Question about Kitchen Ranges
I need a Tecnik TKE5445 cooker hood metal filter - where might I find one?
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: does filter for cooker hood need to be used if
If you have hooked to external vent you do not need to use the filter.
Posted on Apr 18, 2010
SOURCE: I need the Manual for the Tecnik TKC 1285 Dual Fuel Kitchen
anyone still need the users manual for this, i have a copy and could scan and email it, drop me a line on probinson09@mac.com anyone ever changed any of the elements, my small oven grill element is warped and the fan element has stopped working, i have the parts but haven't attempted installing them yet
Posted on May 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: Cooker hood turning off
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
SOURCE: a bulb blew in my tecnik cooker hood and neither
In case you are still looking for an answer. The same happened to me.
I found a 3-amp fuse which I changed, and now it's ok.
I removed the chimney casing and located the electrical connection into the wall. You'll find a fuse unit within the switch which swings out.
Hope this helps.
Posted on Dec 20, 2010
Cooker hood installation
A cooker hood needs to done by a competent qualified Electrician but basically depending on your surface of the cooker hood.Depending on the type of cooker hood you have(extract or outside) If it is a extraction (meaning you are using filters and not connected to a vent) The Electrician needs to connect the electric to a point or spur via a power switch on the wall which when you fit up the main part of the hub covers the spur. after that you need to measure and fit the cooker hood to your requirements but make sure your walls can support it and mark off the holes before drilling or check the walls for electric wires in terms of safety.
May 21, 2012 | Washing Machines
There is a loud buzzing from our Tecnik 1285 range cooker. The buzzing starts about 5 minutes after turning either of the ovens on, and only stops 10 minutes after turning it off. The front of the oven /...
its the cooling fan to keep the control and metal and top of cooker cool. mine is also extremely loud. I think it basically turns unecessarily quickly and could be slowed with a resistor in line
Jan 20, 2011 | Tecnik Ovens
A bulb blew in my tecnik cooker hood and neither the lights of the fan will work? is there a fuse somewhere that I need to change?
Hope this helps.
Dec 08, 2010 | Rangemaster Kitchen Hood
I have a tecnik tkc 1255/ss range oven serial no 0704020076 COD. 0.41019xst0sq i need a replacement main oven door handle
You dont happen to have the LPG jets that were supplied with the cooker do you? I'm having trouble getting hold of any?
Thanks,
Apr 19, 2010 | Tecnik Ovens
How to change carbon filter on whirlpool cooker hood AKG958GY
The paper filte pulls out from under the lugs of the metal panel that is attached to the door, turn the plastic clips on the left and right, half way and it will drop out.
Sep 14, 2009 | Kitchen Ranges
Tecnik TKC 1426 Kitchen range
Hi, switch off the mains for the cooker, wait for about 15 seconds, switch it on (0:00 flashing) then press the 2 buttons on the left at the same time and hold them, and then press the - or + button to set the time.
Cheers
Feb 22, 2009 | Tecnik TKC1426 Electric Kitchen Range
Inner door seal
You need to disassemble the door and reassemble with the inner glass well in place, no need for a new door.
If the glass is damaged, call manufacturer and replace glass.
If some other part on the frame has bent, replace the faulty part.
The whole door is expensive.
To replace or refit the door glass you can do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagrams below as an example, I do not have Tecnik diagrams:
, click on picture to enlarge:
Contact Tecnik at the number listed on the owner manual to get diagrams for your model.
Apr 09, 2008 | Tecnik TKC1426 Electric Kitchen Range
NEEDED MANUAL FOR TECNIK COOKER
I have a manual if you e mail me your address to monica230157@hotmail.com, I'll photocopy it and post it on to you.
Jan 12, 2008 | Tecnik TKC8525 Double Oven
TECNIK 1285 RANGE COOKER
I have a Tecnik Range cooke that was in the house when i bought it. The secong oven has no cover for the heating element at the top so everything I put in browns at the top. Should this oven have a metal plate underneath so that I can use it as a conventional oven or should it be like that
Dec 19, 2007 | Tecnik TKC1285 Dual Fuel (Electric and...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
