high quickly and tapping the motor housing. Once the motor starts, let it run for 15 min plus to seat the brushes. Keep clear of or remove beaters whille trying to get the moror running. In brief, the brushesaren't making good contact with armature. Good Luck
Aug 11, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
How to fit POLO PULLOUT SPRAY KITCHEN SINK MIXER TAP 0119 **NDD**
hi i need to fix a pull out sink mixer...but i have no idea how to fix.pls help.thanks
Oct 05, 2009 | Food Mixers
Oil seal
1. Remove the acorn nut, hex nut, and washer that hold the "planetary" agitator section on the transmission shaft.
2. Remove the trim ring (if any) around the same.
3. The agitator section should now be able to be worked free.
4. Remove the retainer clip on the top of the agitator shaft. (Some models have a pair of hex nuts here; if so, remove those.)
5. Pry the gear up and off the shaft. Remove the square key from the shaft keyway at the same time.
6. Tap gently on the top of the agitator shaft to drive it out from the bearings and grease seal.
7. Recommend removing and replacing the top bearing at this time; it's inexpensive to replace, if you're in this deep.
8. Use a suitable diameter piece of round steel stock to drive out the lower bearing and oil seal. I don't recommend using the agitator shaft.
9. Clean thoroughly, insert a new bottom bearing and oil seal, drive in place with a rubber mallet.
10. Replace agitator shaft through oil seal and bearing, tap gently into place.
11. Fill cavity with approved lubricant. I use USP-grade mineral oil, as it is food-safe and provides satisfactory lubricity.
11. Install top bearing, tap gently into place.
12. Reverse steps 5-1 to reassemble.
Aug 24, 2008 | Food Mixers
Mixer attachment
make sure attachment is turned full counter clockwise to release point give a good tug if doesnt work try a light tapping with a rubber hammer or lobster wooden hammer
Nov 20, 2007 | KitchenAid KSM150PS Artisan Series Stand...
Kneading Blade Stuck on Kenwood Mixer KM300
Lightly tap out the dough with a piece of wood in the direction you would usualy remove it
Jan 16, 2007 | Kenwood KM300 Chef Stand Mixer
Food Mixers Logo
56 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
