Question about Avaya Ip500 V2 Etr 6 Base Card - 700476039 - Ip Office 500 Partner Edition -
IP office SIP calls auto answering without beep
I am trying to implement auto answer mode in my Avaya system. even i have enabled HFAns key and we have 2 different trunk , SIP and PRI. internal calls and PRI calls are auto answering with a beep, but SIP calls are auto anwsering without any beep. My objective is enabling call alert in auto-answer SIP, Kindly suggest.
SOURCE: Not able to connect to server
The software vpn probably will not work.
Is the vpn tunnel up? Can you ping the IPO? what subnet is the pc?
Posted on Dec 21, 2007
SOURCE: Avaya 5610 double display on incoming caller ID
Did you get this fixed. I would double check the firmware files of the phone. And maybe reset it.
Posted on Dec 25, 2007
  • 33 Answers
SOURCE: Blank Screen
Try changing the connection on the ethernet switch like the cisco switch if you are you using power on ethernet...
Posted on Dec 11, 2008
SOURCE: IP Phone available for IP office?
If your IP Office is Rel 4.2 or higher, You can purchase a license that will allow you to load a vpn script into the phone. Once you set up your VPN router at corporate, the phone gets plugged into any open internet connection and syncs up with the VPN router and makes a tunnel which then will connect with the phone system giving you a remote IP phone extension of that system.
For the PC, just load client software on it, and it works the same.
Since the tunnel is directly from the device (phone or PC), your home network will not be apart of the office network.
Posted on Mar 12, 2009
SOURCE: Dial tone, can be called, hear caller, but caller cann't hear me.
The problem is likely either a conflict in compression or a speech path problem.
In Manager, is "Allow Direct Media Path" checked?
If so uncheck and reboot eh phone system, then reboot the remote phone.
Posted on Jul 30, 2010
How can I get my wireless headset CS520 model to answer a call without having to lift the phone receiver first?
A headset button can be added to the phone that when pushed will activate the headset port on the phone. Once added the light will light when headset mode is active. This button can be added through the multi-line set key assignment for in the mitel. I would also suggest added a release button at the same time as the release key would be used to disconnect a call in headset mode.
Mar 09, 2015 | Mitel 5330e IP Phone 50006476
How to turn on answer machine on avaya 9508
See page 5 of the manual here... http://www.manualslib.com/manual/451156/Avaya-Ip-Office-9508.html
Jul 13, 2014 | Avaya 9508 Digital Phone New
How do I set up Voicemail for my office?
Yikes man. The Polycom phones are used in just about every hosted or sip based pbx. So hard to answer without more information. Do you have a message or voicemail button? Do you know anymore info about the system that your phone connects to? Company name etc?
May 02, 2014 | Polycom IP 335
The call gets answered automatically on speaker rather than ringing.
You must have accidently hit the HFAns button on. If on your digital display you see a down arrown button on top of HFAns press the gray button on the bottom of HFAns. This will disable the handsfree option. Hope this solves your problem.
Nov 18, 2010 | Avaya Definity 6408D Corded Phone
4412D+
All users or just 1 or 2.
Have you tried to replace the handsets?
what kind of lines? Analog pots or digital PRI, or SIP?
Mar 16, 2009 | Avaya 4412D Corded Phone
Using AVAYA 4610SW IP phone
Answer to the second problem :-
1. The changes in the ring tone has to be made by accessing the Avaya server where the phones are registered.
2. Log in to the avaya server...... enter change station <station number> on the command prompt
3. In the personalized ring pattern field, you can select one out of the 8 available options by typing any digit between from 1 to 8.
4. The ring pattern of that particular station will change accordingly.
5. Keep the personalized ring pattern of all the stations different by assigning different digits against this value
Jan 13, 2009 | Avaya 4610SW
Making a Polycom SoundPoint 501 work on an Avaya IPO
As you have probably found, SIP phones are not supported until R5, which just came out.
Nov 11, 2008 | Polycom SoundPoint IP 501 IP Phone
Hi TexasTom,
I'm not quite clear on your problem. But I think what your describing would be difficult to archive. That's if I understand you correctly!
Perhaps what you might want to consider is this sort of device. It allows to normal (PSTN) telephones to be used as either SIP (VoIP) or as normal PSTN telephones. It does not require a PC once it's been set-up.
Hope this helps.
Kind regards,
Spare head 2.
Jan 04, 2008 | Avaya 5610 IP Phone
Avaya Ip500 V2 Etr 6 Base Card - 700476039 - Ip Office 500 Partner Edition - Logo
77 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
