Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Power requirements I di not know the voltage
    Problem Solver:
  • 9 Answers
The BEFSR41 version 2 requires 9 VAC @ 1.0 Amp.
Posted on Jan 25, 2009
Power voltage requirement
Wrong site. I fix home appliances, But you can buy them cheaper than I would fix them for.
Dec 26, 2015 | Cars & Trucks
I havea27" Westinghouse LTV-27w2 LCD TV. I am with AT&T Uverse along with internet service. I believe I have a power supply problem. There is absolutely no power to my TV. Everthing else is...
Do you know how to use a meter? If so the first thing to do is take the back off and check the AC fuse, if this is blown replace it and see if the set works. If it blows again you have a short in the primary power supply and replacement of the power board will be required. If the ac fuse is good you will need to check all the plugs coming out of the power supply for voltage, if you have voltage coming out then you could have a bad main board or power supply. If you have no voltage coming out and the fuse is good then replacing the power supply is required. Let me know what you find and I can help you further!
Tim Nolan
Sep 23, 2008 | Televison & Video
Required output voltages from an acoustic solution lcd television power supply unit
Only the original supply is going to work---schematics with voltages and wave forms are rarely available online except to a authorized service center for that brand---they want to SELL REPLACEMENT boards and not have someone fix them.
Jun 15, 2012 | Televison & Video
Router won't power up
Check the power adapter with a multimeter. The voltage should be the same or slightly higher that the voltage stated on the adapter's label. If there isn't any or low voltage the the adapter is faulty and needs to be replaced.
Mar 06, 2012 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have a condenser mic, and it needed phantom power to work, so I bought the Ultra Di-100, but I don't know how to make my mic work with it.
Sorry, but the DI-100 can OPERATE on phantom power, not supply it. If you have a mixer that has phantom power then you have no need for the DI box. DI boxes are to convert unbalanced signals to balanced to send via XLR or TRS cables.
If you don't have a mixer that has built in Phantom power or a source of Phantom power, then you need a mic preamp that can supply the phantom power.
Here is an example device, but DO shop[ around as you should find some even less expensive. Make sure they have phantom power.
http://www.amazon.com/M-Audio-Audio-Budget-Microphone-Preamp/dp/B000CZ0RZG
Dec 21, 2010 | Behringer Ultra Di-100 Active Direct Box...
Repetitive disconnect problem....requires powering off & on to reset
I used a D-Link Di 624 for a number of years with Comcast and never had a problem with the router, but I did upgrade the firmware. You may want to look at the following items from D-Link about the DI-624S and see if you can find a better solution. I took the router out of service as I changed to Verizon FIOS and use their provided router.
See: http://www.dlink.com/support/faq/default.aspx?question=DI%20624S&page=1
Dec 06, 2010 | D-Link AirPlus Xtreme G DI-624S Wireless...
I've lost my adaptor to my router. I just need to find a place that sells parts.
Try this site, find an adapter that is same voltage as the one that came with the d-link, i think its 12v 1.2a so if you get a 1000ma or 500ma 12v power supply should do the trick.
http://cpc.farnell.com/jsp/search/browse.jsp?N=411+1002136+500001
Feb 09, 2010 | D-Link DI 514 Wireless Router (DI-514)
I'm going to Europe and wanted to know how to convert electricity so when I plug in my computer it won't fry the computer
This is a copy from the Radio Shack site. The quick answer is go to pretty much any electronic store or most travel stores and buy a Foreign Power Converter.
AC to AC Power Conversion (Foreign Voltage Converters) Purpose of Converter / Explanation of Operation AC-to-AC voltage converters, or travel converters, are designed to convert the voltage used in a foreign country to the voltage required for a particular AC device. These converters are either transformer-based or solid-state, and this affects what type of devices the converter can power. In addition to converting the power, you will often need to also use a plug adapter. Plug adapters are generally either built into the converter, or provided as separate parts. They are also sold separately, for use with multi-voltage devices that are designed to convert the power internally.
Selecting a Converter These are one of the more confusing of the power conversion devices. Because of the range of voltages, plug types and converter designs, many customers find that they need help determining exactly which converter they need. To aid in that process, we have put together a short worksheet to help you determine what type of converter is needed: We recommend that you print out thi sheet when taking a number of different devices to a different country.
First, you should determine the electrical requirements (voltage, frequency, and wattage) for the device(s) you will be taking with you. This information is generally on a label or embossed into the back or bottom of the device. Make a note of the voltage(s), frequency or frequencies, and the wattage indicated for each device.
  • The voltage may be given as either V, VAC or VDC. The standard voltage for US devices is 120 V. Devices that are designed to operate using different input voltages will be labeled, such as 110/120 V, or 120/240 V.
  • The frequency will be given in Hz. The standard frequency for US devices is 60 Hz. Devices that are designed to operate using different frequencies will be labeled, such as 50/60 Hz.
  • The wattage will be given in either watts (W) or volt-amps (VA). If the wattage is not listed on the device, you will need to contact the device's manufacturer for this information. If you have the maximum current consumption (in amps), you can calculate the wattage by multiplying the voltage (V) times the current consumption (A).
Next, you will need to know the electrical requirements for the country you are going to be visiting.
Next, you will need to compare your equipment requirements to the country's information to determine whether you need a Step-up or Step-down Voltage converter.
  • If your equipment accepts the voltage and frequency provided by the country you will be visiting, then only a Plug Adapter will be required.
  • If the voltage of the target country is higher than the voltage required by your device(s), you will need a Step-Up Voltage Converter.
  • If the voltage of the target country is lower than the voltage required by your device(s), you will need a Step-Down Voltage Converter.
Once you know what type of converter or adapter you need, consult our list of travel power conversion products to find one that meets your requirements.
Cautions
  • The AC outlet in many foreign bathrooms is for low-wattage devices only. To avoid damage to your converter and/or attached device, check with your host or hotel before powering a high-wattage device (such as a hair dryer) from this plug.
  • Do not use a voltage converter with electronic devices such as televisions, VCR's and computers unless the device indicates that it can handle both 50 Hz and 60 Hz.
  • Do not use heating appliances, such as hair dryers, irons and coffee-makers, on a transformer-based voltage converter.
  • Do not use non-heating electronic devices, such as calculators, electric razors and portable audio players, on solid-state voltage converter.
  • Do not use 110-120 VAC Surge protectors or Uninterruptible Power supplies on a 220-240 VAC system. Even with a step-down power converter, damage could occur as the two power systems are wired differently.
Sep 22, 2009 | Toshiba Satellite L305D-S5895 Notebook
My D-Link AirPlus Xtrame G is dead
Your power adapter may be dead, check the power connector with a multimeter to see if you have the correct voltage as per the label on the adapter. If not you may only need to buy a power adapter.
You may be able to borrow another adapter with the same voltage and current rating and plug it into your D-Link and if you get a POWER and STATUS lights it proves you have a dead power adapter. If you don't get any lights then it looks like your D-Link is dead.
Nov 25, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Dim Power LED on DI-707P
there is apossible hardware issue within the unit itself, the chipset may have been damaged through age, surge or impact.
aside from the hardware issue, it can be a firmware issue too, and an upgrade will be the best move to solve the problem.
please contact D-Link support to perform further troubleshooting and to check on the warranty status of the device as it is showing signs of being deffective.
http://support.dlink.com
phone: 1.877.45D-LINK (1.877.453.5465)
hope this helps
Aug 20, 2008 | D-Link DI-707P Router (DSDLDI707P)
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
57 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
